Page 7 of 9 1 2 3 4 5 6 7 8 9
Re: Project Bad Demeanor [Re: Hitman340] #864438
07/29/12 09:42 PM
07/29/12 09:42 PM
BPE Offline
BPE  Offline
You will be grudge racing in no time.
Rod
Re: Project Bad Demeanor [Re: Hitman340] #864439
07/29/12 11:26 PM
07/29/12 11:26 PM
Out West
408strokerdart Offline
Out West
Another.
Scoop attached to the hood or mounted independently? Looks good either way. Wasn't sure how much I was going to like that scoop on that body, but it looks good.
Re: Project Bad Demeanor [Re: 408strokerdart] #864440
07/29/12 11:34 PM
07/29/12 11:34 PM
Niles, Michigan
Hitman340 Offline OP
Niles, Michigan
Its mounted To the engine.
Re: Project Bad Demeanor [Re: Hitman340] #864441
07/30/12 12:53 PM
07/30/12 12:53 PM
Out West
Out West
Thinking about doing this to my new scoop also. Any pictures of how you did it? Did you build a tray inside the scoop then mounted to the engine? I don't think I have ever seen good pictures of how this is done.
Re: Project Bad Demeanor [Re: 408strokerdart] #864442
07/30/12 07:18 PM
07/30/12 07:18 PM
Niles, Michigan
Niles, Michigan
The tray is bonded to the inside of the scoop.Then you make up the mount to fit it from there.Here is the style i made up.
Re: Project Bad Demeanor [Re: Hitman340] #864443
07/30/12 07:21 PM
07/30/12 07:21 PM
Niles, Michigan
Niles, Michigan
Its made of 3/8 .058 Moly.
Re: Project Bad Demeanor [Re: Hitman340] #864444
07/30/12 07:23 PM
07/30/12 07:23 PM
Niles, Michigan
Niles, Michigan
A look at the inside of the scoop.
Re: Project Bad Demeanor [Re: Hitman340] #864445
07/30/12 07:27 PM
07/30/12 07:27 PM
Niles, Michigan
Niles, Michigan
You also can use a kit from Quarter Max. This will cut down on some fab work.It just screws inplace of the air cleaner stud and your fastener is then on top of the scoop.
Re: Project Bad Demeanor [Re: Hitman340] #864446
07/30/12 11:01 PM
07/30/12 11:01 PM
Out West
Out West
Thanks for the pictures. It clears that install up nicely. Did you have to cut and re-flange the scoop or did it just happen to be at the right height to fit under the hood?
Nice work. If I were closer you would be doing a few things to my Dart.
Re: Project Bad Demeanor [Re: 408strokerdart] #864447
07/31/12 08:13 AM
07/31/12 08:13 AM
tboomer Offline
tboomer  Offline
Now that is some nice work!
Re: Project Bad Demeanor [Re: tboomer] #864448
07/31/12 09:56 PM
07/31/12 09:56 PM
Niles, Michigan
Niles, Michigan
Brian I hope this was some help to you.I did not have to re-flange the scoop.It fell about 3/8s lower than I would have made it but not worth what it would take to change it.If there is any way I can help please feel free to give me a shout.Thank all of you for the kind words in regards to my work.
Keith,Im pulling everything out tommaro and Giving it to Vic this weekend.Looking forward to bending the needle on your Dyno over the winter.
Re: Project Bad Demeanor [Re: Hitman340] #864449
07/31/12 11:25 PM
07/31/12 11:25 PM
Out West
Out West
Definately helpful. I appreciate the pictures.
Re: Project Bad Demeanor [Re: 408strokerdart] #864450
08/03/12 01:00 AM
08/03/12 01:00 AM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
Top-shelf Jeff! I am glad to see you back at it (healthy).
Re: Project Bad Demeanor [Re: HardcoreB] #864451
12/02/12 08:56 PM
12/02/12 08:56 PM
Niles, Michigan
Niles, Michigan
Turned the X-mas lights on for santa. Hope he brings me something good.
Re: Project Bad Demeanor [Re: Hitman340] #864452
12/02/12 09:06 PM
12/02/12 09:06 PM
Niles, Michigan
Niles, Michigan
Wow, Wished I would have turned that light on sooner. That $hit really works.
ATI rates this bad boy to hold up to 1800 HP.
My little W8 would really have to grow a pair in order to break this thing. Now were just down to assembling the engine and we should be ready for spring.Merry christmas to me.
Re: Project Bad Demeanor [Re: Hitman340] #864453
12/02/12 10:12 PM
12/02/12 10:12 PM
south central pa
bdaz smblk Offline
bdaz smblk  Offline
south central pa
Another.
Car looks awesome and am sure it will run just as good.Is that a carbon hood if so who did it.Thanks Kenny
3120lb, small block, 10.5" tire, NA, through exhaust, full int, WITH 83/4 REAR, 9.0 at 150mph
Re: Project Bad Demeanor [Re: Hitman340] #864454
12/02/12 10:36 PM
12/02/12 10:36 PM
LONG ISLAND
fishy340 Offline
fishy340  Offline
LONG ISLAND
Nice i got the same exact one in my cuda....i know it been 4.60s in my friends 3250lb x275 car...mine is all fresh for next yr.
Re: Project Bad Demeanor [Re: Hitman340] #864455
12/03/12 12:52 AM
12/03/12 12:52 AM
Out West
Out West
Not to bust your bubble Jeff, but I see a problem....maybe. That is the same transmission I run. They forgot to put the "spacer" between the bellhousing and trans case on mine. They made a run of sb mopar bells that were to short and they make it up with a spacer. Now, maybe you have a newer bellhousing since they said they would correct it at their next run of castings. Just check it out....caused me some grief and took lots of measurements to find out it was not my mistake. ATI kept saying I didn't have the coverter in all the way.
Re: Project Bad Demeanor [Re: 408strokerdart] #864456
12/03/12 08:32 PM
12/03/12 08:32 PM
Niles, Michigan
Niles, Michigan
Thanks guys.
Kenny, That is a glass hood with a carbon wrap.This is something I offer at my shop.
Thanks for the good info Brian. I will be sure to give that a close look. If I run into a issue I may be asking for some of your measurements to compair befor I call them. Thanks again!!!
Re: Project Bad Demeanor [Re: Hitman340] #864457
12/04/12 06:47 PM
12/04/12 06:47 PM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
That sucks about your arm Jeff but that car looks PROfessional!
