Re: bet you never had this problem
[Re: Boise Chall]
#861481
11/23/10 08:54 PM
11/23/10 08:54 PM
Posts: 28,069 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
Yep. That's way too much pressure on the input shaft. How did you put it in there? Did you stab it as far as it would go then crank on the bellhousing bolts to pull the transmission in?
That tight of a bushing will spin the input shaft when the clutch should let it spin. You might as well have never hit the clutch. Fix that and the problem should go away.
I'd hate to see what kind of thrust load you were putting on that input shaft bearing. It probably had everything stacked up tight in there.
[Re: kingkt]
#861484
11/23/10 09:11 PM
11/23/10 09:11 PM
Posts: 25,200 Upper Midwest
MoparforLife
Upper Midwest
Cut about 1/8 inch off the transmission input shaft where it goes into the pilot. It is bottoming out in the crankshaft and binding up.
Clean it, if it's Dirty. Oil it, if it Squeaks.
But: Don't fix it, if it Works!
[Re: feets]
#861486
11/23/10 09:31 PM
11/23/10 09:31 PM
Posts: 972 Mooresville, NC
A70Runner
Mooresville, NC
Are the bushings in the z-bar new? Did you adjust the pedal free play?
"People Think I'm Insane Because I Am Frowning All The Time" Black Sabbath
[Re: kingkt]
#861490
11/23/10 09:59 PM
11/23/10 09:59 PM
Posts: 1,212 QLD Australia
Keith Black®
QLD Australia
bolt the trans in without the clutch/flywheel, trans in neutral. see if you can turn the input shaft by hand (if your bellhousing allows you too)
-------------------------------- Darren Beale Keith Black Racing Engines®
[Re: kingkt]
#861491
11/23/10 10:05 PM
11/23/10 10:05 PM
Posts: 606 Montana
Yancy Derringer
Montana
Some general purpose ramblings from the nearly senile.
First, carefully measure the depth of the pilot from the bell face, as well as the length of the input shaft back to the bell face of the transmission.
Next, pull the clutch cover and disc OUT and install ONLY the transmission with no clutch.
Now you can put the box in HIGH gear, and with a yoke in the tail, you tell if the pilot is binding in the bushing.
If/ when you get this to check out, are you able to see into the bottom of the bell, I.E. do you have a stock bell or scattershield?
If you can see into the bell, take a friend to push the pedal all the way down, and measure iwth a feeler to see how much release clearance you have.
If you cannot see what's happening for sure, find yourself a "real" clutch rebuilder---they ARE around---and have them check the clutch. They'll need your cover and disc, and maybe your flywheel.
It DOES happen that covers don't release because of some problem
As others have mentioned, check your clutch linkage from top to bottom. Have a friend push the clutch in/ out SLOWLY and repeatedly while you look at such areas as the welds on the Z bar linkage, etc, or for other flexing. Even the clutch fork can sometimes crack and flex
