Priming 440 for Starting
#860479
11/22/10 10:24 AM
11/22/10 10:24 AM
Posts: 4,288 Danville, NH
Mopar_Mike
Danville, NH
I am going to prime the oil pump and would like to turn the crank as well but I have the radiator and fan etc. in already and its alittle difficult to get to the crank. If I am using the drill to turn the oil pump would it be ok to have someone bump the starter (with ignition key) to turn the crank?
Thanks.
RS23L7 4-Speed
Re: Priming 440 for Starting
[Re: Mopar_Mike]
#860481
11/22/10 12:11 PM
11/22/10 12:11 PM
Posts: 5,746 Ontario, Canada
Dodgem
Ontario, Canada
I would have a buddy do it or use this http://www.autozone.com/autozone/accesso...Switch/_/N-25eostart drill when it builds pressure turn engine over for 30 seconds or so while continuing to run drill keeping pressure up. Will do that a couple times. Cool thing is you have a hydraulic cam it will pump the lifters up as well so less clattering when start up comes. I then like to install the dizzy and pre time with carb off then install carb and start. If you have a manual pump it must be blocked off or you get a mess.
[Re: Mopar_Mike]
#860482
11/22/10 07:04 PM
11/22/10 07:04 PM
RapidRobert
You may have trouble finding the 2 sweet spots for the heads. You'll end up getting aggravated. There is room for your ratchet/socket if you use just the right length of extension. It'll be worth it to buy it. Several bucks is nothing compared to your investment in the eng & keeping your cool. EDIT take 5 minutes to read "break in secrets" at www.mototuneusa.com
[Re: Scatransit]
#860485
11/24/10 11:59 AM
11/24/10 11:59 AM
Posts: 366 San Gabriel, CA 91775
rexus31
Don't you have to rotate the engine to prime the top end?
2007 Dodge Charger R/T, Road and Track Performance Group, Steel Blue
1965 Chrysler 300 Convertible, 383 4V, 727TF, Factory Air, Spanish Red
1964 Pontiac GTO, Tri-Power, 4 Speed, Grenadier Red
"What ain't no country I ever heard of. They speak English in What?" - Jules Winnfield
[Re: rexus31]
#860486
11/24/10 01:02 PM
11/24/10 01:02 PM
Posts: 75,077 U.S.S.A.
JohnRR
U.S.S.A.
Some people do that , I have just poured oil over the rockers before torquing down the shafts, stamped steel rockers , used assembly lube on adjustables.
