Re: 71 cuda pro touring project
[Re: rhamson]
#859915
05/28/11 12:49 PM
05/28/11 12:49 PM
Posts: 1,462 Mrytle Beach SC
johnscudashop
Mrytle Beach SC
Hello, Being that this car will sit much lower than stock,I made my own bars instead of puchasing them from somewhere else because of this very problem plus I wanted the bars to be tied into a stronger structure other then the 20 gauge sheet metal of the cowl. I have 1 inch distance from the tire and the bar with the suspension fully extened upward. (like in the second picture) NOT TOTAL SUSPENSION TRAVEL. Enless something in the suspension breaks that would be plenty of clearance. But I notice that your bar looks like its mounted lower then mine on the shock tower. That is where it will hit if the suspension bottoms out. Hopefully you checked your tire clearance? These are things you need to address now while you mock your car up. Looks like you may have welded them in fully aready.
[Re: johnscudashop]
#859917
05/28/11 07:15 PM
05/28/11 07:15 PM
The work is looking good and progressing along nicely.
[Re: johnscudashop]
#859928
06/13/11 05:27 PM
06/13/11 05:27 PM
johnscudashop
Mrytle Beach SC
After some careful measuring I made the mounts today for the main hoop of the roll bar. What I did is, use 1/8 thick plate, trianglate the area from the rocker to the frame connector.
[Re: johnscudashop]
#859929
06/13/11 05:30 PM
06/13/11 05:30 PM
johnscudashop
Mrytle Beach SC
Using a competion engineering 1 3/4 diam .134 wall Roll bar loop .I am gonna build the rest of the cage off this.
[Re: johnscudashop]
#859932
06/16/11 07:54 PM
06/16/11 07:54 PM
johnscudashop
Mrytle Beach SC
After some more careful measuring,I finished trimming the main roll bar hoop. Then measured back at a angle from the top of the roll bar hoop to the rear frame rails. I ended up cutting into the back seat area being careful not to disturb any main supports to the rear seat. I will have to modify the upper rear seat frame for the main hoop to rear frame rail tubes to run through. Then I ended notching 2 tubes and sent them locally to be blasted and epoxy primed. When it comes back I will figure the rest. I want to make the rear crossbrace and front supports removable.
