Page 5 of 26 1 2 3 4 5 6 7 25 26
Re: 71 cuda pro touring project [Re: johnscudashop] #859914
05/28/11 09:13 AM
05/28/11 09:13 AM
Maryland
rhamson Offline
rhamson  Offline
Maryland
1" Tire clearance at maximum suspension travel
I believe you will have a problem with this 1" measurement for suspension travel. I installed the kit from USCartool and when they had sent no instructions with the kit I called them to verify the placement of these tower support bars. Basically I was told if I used the support tabs that weld to the existing support arms I should be okay. This placed the new support tube up much higher than what you have in your pictures. Here is a picture of where mine were placed.
Re: 71 cuda pro touring project [Re: rhamson] #859915
05/28/11 12:49 PM
05/28/11 12:49 PM
Mrytle Beach SC
johnscudashop Offline OP
Mrytle Beach SC
Hello, Being that this car will sit much lower than stock,I made my own bars instead of puchasing them from somewhere else because of this very problem plus I wanted the bars to be tied into a stronger structure other then the 20 gauge sheet metal of the cowl. I have 1 inch distance from the tire and the bar with the suspension fully extened upward. (like in the second picture) NOT TOTAL SUSPENSION TRAVEL. Enless something in the suspension breaks that would be plenty of clearance. But I notice that your bar looks like its mounted lower then mine on the shock tower. That is where it will hit if the suspension bottoms out. Hopefully you checked your tire clearance? These are things you need to address now while you mock your car up. Looks like you may have welded them in fully aready.
Re: 71 cuda pro touring project [Re: johnscudashop] #859916
05/28/11 12:51 PM
05/28/11 12:51 PM
Mrytle Beach SC
Mrytle Beach SC
Suspension fully extended upward
Re: 71 cuda pro touring project [Re: johnscudashop] #859917
05/28/11 07:15 PM
05/28/11 07:15 PM
The work is looking good and progressing along nicely.
Re: 71 cuda pro touring project [Re: johnscudashop] #859918
05/29/11 10:12 AM
05/29/11 10:12 AM
Maryland
rhamson Offline
rhamson  Offline
Maryland
I appreciate your concerns but the tube is angled steeply above the tire to the existing support which clearly allows plenty of clearance. I do like the way you have tied the tube into the door frame structure and may be something I may add as I too am not totally happy with the connection to the thin firewall metal.
Re: 71 cuda pro touring project [Re: rhamson] #859919
05/29/11 01:00 PM
05/29/11 01:00 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Just asking, but is there an advantage to a bar with such a dramatic 90 degree bend as opposed to just a straight tube going from the inner fender to the firewall area?
Re: 71 cuda pro touring project [Re: gtx6970] #859920
05/29/11 02:46 PM
05/29/11 02:46 PM
Mrytle Beach SC
Mrytle Beach SC
You always better off to go with strait brace if you can. With me tying it into the lower cowl and kick panel I didn't have that option.
Re: 71 cuda pro touring project [Re: johnscudashop] #859921
06/08/11 05:24 PM
06/08/11 05:24 PM
Mrytle Beach SC
Mrytle Beach SC
I added a cowl bar today as I wanted to add some ridgity to the upper part of the cowl(I plan on some hard cornering and Autocrossing ect.) I started with 4 1/8 thick steel plates mount in the door support area and 1 1/2 1/8 wall DOM tube. I had to modify the steering column support and the dash frame.
Re: 71 cuda pro touring project [Re: johnscudashop] #859922
06/08/11 05:25 PM
06/08/11 05:25 PM
Mrytle Beach SC
Mrytle Beach SC
Dash frame installed
Re: 71 cuda pro touring project [Re: johnscudashop] #859923
06/08/11 05:26 PM
06/08/11 05:26 PM
Mrytle Beach SC
Mrytle Beach SC
Steering column support modification
Re: 71 cuda pro touring project [Re: johnscudashop] #859924
06/08/11 05:27 PM
06/08/11 05:27 PM
Mrytle Beach SC
Mrytle Beach SC
End view
Re: 71 cuda pro touring project [Re: johnscudashop] #859925
06/08/11 05:31 PM
06/08/11 05:31 PM
Mrytle Beach SC
Mrytle Beach SC
I had to remove the original windshield frame corner braces. I will have to either modify of make new ones. One thing I must note, if you plan on this modification you might not be able to use your factory dash cluster or heat and Ac box. Since I am using a vintage air unit and a custom gauge cluster it wont be a problem.
Re: 71 cuda pro touring project [Re: johnscudashop] #859926
06/08/11 06:01 PM
06/08/11 06:01 PM
Mrytle Beach SC
Mrytle Beach SC
Dash frame clearance
Re: 71 cuda pro touring project [Re: johnscudashop] #859927
06/11/11 11:58 AM
06/11/11 11:58 AM
Mrytle Beach SC
Mrytle Beach SC
Re: 71 cuda pro touring project [Re: johnscudashop] #859928
06/13/11 05:27 PM
06/13/11 05:27 PM
Mrytle Beach SC
Mrytle Beach SC
After some careful measuring I made the mounts today for the main hoop of the roll bar. What I did is, use 1/8 thick plate, trianglate the area from the rocker to the frame connector.
Re: 71 cuda pro touring project [Re: johnscudashop] #859929
06/13/11 05:30 PM
06/13/11 05:30 PM
Mrytle Beach SC
Mrytle Beach SC
Using a competion engineering 1 3/4 diam .134 wall Roll bar loop .I am gonna build the rest of the cage off this.
Re: 71 cuda pro touring project [Re: johnscudashop] #859930
06/13/11 05:32 PM
06/13/11 05:32 PM
Mrytle Beach SC
Mrytle Beach SC
6 inches from rear head rest
Re: 71 cuda pro touring project [Re: johnscudashop] #859931
06/13/11 05:35 PM
06/13/11 05:35 PM
Mrytle Beach SC
Mrytle Beach SC
interior picture
Re: 71 cuda pro touring project [Re: johnscudashop] #859932
06/16/11 07:54 PM
06/16/11 07:54 PM
Mrytle Beach SC
Mrytle Beach SC
After some more careful measuring,I finished trimming the main roll bar hoop. Then measured back at a angle from the top of the roll bar hoop to the rear frame rails. I ended up cutting into the back seat area being careful not to disturb any main supports to the rear seat. I will have to modify the upper rear seat frame for the main hoop to rear frame rail tubes to run through. Then I ended notching 2 tubes and sent them locally to be blasted and epoxy primed. When it comes back I will figure the rest. I want to make the rear crossbrace and front supports removable.
Re: 71 cuda pro touring project [Re: johnscudashop] #859933
06/16/11 07:55 PM
06/16/11 07:55 PM
Mrytle Beach SC
Mrytle Beach SC
Notching the roll bar rear support tubes
