727 Help #859616
11/21/10 07:37 PM
11/21/10 07:37 PM
Indiana
BM70Dart Offline OP
BM70Dart  Offline OP
Indiana
Wondering what could be wrong with my 727 stuck it in car ran about 15 min drove down the road and then it quit working pulled lines off cooler nothing coming out of tranny lines could the pump went bad or what else i'm not a tranny guy thanks for any help
Re: 727 Help [Re: BM70Dart] #859617
11/21/10 08:10 PM
11/21/10 08:10 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
Pump tangs broke,low on fluid,converter need more info.
Re: 727 Help [Re: BM70Dart] #859618
11/21/10 08:13 PM
11/21/10 08:13 PM
Indiana
65dragnet Offline
65dragnet  Offline
Indiana
sounds like pump problem maybe broke ears on inner rotor
E. Williams 65 Coronet 500 3400lbs w/d, 446, Indy EZ'S, A&A transbrake,Comp 650 lift cam, 6.50 @ 105 mph 1/8th 10.25 @ 130mph 1/4
Re: 727 Help [Re: 65dragnet] #859619
11/21/10 08:15 PM
11/21/10 08:15 PM
okla.
sam64 Offline
sam64  Offline
okla.
if its in park there will be no fluid flow,put in nuetral and see what happens.
Re: 727 Help [Re: B G Racing] #859620
11/21/10 08:54 PM
11/21/10 08:54 PM
Indiana
BM70Dart Offline OP
BM70Dart  Offline OP
Indiana
It was full off fluid.
Pulled lines off in nuetral and nothing came out.
I drove the car about 1 mile came home and parked it and now it has no gears at all.
Pulled trans out and ears on pump look ok.
Re: 727 Help [Re: BM70Dart] #859621
11/21/10 09:01 PM
11/21/10 09:01 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
Make sure you have shift detents,the rooster and lever may have jumped up off the spool valve.
Re: 727 Help [Re: sam64] #859622
11/22/10 01:34 AM
11/22/10 01:34 AM
A Banana Republic near you.
JohnRR Online rolleyes
JohnRR  Online Rolleyes
This is not entirely accurate , there is fluid flow in park , it's just not as much as it is in neutral.
