Re: Question about column A-body shifter linkage
[Re: JohnRR]
#858421
11/22/10 02:11 AM
11/22/10 02:11 AM
Posts: 5,655 Detroit area
6PAX
Detroit area
I used the same linkage from a 318 904 to a 400 727
Yes, how did you have to modify it?
[Re: 6PAX]
#858422
11/22/10 10:22 AM
11/22/10 10:22 AM
Posts: 4,978 VA
DAMOPARS
VA
This is a motor home 727 (not sure if that makes a difference) and it was a few years ago, it did involve some mods had to grind a tab on the trans, but I can not remember what else I did, it was minor. This was when it was column shift car. It was a pain to get it off when I went to floor shifter. Somebody on www.bigblockdart.com would know for sure.
[Re: DAMOPARS]
#858423
11/23/10 02:01 AM
11/23/10 02:01 AM
6PAX
Detroit area
The Z bar, and I think the arm from Z bar to trans, is different
Can anyone tell me how to tell the difference? I want to look for a set of small block 727 linkage but I don't know how to tell the difference from the 904 linkage.
[Re: 6PAX]
#858424
11/23/10 10:17 AM
11/23/10 10:17 AM
Posts: 2,763 Myrtle Beach, SC formerly the ...
340wedge
On the 904 the linkage that connects to the transmission that moves the selector into gear is adjustable with a threaded rod and screw.
The 727 has an square block that slides onto a shaft coming out of the trans and that block is what adjusts the gear selector.
1971 Sassy Grass Green Duster 340 2006 Charger Daytona GoMango
