Brighter headlights? #858377
11/20/10 01:09 AM
11/20/10 01:09 AM
Anonymous OP
Anonymous OP
Anyone install these new high tech headlights? Like PIAA or other brands who offer bright white or something like that?
If so, do they really work? I got cheapies in my car and they are terrible....
Re: Brighter headlights? #858378
11/20/10 01:34 AM
11/20/10 01:34 AM
Colo Springs, Co
dragaddict Offline
super street
dragaddict  Offline
super street
Colo Springs, Co
What car are you changing? On a 69 B body we installed halogen bulbs but requires the use of a relay system or will burn up something [everything?] in the circuit. Not real hard to do and a possitive upgrade.
Re: Brighter headlights? [Re: dragaddict] #858379
11/20/10 02:04 AM
11/20/10 02:04 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Cheap H4 light housings with poorly designed lenses are no better than stockers (if even as good) though higher wattage bulbs (along with relays) will at least make them brighter... I run Hella lights with PIAA Xtreme White bulbs with relays.. The difference is amazing...
Re: Brighter headlights? [Re: 1_WILD_RT] #858380
11/20/10 02:11 AM
11/20/10 02:11 AM
Colo Springs, Co
dragaddict Offline
super street
dragaddict  Offline
super street
Colo Springs, Co
Allow me to run this just slightly of topic just a bit. What about tailights also. I really like the idea of better headlights but a decent set of tailghts that still look like they belong in an old car would be a nice compliment the the fronts. Any luck on this and would you relay tailights?
Back to your normally schedualed post
Re: Brighter headlights? [Re: dragaddict] #858381
11/20/10 02:53 AM
11/20/10 02:53 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Adding relays to the tail lights might offer slight improvement but actually adding headlight relays will help the tail lights almost as much by removing the major draw on the light circuit... It also helps the bulkhead connector.. I use relays for the headlights, high speed setting on the heater- A/C blower & on my power windows.. The lower draw circuits see less voltage drop so they also work better...
Re: Brighter headlights? [Re: 1_WILD_RT] #858382
11/20/10 03:12 AM
11/20/10 03:12 AM
Montana
Y
Yancy Derringer Offline
Y
Montana
I agree--headlight relays helps a bunch.
The big problem for all older Mopars is and has been the bulkhead connector, and marginally sized wire. So far as tail/ turn lamps, it really doesn't take that much effort to pull new wire from tail to front, and possibly eliminating or upgrading the connector in the kick panel
Re: Brighter headlights? [Re: Yancy Derringer] #858383
11/20/10 08:18 AM
11/20/10 08:18 AM
Sterling Heights, Michigan 483...
daniel_depetro Offline
I have read that the old trick was to simply use larger wire from the switch directly to the headlights bypassing the bulkhead connector.
This along with some good quality sealed beam replacements should make quite a difference.
I've always installed new headlights in my old cars and they make quite a difference. I'm going to try upgrading the wire and see if that helps even more. It's cheap so I'll bite.
1969 Dodge Super Bee A12 (440 Six Pack, 4-speed, Dana 60 4.10)
1972 Plymouth Road Runner (400, 4-speed, 8.75" 3.23)
1974 Plymouth Duster 360 (360, 4-speed, 8.75" 3.23)
Re: Brighter headlights? [Re: dragaddict] #858384
11/20/10 10:39 AM
11/20/10 10:39 AM
Coram, NY
Pool Fixer Offline
Pool Fixer  Offline
Coram, NY
I did the Hella H4 upgrade to my 68 charger. For tails, I didn't like any of the pics that others posted of the bulb upgrades. I actually found a company that was selling 68 charger tailight lenses with LED's built in. I'll give you that when they are on, they don't even come come close to looking stock, but they are very bright. looking at them during non-lighting situations, can't tell the difference from stock.
You could definitely make something yourself by buying some sort of LED light assembly and fab it into your existing tailights. for a 68 charger, not that this helps a lot of people, go over to dodgecharger and look up a member norwaycharger. He has 68 LED's that look pretty stock when lit up, but they are very bright. they are about 400 bucks too so that's something to consider.
For the OP, listen to these guys. don't waste your time rigging projector headlight into your old car. The new car setups are engineered so the light source and the lens/housing work together. Unless you spent really cubic dollars, you will end up looking like a tool and not getting the most out of it. The Hella H4 housings will be "light" years ahead of stock and they will work properly without blinding other drivers.
Re: Brighter headlights? [Re: daniel_depetro] #858385
11/20/10 12:08 PM
11/20/10 12:08 PM
Space Station #5
471Magnum Offline
471Magnum  Offline
Space Station #5
This does nothing to remove the amp load from the HL switch which is another weak link. Switch failures are not uncommon. Adding amp load to 40 year old switch is asking for trouble. Relays are the way to go. Get the amp load off as much of that old wiring as possible.
Regarding tail lamps, LEDs are probably your best option for reducing the amp load.
-Jim
I can fix it... my old man is a television repairman.
He's got the ultimate set of tools... I can fix it.
Currently Mopar-less
Re: Brighter headlights? [Re: 471Magnum] #858386
11/20/10 12:30 PM
11/20/10 12:30 PM
Clean ALL connections esp the bulkhead. Better bulbs/use relays (imo feed the head lights from the alt side)/dont do anything that will increase the draw thru the bulkhead
Re: Brighter headlights? [Re: RapidRobert] #858387
11/20/10 12:52 PM
11/20/10 12:52 PM
Space Station #5
471Magnum Offline
471Magnum  Offline
Space Station #5
good point
-Jim
Re: Brighter headlights? [Re: 471Magnum] #858388
11/21/10 04:57 PM
11/21/10 04:57 PM
san diego
JonsGottaDusta Offline
san diego
I did the H4 upgrade with Xenon bulbs and its a world of a difference. You cannot even compare it to what was stock. I just built a wiring harness out of 12g wire with some relays and all is good. One of the best mods on my car.
Re: Brighter headlights? [Re: JonsGottaDusta] #858389
11/21/10 08:21 PM
11/21/10 08:21 PM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
I just ordered a pair of the Bosch headlight lens reflectors, a pair of Phillips Vision Plus bulbs and a nicely made 14 gauge headlight wiring harnesses from Suvlights.com
http://suvlights.com/index.php
I could have saved about $25 if I built my own harness, but with tax and shipping, the total for everything came to just over $152 and it's plug and play with very nice quality components.
Re: Brighter headlights? [Re: dragaddict] #858390
11/21/10 10:37 PM
11/21/10 10:37 PM
Colorado
denfireguy Offline
denfireguy  Offline
Colorado
You should use relays to control headlights but current draw is not the reason. (Hella H4s on high beams draw 30% less current than the tungsten bulbs the car came with.)
The reason is to use relays to shorten the high current path to the shortest length possible. This preserves switches, connectors and wiring. The lamps actually draw less current than the car's lights were designed to use.
4002 headlamp draws 8 amps on high. Hella H4 draws 5 amps.
Craig
Re: Brighter headlights? [Re: jbc426] #858391
11/21/10 11:24 PM
11/21/10 11:24 PM
albany ny
0
05dakota Offline
05dakota  Offline
albany ny
do that make a harness for use with stock bulbs?
Re: Brighter headlights? [Re: 05dakota] #858392
11/21/10 11:25 PM
11/21/10 11:25 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
It would be the same as the one for upgraded bulbs...
Re: Brighter headlights? [Re: 1_WILD_RT] #858393
11/21/10 11:27 PM
11/21/10 11:27 PM
albany ny
0
05dakota Offline
05dakota  Offline
albany ny
i went to that site and cant see what harness would work on a old mopar
Re: Brighter headlights? [Re: 05dakota] #858394
11/21/10 11:34 PM
11/21/10 11:34 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
I went there too & wasn't very impressed... If I could find the female socket connectors that would plug into the original headlight plugs I'd be inclined to build & market a properly designed drop in kit....
Actually I just went to Ebay & there are some that look reasonable..
Four light system...
http://cgi.ebay.com/ebaymotors/H4-Relay-...3#ht_1213wt_691
Two light system
http://cgi.ebay.com/ebaymotors/H4-Relay-..._Truck_Parts_Ac
Re: Brighter headlights? [Re: 1_WILD_RT] #858395
11/22/10 12:09 AM
11/22/10 12:09 AM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
Two light system
You're kidding right? Those ebay set-ups don't even come close to these US made ones from Suvlights. For only $5 more than the Chinese ones, take a look at the features on the Suvlights harnesses and compare then to the picture of Chinese ones you've listed.
Suvlights harness:
2 OEM Bosch/Tyco AMP (Potter & Brumfield) or equivalent 50 amp relays (single & dual 87 outputs)
Heavy Duty interlocking relay sockets with mounting tab
Fusible link (slow reacting fuse protection) & separate fuses (fast reacting) with 12 gauge heavy duty automotive wiring
Black split loom matches OEM to protect against heat and elements
Male connector(s) to plug into existing headlight socket
(2 or 4) new heat resistant headlight sockets (depending on application)
The Heavy Duty models are 14 gauge (can power a pair of 130 Watt bulbs) while the Super Heavy Duty model is 12 gauge and uses 4 relays.
Here's a pic of the ebay ones complete with 30 amp Chinese relays and yellow wire looms? Are they even fused?
Re: Brighter headlights? [Re: 05dakota] #858396
11/22/10 12:16 AM
11/22/10 12:16 AM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
I'm putting these parts on a 1970 Barracuda. Are you upgrading the headlights or just adding relays to the exsisting bulbs? Dual or quad headlights?
