Early A-body dual exhaust? #857820
11/19/10 12:21 PM
11/19/10 12:21 PM
Charlotte, NC
446acuda Offline OP
446acuda  Offline OP
Charlotte, NC
I'm just trying to get some ideas on how to run dual tailpipe on a '66-earlier A-body. Seems like space is limited because of the gas tank is moved over to one side unlike the later A-bodies. Post pics if you have them. thanks
Re: Early A-body dual exhaust? [Re: 446acuda] #857821
11/19/10 01:13 PM
11/19/10 01:13 PM
Auburn WA
Dave_J Offline
Dave_J  Offline
Auburn WA
They fit but are tight. You could have a 3" single made easer. It would flow about as good as a dual 2 1/4". The "Y" pipe would make or brake (Break) the flow. A factory "Y" is not good but a "FlowMaster" type is good.
Retired, US ARMY 1973-1994
ASE mechanic, Electrical 1994-1997
Retired GTE/VERIZON/FRONTIER 1997-2015
03 Suzuki Burgman 650(Burger King) Scooter
65 Formula S Cuda
78 Little Red Express Truck
98 Buick Regal (wifes car)
Re: Early A-body dual exhaust? [Re: 446acuda] #857822
11/19/10 05:57 PM
11/19/10 05:57 PM
Northern California
lilcuda Offline
lilcuda  Offline
Northern California
I have 2 1/4" duals on my 66 Barracuda. I only have pictures of the right side where it gets close to the tank.
'67 is an abbreviation of 1967
67' is an abbreviation of 67 feet
They are not interchangeable.
Re: Early A-body dual exhaust? [Re: lilcuda] #857823
11/19/10 05:58 PM
11/19/10 05:58 PM
Northern California
lilcuda Offline
lilcuda  Offline
Northern California
Here's another view.
Re: Early A-body dual exhaust? [Re: 446acuda] #857824
11/19/10 06:03 PM
11/19/10 06:03 PM
Ohio
Johnny Pace Offline
Johnny Pace  Offline
Ohio
there's really just not alot of room under these cars..if it were me i'd run dual flowmasters: 44's are the loudest down to 50 series being quietest. then dump the pipes out in front of the tires if you really want true duals, unless you want to fight with the fuel tank. i'd think an exhaust shop could probably squeeze them out the back though.
Re: Early A-body dual exhaust? [Re: Johnny Pace] #857825
11/19/10 08:46 PM
11/19/10 08:46 PM
Nampa, ID
None2Slow Offline
None2Slow  Offline
Nampa, ID
I have duals on my 63 Valiant Convert. It was tight and the shop had a hell of a time getting it past the tank. After the forth time, he got it. I am running flowmaster 40s I believe. Its all in 2 1/4". At some point I need to add headers to the car as the stock 273 manifolds just ain't gonna cut it with the 360 going in.
Re: Early A-body dual exhaust? [Re: 446acuda] #857826
11/19/10 09:40 PM
11/19/10 09:40 PM
A body gas tank straps went from side to side through 1967; straps changed to front-to-rear in 1968. The gas tank itself is in the same place, the frame rails are in the same place, springs are in the same place etc., etc.
I have stock Walker replacement tailpipes for a 68-up 340 on my 65 Barracuda (with 69 Barracuda tips). They fit like a glove. Unfortunately, the Walker pipes are NLA. But, basically, whatever will fit a later A will fit the early A, with a slight intrusion from the side-to-side strap which 67 A's also have. So tailpipes shouldn't be any harder to make for the early A's than for the later A's.
Re: Early A-body dual exhaust? #857827
11/23/10 02:15 PM
11/23/10 02:15 PM
Charlotte, NC
446acuda Offline OP
446acuda  Offline OP
Charlotte, NC
Thanks all! I should have looked under my '69 Barracuda before posting this question.
Re: Early A-body dual exhaust? [Re: 446acuda] #857828
11/23/10 03:04 PM
11/23/10 03:04 PM
Dayton, Ohio
65cuda Offline
mopar addict
65cuda  Offline
mopar addict
Dayton, Ohio
The early As had more room on one side of the tank because they only had single exhaust. so it is tight. but a good shop can bend around it. they also dont have the extra notch in the trans crossmember. i cut mine and welded it back in.
65 Cuda 360,3.23 SG-13.97 @99.4, 88 D100, 2000 Kota Qcab, 71 Duster 416 11.84 @110., 73 Imp ,(2)72 & (1)71 Dart Swingers
GarysMocars Legendary Dealer
Re: Early A-body dual exhaust? [Re: 65cuda] #857829
11/23/10 04:59 PM
11/23/10 04:59 PM
Charlotte, NC
446acuda Offline OP
446acuda  Offline OP
Charlotte, NC
I got the notch taken care and actually was going to let it go with the exhaust ending at the axle but the fumes are too bad inside the car so it definitely needs tailpipes. I was thinking about dumping it out the side before the rear wheels but the muffler outlet is too far back so that would be as much trouble as tailpipes.
Re: Early A-body dual exhaust? [Re: 446acuda] #857830
11/23/10 05:35 PM
11/23/10 05:35 PM
sweden
1Fast340 Offline
1Fast340  Offline
sweden
i dont think it would be that hard to get the pipes out in front of the rearwheels actualy,it depends alitle on how the mufflers are possitioned i have done a few brand x exhausts with the mufflers in the factorylocation, then added a 180degree bend out of the muffler pointing the exhaust forward again and then a 135degre bend to make it point out and back in front of the rearwheels, but it depends on if you have enough space betwen the front of the rear framerails and the muffler this wont work as good with subframeconectors but if they are not in the way its easy me i prefer exhaust all the way out the back, mostly since its slightly more challanging to build it that way
