Re: any one ever used safe -t-caps to cap a frame
[Re: dustpan man]
#857644
11/19/10 03:14 AM
11/19/10 03:14 AM
Posts: 3,106 Ridgeland Wi
mopars_1
Ridgeland Wi
they look like crap and fit horrible! waste of time and money if you ask me..
1971 Plymouth Duster 340 auto 1937 Plymouth PT50 1969 Dodge Dart Swinger 340 4 speed 2013 Ram laramie 2500 hemi 2008 Harley FLSTSB springer
[Re: dustpan man]
#857646
11/19/10 03:59 AM
11/19/10 03:59 AM
Posts: 357 Lake Elmo, MN
Evil Monkey
Lake Elmo, MN
I used an Auto Rust Technicians cap (I believe those are the Safe-T-Caps you are referring to) on the back half of the drivers front frame rail on my Cuda. It fit well and has held up fine for about 10 years now, and I have no complaints.
However, after getting the cap from them, I realized it was just 3 pieces of steel welded together to make the cap, and that it was something I could have fabricated myself for about 10 percent of what they charged. I have since made my own caps for the two rear spring hangers out of some steel stock that I had on hand, and they are easily as strong as anything someone could sell to me, but it did take some time to do the fabrication. If you have more time than money - make your own, but if you have more money than time - buy them pre made.
The K frame section of the frame might be something that you would want to buy, though - depends on your fabricating skills. I'm not sure if the caps are good for this area, or if you would be better off getting a new front frame rail, or a section of a frame rail to splice in. But if you're a good fabricator, I would think this section could be fabbed up also.
1974 'Cuda 360/TKO
1990 Ram Van
1998 Neon
[Re: Evil Monkey]
#857647
11/19/10 11:18 AM
11/19/10 11:18 AM
Posts: 3,318 Southern Maryland
klunick
Southern Maryland
Same here. Used Auto Rust Tech's caps and they are fine. Not a perfect fit but they are close. They are also 13 gauge steel which is slightly heavier than what the factory used. My bodyman tells me this car certainly isn't going to be twisting with these, the torque boxes, and frame conectors.
67 Barracuda FB
69 Superbee
"Southern Maryland: If you want a good looking woman, you had better bring her with you"
[Re: wmwalden]
#857649
11/19/10 02:40 PM
11/19/10 02:40 PM
klunick
Southern Maryland
That works as long as the area you are capping is flat. What you gonna do for the area over the axles? For me it was just easier to buy what I needed.
67 Barracuda FB
69 Superbee
[Re: Evil Monkey]
#857650
11/20/10 05:58 PM
11/20/10 05:58 PM
Posts: 2,675 Columbus Ga
reflections7
Columbus Ga
Same here I could have made it myself for 10 percent of what they charge. They work but that is all I will say.
