Switching to Synthetic Oil on Used Car? #857361
11/18/10 07:37 PM
11/18/10 07:37 PM
Highland, MI.
Sunroofcuda Offline OP
Highland, MI.
Would there be any downside to switching to synthetic oil on a 100,000 mile engine that has lived it's whole life on regular oil? Car is a 2001 300-M with the 3.5L. Will the synthetic oil "clean-up" the inside of the motor IF it is sludgy? (I'd bet the inside of this engine is very clean though as the car was meticulously maintained).
Re: Switching to Synthetic Oil on Used Car? [Re: Sunroofcuda] #857362
11/18/10 08:03 PM
11/18/10 08:03 PM
o'fallon, MO
Brian_E Offline
Brian_E  Offline
o'fallon, MO
from what i have gathered, synthetic is always superior to other oil. so no problem switching. hi mileage dictates better oil of same weight and viscosity as manufacturer recommends. Dont think it will clean up sludge, 100 k if maintained there would not be any sludge probably, u may think about a HD high detergent oil to clean engine out if proven to have buildup of sludge but ask dealer about this. My personal opinion.
Re: Switching to Synthetic Oil on Used Car? [Re: Sunroofcuda] #857363
11/18/10 09:15 PM
11/18/10 09:15 PM
Southern by Choice
Shoozy Offline
I have a foot fetish
Shoozy  Offline
Southern by Choice
Lube wise the synthetic is superior. A common problem switching to synthetic is a series of new weeps, seeps, and drips. Synthetic seems to find a way through older gaskets and seals more than conventional.
Old, tired, and sometimes broke down. Me, not my car...
Re: Switching to Synthetic Oil on Used Car? [Re: Sunroofcuda] #857364
11/19/10 12:19 AM
11/19/10 12:19 AM
SD
Z
zrxkawboy Offline
zrxkawboy  Offline
Z
SD
No problem to switch!
It's Swifty! Swifty, you toad sucker!
Re: Switching to Synthetic Oil on Used Car? [Re: Sunroofcuda] #857365
11/19/10 12:54 AM
11/19/10 12:54 AM
Vancouver, WA
MoparMarq Offline
MoparMarq  Offline
Vancouver, WA
Switched to Amsoil synthetic on 3 cars. Toyota Supra ('86.5)had 150K miles at the time of the switch, Acura Vigor ('92) one had 120K, the Durango '01 R/T) had about 60K. None of 'em leak or weep. The switch was 3 years ago. None gets more than 8K miles per year now. So I change the oil once a year on each. Last oil analysis on each showed no problems.
Changed the diff, trans, and txfr case oils to synthetic also. Won't go back to dino oil.
Re: Switching to Synthetic Oil on Used Car? [Re: MoparMarq] #857366
11/19/10 01:14 AM
11/19/10 01:14 AM
Highland, MI.
Highland, MI.
That's what I wanted to know guys - thanks. Switching to synthetic tomorrow & here's to another 150k miles! My wife & I like this car better than our 2007 Charger, & we love the Charger.............
Re: Switching to Synthetic Oil on Used Car? [Re: Sunroofcuda] #857367
11/19/10 01:15 PM
11/19/10 01:15 PM
NW Indiana
deansrr Offline
deansrr  Offline
NW Indiana
I recommend Valvoline Maxlife
1973 Road Runner 1974 Satellite (for sale) 1973 240z (wifes) 1993 Ramcharger (thanks Devil) 2002 Honda S2000
Re: Switching to Synthetic Oil on Used Car? [Re: Shoozy] #857368
11/20/10 08:02 AM
11/20/10 08:02 AM
Sterling Heights, Michigan 483...
daniel_depetro Offline
I don't think weeps, seeps, and drips are common side effects from switching to synthetic oil.
If one does discover a new leak I'd bet it's from the superior cleaning detergents in the synthetic oil removing the sludge of dino oil that is built up in the "corners" thus possibly exposing a leak that was already there but plugged. No, not butt plug!
When you guys switch to synthetics are you adding zddp additives?
I've switched everything I own (Air compressor, motorcycle(s), car(s), truck(s), ...) over to synthetic oils in all drivetrain components (engine, transmission, rear axle).
I personally never had any issues yet, never had any leaks form.
1969 Dodge Super Bee A12 (440 Six Pack, 4-speed, Dana 60 4.10)
1972 Plymouth Road Runner (400, 4-speed, 8.75" 3.23)
1974 Plymouth Duster 360 (360, 4-speed, 8.75" 3.23)
Re: Switching to Synthetic Oil on Used Car? [Re: daniel_depetro] #857369
11/20/10 08:22 AM
11/20/10 08:22 AM
Pacific NW USA
CompSyn Offline
CompSyn  Offline
Pacific NW USA
Good points!
On a side note, there are some synthetics with loads of ZDDP already blended in for well balanced finished product.
Avoid added cost and efforts with aftermarket oil additives and apply those funds to a well balanced finished motor oil product.
