switching to powerglide or th400 questions?
#856369
11/17/10 10:34 PM
11/17/10 10:34 PM
Posts: 761 KY
juicedcuda
KY
When switching to these transmissions behind a BB mopar, obviously you have to switch to a jw bell housing, shifter, flex plate for 8 bolt crank to convertor, driveshaft yoke. Will my starter work with the thicker bell housing? Can I use my 727 convertor, just have it modified for PG/th400?
Anything else I am missing?
1970 Plymouth 'Cuda
1970 Plum Crazy "Gold Duster"
1973 Gold Duster
Re: switching to powerglide or th400 questions?
[Re: juicedcuda]
#856370
11/17/10 10:39 PM
11/17/10 10:39 PM
Posts: 3,502 SOUTH JERSEY
HEMIFRED
SOUTH JERSEY
converter GM to match trans need a flywheel w/ 130 tooth starter should fit
I use GM trans case with adapter plate
home of the Sox and Martin Hemi Duster
[Re: juicedcuda]
#856372
11/17/10 11:08 PM
11/17/10 11:08 PM
Posts: 1,608 Rudolph, Ohio
moparguy7074
Rudolph, Ohio
The fact that I have one for sale!
[Re: moparguy7074]
#856373
11/17/10 11:38 PM
11/17/10 11:38 PM
Posts: 4,590 Indy
joshking440
Lunch is on me!
Lunch is on me!
Indy
[Re: sam64]
#856375
11/18/10 12:39 AM
11/18/10 12:39 AM
Posts: 2,646 Plymouth Meeting, PA
bigtimeauto
Trophy Winner
Trophy Winner
the best part of the conversion beside the transmission is the deeper bell housing for better converters. I use a JW bell on my turbo 400.
BB, TT5,Procharged 3300lb Street Car 4.79/154
[Re: juicedcuda]
#856376
11/18/10 12:41 AM
11/18/10 12:41 AM
Posts: 3,437 Dandridge TN
Dabee
Dandridge TN
The stock starter will work, but you need to shim it to get the proper starter engagement. If you buy a new ultrabell a shim kit comes with the ultrabell. If you buy used just, call JW and order the shim kit.
