switching to powerglide or th400 questions? #856369
11/17/10 10:34 PM
11/17/10 10:34 PM
KY
juicedcuda Offline OP
KY
When switching to these transmissions behind a BB mopar, obviously you have to switch to a jw bell housing, shifter, flex plate for 8 bolt crank to convertor, driveshaft yoke. Will my starter work with the thicker bell housing? Can I use my 727 convertor, just have it modified for PG/th400?
Anything else I am missing?
1970 Plymouth 'Cuda 1970 Plum Crazy "Gold Duster" 1973 Gold Duster
Re: switching to powerglide or th400 questions? [Re: juicedcuda] #856370
11/17/10 10:39 PM
11/17/10 10:39 PM
SOUTH JERSEY
HEMIFRED Offline
HEMIFRED  Offline
SOUTH JERSEY
converter GM to match trans
need a flywheel w/ 130 tooth
starter should fit
I use GM trans case with adapter plate
home of the
Sox and Martin Hemi Duster
Re: switching to powerglide or th400 questions? [Re: HEMIFRED] #856371
11/17/10 10:44 PM
11/17/10 10:44 PM
okla.
sam64 Offline
sam64  Offline
okla.
the j&w bell uses factory starter location.you'll be gettin a new drive shaft too.
Re: switching to powerglide or th400 questions? [Re: juicedcuda] #856372
11/17/10 11:08 PM
11/17/10 11:08 PM
Rudolph, Ohio
moparguy7074 Offline
Rudolph, Ohio
The fact that I have one for sale!
Re: switching to powerglide or th400 questions? [Re: moparguy7074] #856373
11/17/10 11:38 PM
11/17/10 11:38 PM
Indy
joshking440 Offline
Lunch is on me!
joshking440  Offline
Lunch is on me!
Indy
dont do it!!!!!!!!!!!!!!
Re: switching to powerglide or th400 questions? [Re: joshking440] #856374
11/17/10 11:49 PM
11/17/10 11:49 PM
okla.
sam64 Offline
sam64  Offline
okla.
reason being what?also there is one for 8 bolt on rj.
Re: switching to powerglide or th400 questions? [Re: sam64] #856375
11/18/10 12:39 AM
11/18/10 12:39 AM
Plymouth Meeting, PA
bigtimeauto Offline
Trophy Winner
bigtimeauto  Offline
Trophy Winner
the best part of the conversion beside the transmission is the deeper bell housing for better converters.
I use a JW bell on my turbo 400.
BB, TT5,Procharged 3300lb Street Car 4.79/154
Re: switching to powerglide or th400 questions? [Re: juicedcuda] #856376
11/18/10 12:41 AM
11/18/10 12:41 AM
Dandridge TN
Dabee Online content
Dabee  Online Content
Dandridge TN
The stock starter will work, but you need to shim it to get the proper starter engagement. If you buy a new ultrabell a shim kit comes with the ultrabell. If you buy used just, call JW and order the shim kit.
Re: switching to powerglide or th400 questions? [Re: Dabee] #856377
11/18/10 09:00 AM
11/18/10 09:00 AM
North Sweden
RT540 Offline
RT540  Offline
North Sweden
Good info, I have a brand new Bell+ultracase and havenīt tried to fit the starter yet, but as I am in sweden, I will handmade my own shims for the starter. The shipping will cost more than the kit itself.
Tom
Re: switching to powerglide or th400 questions? [Re: RT540] #856378
11/18/10 01:32 PM
11/18/10 01:32 PM
okla.
sam64 Offline
sam64  Offline
okla.
i have both big and small block ones,used starters for 97 dodge pickup 5.2,no shims required on either one.
