68 HEMI Charger wheels and hubcaps wanted #855403
11/16/10 05:12 PM
11/16/10 05:12 PM
CA
P
Packardtom Offline OP
P
CA
I'm looking for a set of wheels and hubcaps for a '68 HEMI Charger and I have a block casting question: what's the difference between 2 identical blocks: the casting dates are exactly the same and the casting numbers are the same but one ends with a 1 and the other ends with a 2. many thanks, Tom
Re: 68 HEMI Charger wheels and hubcaps wanted [Re: Packardtom] #855404
11/16/10 05:18 PM
11/16/10 05:18 PM
Long Island, NY
shakerjoe Offline
shakerjoe  Offline
Long Island, NY
the shift that the block was cast on afaik
Re: 68 HEMI Charger wheels and hubcaps wanted [Re: shakerjoe] #855405
11/16/10 06:16 PM
11/16/10 06:16 PM
CA
P
P
CA
I thought the D N pointer and the clock dots covered that. many thanks. new to this, sorry, what's afaik ?
Re: 68 HEMI Charger wheels and hubcaps wanted [Re: Packardtom] #855406
11/16/10 06:28 PM
11/16/10 06:28 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
AFAIK is As Far As I Know.. But your correct D/N & the pointer covered day & night shift... But -1 -2 -3 covered how many rebuilds of the sand casting core had been done at the time the block was cast..
Re: 68 HEMI Charger wheels and hubcaps wanted [Re: 1_WILD_RT] #855407
11/16/10 06:53 PM
11/16/10 06:53 PM
CA
P
P
CA
OIC...makes sense. many thanks
Re: 68 HEMI Charger wheels and hubcaps wanted [Re: Packardtom] #855408
11/16/10 07:55 PM
11/16/10 07:55 PM
phx, az.
J code Chargers Offline
phx, az.
68 Hemi Chargers had two different hubcap options depending on what kind of brakes the car came with(generally speaking). Drums had the small dog-bowls and Power Disks had the full size turbine type wheel cover. Which do you need?
Re: 68 HEMI Charger wheels and hubcaps wanted [Re: J code Chargers] #855409
11/16/10 08:10 PM
11/16/10 08:10 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
^ not exactly
The STANDARD "hub cap" on the '68 Charger regardless of any option was part number 2768 007:
Re: 68 HEMI Charger wheels and hubcaps wanted [Re: J code Chargers] #855410
11/16/10 08:11 PM
11/16/10 08:11 PM
CA
P
P
CA
this is a drum brake car and I'm looking for Dog Pans. that's the info I have: this is the hubcap, if it's a HEMI
Re: 68 HEMI Charger wheels and hubcaps wanted [Re: 6bblgt] #855411
11/16/10 08:15 PM
11/16/10 08:15 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
The only OPTIONAL "wheel cover" at $24.60 (OPTION code 581 - "DELUXE" wheel covers) on a HEMI equipped R/T was part number 2881 753:
Re: 68 HEMI Charger wheels and hubcaps wanted [Re: Packardtom] #855412
11/17/10 11:13 AM
11/17/10 11:13 AM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
That's the hubcap whether it had a hemi or not .
Re: 68 HEMI Charger wheels and hubcaps wanted [Re: JohnRR] #855413
11/17/10 12:04 PM
11/17/10 12:04 PM
sw chicago
RAH Offline
RAH  Offline
sw chicago
I am the owner of a 1968 hemi charger. Gold auto. the original wheels are 15X6 jk stamped. car came with small pie pan or 15 inch full wheel cover. If you need more info call me at 708 687 1187
Re: 68 HEMI Charger wheels and hubcaps wanted [Re: 6bblgt] #855414
11/17/10 02:59 PM
11/17/10 02:59 PM
Jefferson State
srt Offline
ESYC
srt  Offline
ESYC
Jefferson State
Can anyone verify if there were two different heights of these hubcaps? I've heard that the 14" caps were shorter than the 15".
I agree that the 15" (dog dish) hub cap was standard on the disc equipped hemi's in 68.
The full wheel cover was the sole option (and one could not get 15" chrome steel road wheels on mopars in 68).
Re: 68 HEMI Charger wheels and hubcaps wanted [Re: 1_WILD_RT] #855415
11/17/10 03:37 PM
11/17/10 03:37 PM
Long Island, NY
shakerjoe Offline
shakerjoe  Offline
Long Island, NY
thanks RT for the explanation - forgot about the D N -
