Attention all head porters!!!! #855025
11/16/10 04:33 AM
11/16/10 04:33 AM
West Coast, CA
Troy Offline OP
Troy  Offline OP
West Coast, CA
Hi guys, hope all is well.
I have a question for you all. What grit of sanding scrolls do you use for shaping a port and what do you use for the final "lets make it look pretty."
I have been porting heads for many years with some good results but when I'm done they just don't have that professional look like the pros get. What should I use???
Thanks!!
....there is nothing like driving my 1968 Hemi Dart around town and having people looking at you like you're nuts!!
Re: Attention all head porters!!!! [Re: Troy] #855026
11/16/10 05:01 AM
11/16/10 05:01 AM
Florida STAYcation
dOoC Offline
The village idiot's idiot
dOoC  Offline
Florida STAYcation
It has been a loooong time since I have done any serious port work .. but I remember a tan-ish colored almost like hard rubber mostly in an 1/8" shank.
It would make the exh port LIKE a mirror.
Re: Attention all head porters!!!! [Re: Troy] #855027
11/16/10 06:18 AM
11/16/10 06:18 AM
On the south side of Nowhere
S/ST 3040 Offline
S/ST 3040  Offline
60 grit, low RPM........but, completely unnecessary for flow/HP
Re: Attention all head porters!!!! [Re: Troy] #855028
11/16/10 09:11 AM
11/16/10 09:11 AM
Down South
DaKuda Offline
DaKuda  Offline
Down South
Thanks!!
The port on the left looks pretty good to me..
Re: Attention all head porters!!!! [Re: Troy] #855029
11/16/10 09:56 AM
11/16/10 09:56 AM
nc
moeflo Offline
moeflo  Offline
nc
There's an old wives tale about other peoples cooking always tasting better than their own. You're concentrating on the spots you aren't happy with. Another observer doesn't look at your work that way. I'd bet if you saw your own work a couple of years later and not realizing you did it, you'd wish yours looked that good.
Re: Attention all head porters!!!! [Re: moeflo] #855030
11/16/10 10:53 AM
11/16/10 10:53 AM
Ontario, Canada
Stanton Online content
Don't question me!
Stanton  Online Content
Don't question me!
Ontario, Canada
I'm not a pro welder but I make a product that I regularly display and sell at swapmeets - unpainted. Every one I make I find faults with my welding but when I get to the shows I get loads of compliments on the quality of the welding, many from welder-fabricators and I've also had numerous job offers. Yes, often we're just too critical of our own work - its a sign of pride!
Re: Attention all head porters!!!! [Re: Troy] #855031
11/16/10 12:04 PM
11/16/10 12:04 PM
Syracuse,NY
CompWedgeEngines Offline
Syracuse,NY
The problem with porting, is people WANT to see " pretty" when its done. Its usually finished much nicer than it has to be, because people want it all glamorous. Typically you have to spend an extra hour beautifying the porting jobs.
Whats funny, and you see it all over the internet is when people say: " that porting looks killer dude" and so forth. How can someone look at a picture of a port job and know that its done right? How does it flow, where does it flow, hows the low numbers, whats the velocity and so forth. Its just like the flow numbers game. People WANT big flow numbers. It sells product. People WANT pretty port jobs, its makes the customer happy.
Again , there is a lot more to it than smooth looking ports.
My
RIP Monte Smith
Re: Attention all head porters!!!! [Re: Stanton] #855032
11/16/10 12:07 PM
11/16/10 12:07 PM
West Coast, CA
Troy Offline OP
Troy  Offline OP
West Coast, CA
That is some good advice, thank you very much.
These are some small block Edelbrock heads that I'm doing for a fried but I also have a set of aluminum Hemi heads that I will be doing for myself. I'm just trying to bring them up to the next level.
Anybody else??
Re: Attention all head porters!!!! [Re: Troy] #855033
11/16/10 12:48 PM
11/16/10 12:48 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Anybody else??
Are you displaying the heads with intake and exhuast manifolds off with mirrors and lights ???
just asking ...
Re: Attention all head porters!!!! [Re: JohnRR] #855034
11/16/10 11:18 PM
11/16/10 11:18 PM
West Coast, CA
Troy Offline OP
Troy  Offline OP
West Coast, CA
Hi John....no light will be used, LOL!!!
As I said before, I'm just trying to get to the "next level" in my porting jobs. I have flowed many of my heads after I have messed with them and have come up with some good numbers so I know I,m on the right track.
I wonder if people use a flapper wheel, a Scott Bright type wheel or ????
Re: Attention all head porters!!!! [Re: Troy] #855035
11/17/10 12:21 AM
11/17/10 12:21 AM
GoDartGo Offline
GoDartGo  Offline
I remember the first set of BB heads I ported.
I'd just used the carbide burr,no finish work,and took
them in to get the guides done. When I get there to
pick them up, the guys says "who ported your heads?"
I almost told him I bought them that way, knowing this
guy knew what a good port job was suppose to look like.
But took a deep breath and said that I did them.
He says, "you did a good job on them" I about fell over.
Re: Attention all head porters!!!! [Re: GoDartGo] #855036
11/17/10 09:45 PM
11/17/10 09:45 PM
Indy
Mike Stark CFM Offline
Indy
I finish the chambers and EX ports with a 120 grit roll. The intake ports get finished with a 60 grit roll. This texture helps to keep the fuel in suspension by creating a boundry layer of pressure near the walls. If fuel touches the walls it will puddle and fall out of suspension. Keep the port with fuel rough and make the rest look all pretty for your customers.
Re: Attention all head porters!!!! [Re: Mike Stark CFM] #855037
11/18/10 02:01 AM
11/18/10 02:01 AM
Mopar Country, Mi
ccdave Offline
The Ultimate
ccdave  Offline
The Ultimate
Mopar Country, Mi
Re: Attention all head porters!!!! [Re: ccdave] #855038
11/18/10 02:31 AM
11/18/10 02:31 AM
West Coast, CA
Troy Offline OP
Troy  Offline OP
West Coast, CA
That is the info that I'm looking for!!
Do you use a larger diameter roll....1/2" or do you like the smaller rolls like the 1/4" ones??
Re: Attention all head porters!!!! [Re: Troy] #855039
11/18/10 01:38 PM
11/18/10 01:38 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I use a few different diameters so they fit the radius
at different points... 120 on the intakes and I go a
bit smoother on the exhaust
Re: Attention all head porters!!!! [Re: MR_P_BODY] #855040
11/18/10 11:49 PM
11/18/10 11:49 PM
West Coast, CA
Troy Offline OP
Troy  Offline OP
West Coast, CA
Thank you guys for all he useful information.
Todd, thank you for the PM. I wanted to pm you back but your mailbox is full.
Anybody else??
Re: Attention all head porters!!!! [Re: Troy] #855041
11/19/10 12:03 AM
11/19/10 12:03 AM
Syracuse,NY
Syracuse,NY
No problem Troy....fixed the PMs as well..thanks!
RIP Monte Smith
Re: Attention all head porters!!!! [Re: Mike Stark CFM] #855042
11/19/10 11:31 AM
11/19/10 11:31 AM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
That's basically what I do, too. If an 80 gets the desired results w/ the exhaust, I don't bother going to the 120, though.
My rolls are a mix of straight & tapered 3/8" and 1/2", depending on the grit and contours I'm working with.
