Attention all head porters!!!!
#855025
11/16/10 04:33 AM
11/16/10 04:33 AM
Posts: 3,957 West Coast, CA
Troy
West Coast, CA
Hi guys, hope all is well.
I have a question for you all. What grit of sanding scrolls do you use for shaping a port and what do you use for the final "lets make it look pretty."
I have been porting heads for many years with some good results but when I'm done they just don't have that professional look like the pros get. What should I use???
Thanks!!
....there is nothing like driving my 1968 Hemi Dart around town and having people looking at you like you're nuts!!
Re: Attention all head porters!!!!
[Re: Troy]
#855028
11/16/10 09:11 AM
11/16/10 09:11 AM
Posts: 1,015 Down South
DaKuda
Down South
Thanks!!
The port on the left looks pretty good to me..
[Re: Troy]
#855031
11/16/10 12:04 PM
11/16/10 12:04 PM
Posts: 3,544 Syracuse,NY
CompWedgeEngines
Syracuse,NY
The problem with porting, is people WANT to see " pretty" when its done. Its usually finished much nicer than it has to be, because people want it all glamorous. Typically you have to spend an extra hour beautifying the porting jobs. Whats funny, and you see it all over the internet is when people say: " that porting looks killer dude" and so forth. How can someone look at a picture of a port job and know that its done right? How does it flow, where does it flow, hows the low numbers, whats the velocity and so forth. Its just like the flow numbers game. People WANT big flow numbers. It sells product. People WANT pretty port jobs, its makes the customer happy. Again , there is a lot more to it than smooth looking ports. My
RIP Monte Smith
[Re: Stanton]
#855032
11/16/10 12:07 PM
11/16/10 12:07 PM
Troy
West Coast, CA
That is some good advice, thank you very much.
These are some small block Edelbrock heads that I'm doing for a fried but I also have a set of aluminum Hemi heads that I will be doing for myself. I'm just trying to bring them up to the next level.
Anybody else??
[Re: Troy]
#855033
11/16/10 12:48 PM
11/16/10 12:48 PM
Posts: 75,051 U.S.S.A.
JohnRR
U.S.S.A.
Anybody else??
Are you displaying the heads with intake and exhuast manifolds off with mirrors and lights ???
just asking ...
[Re: JohnRR]
#855034
11/16/10 11:18 PM
11/16/10 11:18 PM
Troy
West Coast, CA
Hi John....no light will be used, LOL!!!
As I said before, I'm just trying to get to the "next level" in my porting jobs. I have flowed many of my heads after I have messed with them and have come up with some good numbers so I know I,m on the right track.
I wonder if people use a flapper wheel, a Scott Bright type wheel or ????
[Re: Mike Stark CFM]
#855037
11/18/10 02:01 AM
11/18/10 02:01 AM
Posts: 1,807 Mopar Country, Mi
ccdave
The Ultimate
The Ultimate
Mopar Country, Mi
I finish the chambers and EX ports with a 120 grit roll. The intake ports get finished with a 60 grit roll. This texture helps to keep the fuel in suspension by creating a boundry layer of pressure near the walls. If fuel touches the walls it will puddle and fall out of suspension. Keep the port with fuel rough and make the rest look all pretty for your customers.
[Re: ccdave]
#855038
11/18/10 02:31 AM
11/18/10 02:31 AM
Troy
West Coast, CA
That is the info that I'm looking for!!
Do you use a larger diameter roll....1/2" or do you like the smaller rolls like the 1/4" ones??
[Re: Troy]
#855039
11/18/10 01:38 PM
11/18/10 01:38 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I use a few different diameters so they fit the radius at different points... 120 on the intakes and I go a bit smoother on the exhaust
[Re: MR_P_BODY]
#855040
11/18/10 11:49 PM
11/18/10 11:49 PM
Troy
West Coast, CA
Thank you guys for all he useful information. Todd, thank you for the PM. I wanted to pm you back but your mailbox is full. Anybody else??
[Re: Troy]
#855041
11/19/10 12:03 AM
11/19/10 12:03 AM
CompWedgeEngines
Syracuse,NY
No problem Troy....fixed the PMs as well..thanks!
RIP Monte Smith
#855042
11/19/10 11:31 AM
11/19/10 11:31 AM
BradH
That's basically what I do, too. If an 80 gets the desired results w/ the exhaust, I don't bother going to the 120, though.
My rolls are a mix of straight & tapered 3/8" and 1/2", depending on the grit and contours I'm working with.
