2000 Intrepid why is it pinging so bad?
#854076
11/15/10 01:08 AM
11/15/10 01:08 AM
Posts: 469 In a van, down by the river
jmf340
I know the new gas is crap, but does it make that much difference? 2000 Intrepid R/T 3.5 107K I run synthetic 10w30 and have upgraded to Shell 93 with no improvement. I was under the impression that the 'brand' gasolines have additives to help with crappy gas. Also, shouldn't the computer compensate for detonation or a lean condition?
Got Mopar???
Re: 2000 Intrepid why is it pinging so bad?
[Re: maxi426]
#854083
11/19/10 10:14 AM
11/19/10 10:14 AM
Posts: 905 SD
zrxkawboy
SD
Knock sensor was my first thought, and EGR is also possible. You mentioned switching to Shell 93. If you had been running cheap gas for a long time, you could easily have the deposits that others have mentioned. I've heard good things about Mopar Combustion Chamber Cleaner, but have not used it personally.
It's Swifty! Swifty, you toad sucker!
[Re: zrxkawboy]
#854084
11/20/10 03:25 PM
11/20/10 03:25 PM
jmf340
I like the Seafoam idea, but where can I locate a vacuum line that feeds the intake? There is a place where I can put in between the throttle plate and the intake. Will that work?
Got Mopar???
[Re: jmf340]
#854086
11/21/10 02:09 AM
11/21/10 02:09 AM
Posts: 1,371 Costa Mesa, CA
chache876
Costa Mesa, CA
Would the knock sensor or EGR turn on the 'check engine' light? Mine is not on and there are no codes stored or pending.
the egr tube can get clogged, but the actual valve will still open and close so that it won't set off a CEL
