2000 Intrepid why is it pinging so bad? #854076
11/15/10 01:08 AM
11/15/10 01:08 AM
In a van, down by the river
jmf340 Offline OP
jmf340  Offline OP
I know the new gas is crap, but does it make that much difference? 2000 Intrepid R/T 3.5 107K
I run synthetic 10w30 and have upgraded to Shell 93 with no improvement. I was under the impression that the 'brand' gasolines have additives to help with crappy gas. Also, shouldn't the computer compensate for detonation or a lean condition?
Got Mopar???
Re: 2000 Intrepid why is it pinging so bad? [Re: jmf340] #854077
11/15/10 01:30 AM
11/15/10 01:30 AM
Bama
Randy.. Offline
Randy..  Offline
Bama
Knock sensor may be bunk.
Re: 2000 Intrepid why is it pinging so bad? [Re: Randy..] #854078
11/15/10 04:02 AM
11/15/10 04:02 AM
Costa Mesa, CA
chache876 Offline
chache876  Offline
Costa Mesa, CA
egr could be stuck open too
Re: 2000 Intrepid why is it pinging so bad? [Re: chache876] #854079
11/15/10 01:47 PM
11/15/10 01:47 PM
md
mopars4ever Online content
mopars4ever  Online Content
md
Try some Techron fuel additive in the next couple tanks of gas. I used a little Mopar combustion chamber cleaner down the intake and the techron in the gas and it got rid of my pinging on my non mopar.
Re: 2000 Intrepid why is it pinging so bad? [Re: mopars4ever] #854080
11/15/10 06:34 PM
11/15/10 06:34 PM
jmf340 Offline OP
jmf340  Offline OP
Would the knock sensor or EGR turn on the 'check engine' light? Mine is not on and there are no codes stored or pending.
Got Mopar???
Re: 2000 Intrepid why is it pinging so bad? [Re: jmf340] #854081
11/15/10 08:57 PM
11/15/10 08:57 PM
PA
70Duster Offline
70Duster  Offline
PA
With no codes or CEL, I'd think possibly excessive carbon build-up. I'd try Seafoam or plain water added very slowly through a vacuum line. Don't add too fast or you risk hydro-lock.
Re: 2000 Intrepid why is it pinging so bad? [Re: 70Duster] #854082
11/19/10 09:51 AM
11/19/10 09:51 AM
Western NY
maxi426 Offline
maxi426  Offline
Western NY
If it pings at mid throttle but not when wide open, I'd look at EGR not working.
Re: 2000 Intrepid why is it pinging so bad? [Re: maxi426] #854083
11/19/10 10:14 AM
11/19/10 10:14 AM
SD
Z
zrxkawboy Offline
zrxkawboy  Offline
Z
SD
Knock sensor was my first thought, and EGR is also possible. You mentioned switching to Shell 93. If you had been running cheap gas for a long time, you could easily have the deposits that others have mentioned. I've heard good things about Mopar Combustion Chamber Cleaner, but have not used it personally.
It's Swifty! Swifty, you toad sucker!
Re: 2000 Intrepid why is it pinging so bad? [Re: zrxkawboy] #854084
11/20/10 03:25 PM
11/20/10 03:25 PM
jmf340 Offline OP
jmf340  Offline OP
I like the Seafoam idea, but where can I locate a vacuum line that feeds the intake? There is a place where I can put in between the throttle plate and the intake. Will that work?
Got Mopar???
Re: 2000 Intrepid why is it pinging so bad? [Re: jmf340] #854085
11/20/10 09:08 PM
11/20/10 09:08 PM
PA
70Duster Offline
70Duster  Offline
PA
If there's a vacuum line in between the throttle plate and the intake that should work. Also maybe you could use the vacuum line to the brake booster.
Re: 2000 Intrepid why is it pinging so bad? [Re: jmf340] #854086
11/21/10 02:09 AM
11/21/10 02:09 AM
Costa Mesa, CA
chache876 Offline
chache876  Offline
Costa Mesa, CA
the egr tube can get clogged, but the actual valve will still open and close so that it won't set off a CEL
