rubber insulators front suspension #853611
11/14/10 09:34 PM
11/14/10 09:34 PM
michigan
black64 Offline OP
black64  Offline OP
michigan
Any source for the rubber insulators for the pitman arm and the idler arm? Checked out pst, just suspension, and moog they have the whole assembly but no rubber washers sold individually.
Re: rubber insulators front suspension [Re: black64] #853612
11/15/10 11:37 AM
11/15/10 11:37 AM
Gilbertsville, PA 19525
P
Pntastar69 Offline
Pntastar69  Offline
P
Check energy suspension.
Re: rubber insulators front suspension [Re: black64] #853613
11/15/10 02:35 PM
11/15/10 02:35 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
do you mean the grease boots ?
Re: rubber insulators front suspension [Re: JohnRR] #853614
11/15/10 02:56 PM
11/15/10 02:56 PM
michigan
black64 Offline OP
black64  Offline OP
michigan
Yeah, they fit between the idler arm and drag link and between the pitman arm and drag link.
Re: rubber insulators front suspension [Re: JohnRR] #853615
11/15/10 02:57 PM
11/15/10 02:57 PM
IMGTX Online content
IMGTX  Online Content
That's what I was wondering too.
Auto Zone sells the lip type in Silicone from Energy suspension or plain rubber lip seals in the help section. The balloon type I don't know of anyone that sells those.
Re: rubber insulators front suspension [Re: IMGTX] #853616
11/15/10 03:48 PM
11/15/10 03:48 PM
michigan
black64 Offline OP
black64  Offline OP
michigan
They are the grease boots and are flat not balooned. picture attached
Re: rubber insulators front suspension [Re: black64] #853617
11/15/10 03:59 PM
11/15/10 03:59 PM
Those are just foam rubber washers. If you can find grease resistant foam you can make them but you can use the lip seals in place of them with no problems. They just keep the water and dirt out.
I like the ballon seals better but we get what we get.
Re: rubber insulators front suspension [Re: black64] #853618
11/15/10 04:12 PM
11/15/10 04:12 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Is that a factory picture you attached ? I have only seen that type with an aftermarket moog idler arm and not on a pitman arm. Chrysler also sells the boots separately , but I don't think they are like those in the picture you attached.
Re: rubber insulators front suspension [Re: JohnRR] #853619
11/15/10 08:19 PM
11/15/10 08:19 PM
michigan
black64 Offline OP
black64  Offline OP
michigan
The pic is from the moog site. The old ones on my car look like that.
Re: rubber insulators front suspension [Re: black64] #853620
11/15/10 09:01 PM
11/15/10 09:01 PM
IN
ahy Offline
ahy  Offline
IN
I've always had the felt "washer" but I wouldn't hesitate to put a parts store rubber boot in there instead... assuming its not a concours resto.
Re: rubber insulators front suspension [Re: ahy] #853621
11/15/10 11:00 PM
11/15/10 11:00 PM
michigan
black64 Offline OP
black64  Offline OP
michigan
I will try the part stores to see but they do not seem to be able to find jack if it is not on the computer if you get my meaning. The days of walking in the auto parts store with an old part and the guy knowing what will work are gone. But, it never hurts to try.
Re: rubber insulators front suspension [Re: black64] #853622
11/15/10 11:38 PM
11/15/10 11:38 PM
Re: rubber insulators front suspension [Re: black64] #853623
11/15/10 11:39 PM
11/15/10 11:39 PM
IN
ahy Offline
ahy  Offline
IN
Look in the "help" section or ask for tie rod boots.
Re: rubber insulators front suspension [Re: ahy] #853624
11/16/10 02:10 PM
11/16/10 02:10 PM
michigan
black64 Offline OP
black64  Offline OP
michigan
thanks all for the info.
