sealer in cooling system #852426
11/13/10 09:42 AM
11/13/10 09:42 AM
Annapolis, Missouri USA
CIB Offline OP
CIB  Offline OP
after pulling my 440 several times last winter to stop rear main seal leak, I noticed some sealer getting pushed into heads thru exhaust bolts. I started to have high temp probems this summer.Replaced water pump and thermostat,still running higher temps than normal. Where could the pieces of sealer be stopping up cooling system?
Re: sealer in cooling system [Re: CIB] #852427
11/13/10 09:50 AM
11/13/10 09:50 AM
Niles , Ohio
therocks Online content
therocks  Online Content
Niles , Ohio
I use anti sieze on the exhaust bolts and never had a leak.Try pulling the 2 plugs on the bottom front of the block and see what comes out.You cant believe how much gunk gets built up down there.Most plugs Ive pulled water wont even come out till you get the crud out of the hole.Rocky
Chrysler Firepower
Re: sealer in cooling system [Re: therocks] #852428
11/13/10 10:33 AM
11/13/10 10:33 AM
Upper Midwest
MoparforLife Offline
Upper Midwest
The dirt and crud behind the soft plugs is really what rusts them out - not the coolant moving past them. Most of the time when you pull them the mud is way up on the freeze plugs. The truly best way to flush an engine is to pop all the plugs out. Just flushing with moving water will not get most of this out.
Re: sealer in cooling system [Re: CIB] #852429
11/13/10 10:45 AM
11/13/10 10:45 AM
More info, started getting hotter all of a sudden or gradually this summer. How hot? around town/idleing or out on the highway? Have a shroud? rad marginal? any other driveability probs when it started happening
Re: sealer in cooling system [Re: MoparforLife] #852430
11/13/10 01:20 PM
11/13/10 01:20 PM
CIB Offline OP
CIB  Offline OP
Started this summer early. Has original gauge in 65 belvedere. In past never got above 1/4 on gauge,Now gets gradually warmer highway driving. In town or idleing moves up past halfway to about 3/4. Has shroud, Car had dealer installed air and has bigger radiator for air conditioning. All started after sealer got into cooling system from exhaust bolts. After pulling engine several times to get rear main seal from leaking. I also replaced water pump and thermostat, no change. I believe there were pieces of sealer about the size of the head of a pencil that got into system. I wonder if they would be pluggingthe cooling sysem anywhere.
Re: sealer in cooling system [Re: CIB] #852431
11/13/10 05:10 PM
11/13/10 05:10 PM
Niles , Ohio
Niles , Ohio
Unless they are a few thousand floating in there I doubt they can plug anything up.They would all have to be in one spot pretty much.Pull the plugs on the block and do a good back flush there and on the rad.Rocky
Chrysler Firepower
Re: sealer in cooling system [Re: therocks] #852432
11/13/10 06:29 PM
11/13/10 06:29 PM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
It doesn't take much to plug a lot of the radiator tubes with gunk. You could pull the radiator flip it upside down and flush it out real good. That would eliminate it as a possible cause...?
Re: sealer in cooling system [Re: jbc426] #852433
11/13/10 07:54 PM
11/13/10 07:54 PM
CIB Offline OP
CIB  Offline OP
Thanks for the suggestions, your help is appreciated.
Re: sealer in cooling system [Re: CIB] #852434
11/18/10 08:23 PM
11/18/10 08:23 PM
CIB Offline OP
CIB  Offline OP
update: I pulled radiator turned upside down and flushed, a few pieces of sealer came out. Took car for test ride,seemed slightly better but still got warmer than usual at low rpm. Engine onley has about1000 miles since rebuild. Block and heads were cleaned and flushed. Running flex fan. Used to be higher rpms would get warmer then cool down as rpms got lower. Now is just the opposite.
Re: sealer in cooling system [Re: CIB] #852435
11/18/10 09:25 PM
11/18/10 09:25 PM
If it's OK at higher rpm's that tells you the rad flow is adequate & assuming the rad has enough area so that it did cool Ok at lower rpm at one time. It's hotter now at lower rpm's (b 4, it was cooler at the same (lower) rpm's?)
Re: sealer in cooling system [Re: RapidRobert] #852436
11/19/10 12:04 AM
11/19/10 12:04 AM
CIB Offline OP
CIB  Offline OP
Yeah me too! Flex fan? radiator cap?
