Re: sealer in cooling system
[Re: CIB]
#852427
11/13/10 09:50 AM
11/13/10 09:50 AM
Posts: 21,080 Niles , Ohio
therocks
Niles , Ohio
I use anti sieze on the exhaust bolts and never had a leak.Try pulling the 2 plugs on the bottom front of the block and see what comes out.You cant believe how much gunk gets built up down there.Most plugs Ive pulled water wont even come out till you get the crud out of the hole.Rocky
Chrysler Firepower
[Re: CIB]
#852429
11/13/10 10:45 AM
11/13/10 10:45 AM
RapidRobert
More info, started getting hotter all of a sudden or gradually this summer. How hot? around town/idleing or out on the highway? Have a shroud? rad marginal? any other driveability probs when it started happening
[Re: MoparforLife]
#852430
11/13/10 01:20 PM
11/13/10 01:20 PM
Posts: 139 Annapolis, Missouri USA
CIB
Started this summer early. Has original gauge in 65 belvedere. In past never got above 1/4 on gauge,Now gets gradually warmer highway driving. In town or idleing moves up past halfway to about 3/4. Has shroud, Car had dealer installed air and has bigger radiator for air conditioning. All started after sealer got into cooling system from exhaust bolts. After pulling engine several times to get rear main seal from leaking. I also replaced water pump and thermostat, no change. I believe there were pieces of sealer about the size of the head of a pencil that got into system. I wonder if they would be pluggingthe cooling sysem anywhere.
[Re: CIB]
#852431
11/13/10 05:10 PM
11/13/10 05:10 PM
therocks
Niles , Ohio
Unless they are a few thousand floating in there I doubt they can plug anything up.They would all have to be in one spot pretty much.Pull the plugs on the block and do a good back flush there and on the rad.Rocky
Chrysler Firepower
[Re: therocks]
#852432
11/13/10 06:29 PM
11/13/10 06:29 PM
Posts: 3,285 West Coast, USA
jbc426
West Coast, USA
It doesn't take much to plug a lot of the radiator tubes with gunk. You could pull the radiator flip it upside down and flush it out real good. That would eliminate it as a possible cause...?
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
