Re: What do you guys do for those hard to get to areas??
[Re: DaytonaTurbo]
#851907
11/13/10 01:01 AM
11/13/10 01:01 AM
Posts: 106 Oakbank, MB Canada
mbmopar
Oakbank, MB Canada
I used a long piece of old trans cooler line, attached it to my blow gun via a rubber hose, and about 40 psi I cleaned out approx 20 lbs of sand, silt, crap, etc from my frame rails on my 74 Monaco Police car during the resto......and ran / sprayed primer and paint in as best I could ...the trans line worked great, using the end to scrape away at the inside corners and get the packed silt...but do it outside trust me
"Put a Dodge in your garage!"
[Re: mbmopar]
#851909
11/13/10 03:13 PM
11/13/10 03:13 PM
Posts: 6,003 Salem
Grizzly
Moparts Proctologist
Salem
mbmopar: That's a great idea, thanks! A nearby bodyshop uses a product called "wax-oil". It is sort of like the spray foam stuff used for sealing drafty windows and walls in your house. They put an extension tube on the wax-oil can and use it to fill the rocker panels and door bottoms. Sorry I don't have pics, perhaps someone else does?
Mo' Farts
Moderated by "tbagger".
[Re: DaytonaTurbo]
#851911
11/14/10 10:12 AM
11/14/10 10:12 AM
Posts: 16,823 Between Houston & Galveston TX
SattyNoCar
While I haven't tried it, Eastwood now has a product for treating the inside of frame rails. Worth a try? Eastwood
John
[Re: SattyNoCar]
#851912
11/14/10 11:48 AM
11/14/10 11:48 AM
Posts: 2,592 None
71rm23
None
Worth a try?
Eastwood
Thanks for posting that. I would give it a whirl
[Re: Grizzly]
#851916
11/15/10 03:03 AM
11/15/10 03:03 AM
Posts: 9,670 Lima, Peru
domingo
EL Master
EL Master
Lima, Peru
No, we were reffering to this one quoted above.
I would never put some kind of foamy element inside the rockers!!! I bet it would make things worse!!!
[Re: domingo]
#851917
11/15/10 09:23 AM
11/15/10 09:23 AM
Posts: 2,766 Appleton, Wisconsin
rtmike
Appleton, Wisconsin
I cleaned mine the best I could with compresed air and a shop vac. If there was surface rust I hit it with the spray stuff that turns the rust black (I think its phoshporic acid, but don't quote me, I got the semi-cheap version from NAPA), then I stuck the nozzle of the spray gun in there and put paint in there like crazy. It was messy, but in the end it is probably the best thing I could do. I am sure it is better then the factory, and that held up for 41 years, so considering how little weather it sees, probably good.
Its not primer its perma gray.
[Re: domingo]
#851918
11/15/10 10:54 PM
11/15/10 10:54 PM
Posts: 417 Caledon, Ontario
smac77
Caledon, Ontario
Fluid film is a wax oil and it's pretty runny, not foamy?? I think cosmoline is also a wax oil??? Those two are great for inside panels, rails etc...
Restoration, Sales and Canadian Distributor For: AMD Sheetmetal Wizzard Direct Fit, Bolt In Aluminum Radiators Legendary Interiors SSBC & Wilwood Brakes Control Freak Suspensions Fine lines Tubing and many more... www.macleanclassics.com
[Re: Grizzly]
#851921
11/16/10 09:27 AM
11/16/10 09:27 AM
Posts: 1,756 London, England
Gavin
London, England
You are probably thinking of this product Wayoyl (note spelling). The product is better than the website! It has been used over here in the UK for decades and works pretty well - it is exactly designed for getting in hard to reach cavities etc and preventing rust. I'm sure it must either be available in the US or something similar.
[Re: SattyNoCar]
#851923
11/19/10 08:27 PM
11/19/10 08:27 PM
Gavin
London, England
Doing a quickie google search, I came up with these guys that apply waxoyl or sell it for the DYI'er.
Robinson Service
How difficult is it to apply this stuff?
Not difficult - it is pretty much solid at room temeprature (but you could squish it in your hand easily). If you heat it up it gets real runny and then is easily applied inside sills etc with a sprayer. The ones you buy are basically like a trigger sprayer with a tube on with holes in it. It would be easy enough to make an applicator.
Only thing is - that link you posted seems to be charging over $200 for a 5L can - over here you can get a 5L can for less than $50. That seems excessive to me
[Re: A12]
#851925
11/21/10 10:44 AM
11/21/10 10:44 AM
SattyNoCar
Only thing is - that link you posted seems to be charging over $200 for a 5L can - over here you can get a 5L can for less than $50. That seems excessive to me How much would you charge to ship? Sounds kinda like Ziebart to me too.
John
