Re: Where to get wire connector for Ballast Resistor?
[Re: a12rag]
#850640
11/10/10 09:20 PM
11/10/10 09:20 PM
RapidRobert
If the bakelite is good & just need another brass terminal, look closely at the cover & there should be a mini slot that you can stick a mini eyeglass screwdriver in & depress the tab on the side of the brass terminal & pull it out the back side by pulling on the wires and when you have it depressed the right amt it'll come right out w no force needed. Here's a NAPA # for the female terminal 725145. Crimp/solder on your wires and pull the brass tab on the side of the terminal out a bit from it's flush position then push the assy into the bakelite and it will snap into place. EDIT buy a male terminal (725147) at NAPA when you are there & use it to check that the new female one you buy is crimped just the right amt to slip on w the right amt of force as some are too tight and forcing it onto the ballast (or any other useage) is not the way to adj its tension. I think full retail is about 47 cents ea
[Re: Ronnman]
#850644
11/13/10 02:26 PM
11/13/10 02:26 PM
Posts: 6,098 Valencia, España
NachoRT74
Valencia, España
Terminal Supply Co. Packard 56 type terminals. Ron
http://terminalsupplyco.com/Store/Default.aspx?CAT=DEL010&PCAT=54228#Categories
GRRRRRRRRRRRREEEAT, thanks... I allways have been seraching for conectors providers.
And noted they have lot of gauges sizes for the terminals. Some other are very limited.
just one question... what would be the diff between for example 6288913 and 2965143. I can't see anyone and description is the same
there are more like those with diff PN but same pic and description
[Re: NachoRT74]
#850645
11/13/10 04:49 PM
11/13/10 04:49 PM
RapidRobert
Nacho what can we do (electrically) to keep the ECU from getting hot & drippin the goo
[Re: RapidRobert]
#850646
11/13/10 05:33 PM
11/13/10 05:33 PM
Posts: 531 Charlotte, NC
Kowal
Charlotte, NC
'69 Hemi Charger 500, ‘70 U code Challenger R/T (These and a bunch others at www.dkowal426.com) P.J. O'Rouke: "The old car ran perfectly, right up until it didn't."
[Re: Kowal]
#850647
11/14/10 04:07 PM
11/14/10 04:07 PM
NachoRT74
Valencia, España
just in case if dual ballast plastic piece required: http://www.chargerspecialties.com/wiring.htmHow to get colder anything into engine bay ? mmm, getting everying clean and tight ? If some device gets a bad ground will suck more power. Then in Case of ECUs... a good alternator power level... ECU is like a computer, if doesn't get a nice and stable power, will overheat untill melt the goo.
