Where to get wire connector for Ballast Resistor? #850638
11/10/10 05:54 PM
11/10/10 05:54 PM
California
dg_dodge Offline OP
dg_dodge  Offline OP
California
Hi guys,
It looks like I will soon need a new wire connector (shown in pic below) that holds the two wires that connect to each side of the ballast resistor.
Are these generic electrical pieces or something Mopar-specific? Anyone know the name of this part or where they are sold?
Thanks a lot!
Re: Where to get wire connector for Ballast Resistor? [Re: dg_dodge] #850639
11/10/10 07:13 PM
11/10/10 07:13 PM
Calgary, Alberta Canada
a12rag Offline
a12rag  Offline
Just find a female flat connector that can handle both wires, crimp it on and away you go . . .
Re: Where to get wire connector for Ballast Resistor? [Re: a12rag] #850640
11/10/10 09:20 PM
11/10/10 09:20 PM
If the bakelite is good & just need another brass terminal, look closely at the cover & there should be a mini slot that you can stick a mini eyeglass screwdriver in & depress the tab on the side of the brass terminal & pull it out the back side by pulling on the wires and when you have it depressed the right amt it'll come right out w no force needed. Here's a NAPA # for the female terminal 725145. Crimp/solder on your wires and pull the brass tab on the side of the terminal out a bit from it's flush position then push the assy into the bakelite and it will snap into place. EDIT buy a male terminal (725147) at NAPA when you are there & use it to check that the new female one you buy is crimped just the right amt to slip on w the right amt of force as some are too tight and forcing it onto the ballast (or any other useage) is not the way to adj its tension. I think full retail is about 47 cents ea
Re: Where to get wire connector for Ballast Resistor? [Re: RapidRobert] #850641
11/10/10 10:52 PM
11/10/10 10:52 PM
California
dg_dodge Offline OP
dg_dodge  Offline OP
California
Thanks much for the great advice (as always) ! I really appreciate the help.
Re: Where to get wire connector for Ballast Resistor? [Re: dg_dodge] #850642
11/12/10 08:37 AM
11/12/10 08:37 AM
indiana
mcmopars Offline
mcmopars  Offline
indiana
what about if you go for the restoration look? any idea who sell them?
Re: Where to get wire connector for Ballast Resistor? [Re: mcmopars] #850643
11/13/10 01:53 PM
11/13/10 01:53 PM
Slidell, LA
Ronnman Offline
Ronnman  Offline
Slidell, LA
Re: Where to get wire connector for Ballast Resistor? [Re: Ronnman] #850644
11/13/10 02:26 PM
11/13/10 02:26 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
Terminal Supply Co. Packard 56 type terminals.
Ron
http://terminalsupplyco.com/Store/Default.aspx?CAT=DEL010&PCAT=54228#Categories
GRRRRRRRRRRRREEEAT, thanks... I allways have been seraching for conectors providers.
And noted they have lot of gauges sizes for the terminals. Some other are very limited.
just one question... what would be the diff between for example 6288913 and 2965143. I can't see anyone and description is the same
there are more like those with diff PN but same pic and description
Re: Where to get wire connector for Ballast Resistor? [Re: NachoRT74] #850645
11/13/10 04:49 PM
11/13/10 04:49 PM
Nacho what can we do (electrically) to keep the ECU from getting hot & drippin the goo
Re: Where to get wire connector for Ballast Resistor? [Re: RapidRobert] #850646
11/13/10 05:33 PM
11/13/10 05:33 PM
Charlotte, NC
Kowal Offline
Kowal  Offline
Charlotte, NC
Year one has them
'69 Hemi Charger 500, ‘70 U code Challenger R/T
(These and a bunch others at www.dkowal426.com)
P.J. O'Rouke: "The old car ran perfectly, right up until it didn't."
Re: Where to get wire connector for Ballast Resistor? [Re: Kowal] #850647
11/14/10 04:07 PM
11/14/10 04:07 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
just in case if dual ballast plastic piece required:
http://www.chargerspecialties.com/wiring.htm
How to get colder anything into engine bay ? mmm, getting everying clean and tight ?
If some device gets a bad ground will suck more power.
Then in Case of ECUs... a good alternator power level... ECU is like a computer, if doesn't get a nice and stable power, will overheat untill melt the goo.
