Popping coming from my 8-3/4" #84994
07/06/08 09:27 PM
07/06/08 09:27 PM
Puyallup, WA
StealthWedge67 Offline OP
Puyallup, WA
My 8-3/4" was rebuilt a year ago with all new bearings, seals, and a new clutch style sure-grip unit. It gives me a pretty heavy popping sound that you can feel when coming out of a slow speed tight corner. It never does it on a straightaway. At first I assumed it was the tight new sure grip unit struggling a little to slip around the corner. It also will turn over the inside tire a little bit on tight turns. But, its been a year or so now (approx. 2500 mi.) and its still making this noise. Could something be wrong in there? or is this normal? It was set up by a pro and I'd take it back to him, but it was a used gear-set and he said he wouldn't warranty it because of that. I may still end up taking it to him to check out, but what do you guys think of this....
Re: Popping coming from my 8-3/4" [Re: StealthWedge67] #84995
07/06/08 09:29 PM
07/06/08 09:29 PM
are you using the GM hypoid additive?
Re: Popping coming from my 8-3/4" [Re: StealthWedge67] #84996
07/06/08 09:53 PM
07/06/08 09:53 PM
Santa Cruz, California
Lefty Offline
Lefty  Offline
I'm pretty sure the sound is the clutches sticking instead of slipping. I think it will grind itself to death without the correct sure-grip additive.
Re: Popping coming from my 8-3/4" [Re: Lefty] #84997
07/06/08 10:32 PM
07/06/08 10:32 PM
Puyallup, WA
Puyallup, WA
I'm using the Ford limited slip additive. Should I drain it & refill with fresh gear-oil & additive?
Re: Popping coming from my 8-3/4" [Re: StealthWedge67] #84998
07/06/08 11:46 PM
07/06/08 11:46 PM
fords additive plain sucks. damage is already done IMO. time to tear it apart.
Re: Popping coming from my 8-3/4" #84999
07/08/08 11:30 AM
07/08/08 11:30 AM
Ansonia, CT
CJK440 Offline
CJK440  Offline
Ansonia, CT
I use Posi-X fluid from the major parts chain.
I had this problem before and all I did was jack up the pass side of the axle only. open the fill plug and dump another tube of additive in it.
All good now.
2017 Contusion Blue Challenger T/A 392 M6 "BLKNBLU"
Re: Popping coming from my 8-3/4" #85000
07/08/08 11:33 AM
07/08/08 11:33 AM
Kirkland, Washington
Pacnorthcuda Offline
Actually Ford's additive is highly regarded. Its been a good choice for MANY years!
Re: Popping coming from my 8-3/4" [Re: CJK440] #85001
07/08/08 11:38 AM
07/08/08 11:38 AM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
I had better results with that stuff than the Ford additive.
Re: Popping coming from my 8-3/4" [Re: ZIPPY] #85002
07/08/08 12:32 PM
07/08/08 12:32 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
might have you broke a ring or pinion gear??? That's the sound mine made when I broke/chipped a few teeth. Especially on hard left hand turns
Re: Popping coming from my 8-3/4" [Re: StealthWedge67] #85003
07/08/08 12:34 PM
07/08/08 12:34 PM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
That is a common problem. New, off-the-shelf clutch sure-grips are rarely assembled correctly. If a fresh change of gear lube and friction modifier doesn't do the trick, I would disassemble the unit, clean everyting then de-burr the casting around the clutch ears if needed. Be sure to pre-lube the clutch plates with straight friction modifier on assembly.
I prefer Ford friction modifier because it is actually rebranded OEM Spicer stuff.
Re: Popping coming from my 8-3/4" [Re: DoctorDiff] #85004
07/08/08 12:41 PM
07/08/08 12:41 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
how about the GM syntho stuff (w/ modifier)? That's what I just put in my unit.
Re: Popping coming from my 8-3/4" [Re: Mr.Yuck] #85005
07/08/08 01:23 PM
07/08/08 01:23 PM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
That should also work. It may make the unit a little lazy, however.
Re: Popping coming from my 8-3/4" [Re: DoctorDiff] #85006
07/08/08 09:44 PM
07/08/08 09:44 PM
Puyallup, WA
Puyallup, WA
Well, I'll try draining as much as I can out of it, then refilling it and adding another bottle of friction modifier. I'll report back when I get this done.
Thanks guys (except the guy who wants me to rebuild it already. For gods sake, man.... I'm glad you don't have my credit card!)
Re: Popping coming from my 8-3/4" [Re: StealthWedge67] #85007
07/08/08 10:01 PM
07/08/08 10:01 PM
yah 2500miles still making noises, and you think a fluid change is the cure.
Re: Popping coming from my 8-3/4" [Re: StealthWedge67] #85008
07/08/08 10:13 PM
07/08/08 10:13 PM
Western NC
68Bullit Offline
68Bullit  Offline
Western NC
What ratio is it? Aren't a lot of gears that are steeper than 4.10 prone to popping around tight turns anyway?
Re: Popping coming from my 8-3/4" [Re: 68Bullit] #85009
07/08/08 10:29 PM
07/08/08 10:29 PM
Puyallup, WA
Puyallup, WA
It's a 3.91:1.
Re: Popping coming from my 8-3/4" #85010
07/09/08 03:10 PM
07/09/08 03:10 PM
I would follow DoctorDiffs advice any day.
Re: Popping coming from my 8-3/4" #85011
07/09/08 03:41 PM
07/09/08 03:41 PM
CHRGR69 Offline
CHRGR69  Offline
This site is full of guys that just want to tear down and rebuild anything and everything!
Grandma always said I had "hands of gold"!
Re: Popping coming from my 8-3/4" [Re: CHRGR69] #85012
07/09/08 04:14 PM
07/09/08 04:14 PM
scratchnfotraction Offline
gets us off the puter and in the shop working on mopars
Re: Popping coming from my 8-3/4" [Re: Pacnorthcuda] #85013
07/09/08 06:34 PM
07/09/08 06:34 PM
good for you
