To "Crank It" or not?
#849926
11/09/10 06:29 PM
11/09/10 06:29 PM
BradH
I'm curious what people consider the better approach re: whether to upgrade my RB 452's crank since (yet another change of direction) it'll be going back together w/ the CNC Victor heads and a street roller cam. My original plan was to put the .010 / .010 OEM forged piece that came out of it back in, since it passed the magnaflux and the journals polished OK w/o having to be cut down again. The block is .060" and is otherwise getting a fresh set of rings & bearings. This is INTENDED to be the last time I go through this bottom end, since I've picked up pretty much all the parts needed to assemble a fresh spare 448 short block. However, I expect the change in heads and cam could add another 40 HP, pushing the engine up close(r) to the 650 HP range. I've got a "blem" Eagle 4340 piece I picked up to use w/ my 448 backup... should I use that, instead of the OEM crank, for a bit of added insurance at the higher power level? If so, then I'll have to factor in picking up another 4340 crank at some point in order to finish the 448. Yep, just another one of those decision points in the process flow of getting my junk back together.
Re: To "Crank It" or not?
[Re: BradH]
#849929
11/09/10 06:50 PM
11/09/10 06:50 PM
Posts: 13,357 Marion, South Carolina [><]
an8sec70cuda
Personally, I'd use the stock crank.
[Re: Quicktree]
#849931
11/09/10 07:16 PM
11/09/10 07:16 PM
BradH
I bet if you send that crank (stock) off you will find a buch of small cracks...
Something the magnaflux it passed already didn't find?
[Re: BradH]
#849932
11/09/10 07:29 PM
11/09/10 07:29 PM
Posts: 5,746 Ontario, Canada
Dodgem
Ontario, Canada
yea magnuflux will help to find the cracks you can see. glow light has deflated my balloon a couple times. Now small stress fractures in some places are just fine.
But stroke it and be happy
I thought the blemed eagles where just .010 so can't sell as new / perfect.
