B-Body Steering Shafts #849505
11/09/10 11:49 AM
11/09/10 11:49 AM
Easton, Kansas
Moparmedic440 Offline OP
Easton, Kansas
I am redoing a steering column on my 72 Roadrunner. The shafts have been pulled apart and I noticed that plastic has been injected between the shafts. Is it safe to just put the shafts together or is there away the secure the shafts together. Thank You for any help.
Re: B-Body Steering Shafts [Re: Moparmedic440] #849506
11/10/10 01:34 AM
11/10/10 01:34 AM
Chicago Burbs
sthemi Offline
sthemi  Offline
Chicago Burbs
They should be put back together.
I used a thin 2 part epoxy after cleaning the area. Seems to be a good fix...
Re: B-Body Steering Shafts [Re: sthemi] #849507
11/10/10 08:06 AM
11/10/10 08:06 AM
Mooresville, NC
A70Runner Offline
A70Runner  Offline
Mooresville, NC
I drilled and tapped mine for 10/32 bolts. I went to Lowes and got some countersunk PLASTIC bolts and bolted them together.
"People Think I'm Insane Because I Am Frowning All The Time" Black Sabbath
Re: B-Body Steering Shafts [Re: A70Runner] #849508
11/10/10 10:56 AM
11/10/10 10:56 AM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
one way to fix it... silicon gun
heating the shaft will help to flow the silicon better to fill all the required areas.
