Roots blower physical size and placement #847608
11/06/10 09:39 PM
11/06/10 09:39 PM
New Brunswick, Canada
CoyoteJack Offline OP
How do you determine how big of a snout you need? Is it a one size fits all and you make up alignment issues with spacers or are they very specific to each engine? Can you use a blower that was on a small block chevy and put it on a small block mopar. I know that the intake is different, but the blower is still the same is it not? The more I get into this the more I realize I don't have a clue as to what is really needed.
Jack
Re: Roots blower physical size and placement [Re: CoyoteJack] #847609
11/06/10 09:57 PM
11/06/10 09:57 PM
ELYRIA,OH
blownzoom440 Offline
ELYRIA,OH
big and sm block will be different i am sure.what do you have?what intake or other parts?or are you just starting and asking to know before hand?
Re: Roots blower physical size and placement [Re: blownzoom440] #847610
11/06/10 10:58 PM
11/06/10 10:58 PM
Just starting and trying to make sure I know what I need. It could be very expensive if you don't know. I am looking at a small block setup, 360 magnum with an Indy intake. If you are wondering about the choice of intake, none of the blower retailers seem to have an intake for a 5.9.
Jack
Re: Roots blower physical size and placement [Re: CoyoteJack] #847611
11/06/10 11:11 PM
11/06/10 11:11 PM
ELYRIA,OH
ELYRIA,OH
if you use the stock harmonic ballincer you could put a streight adge on it going up to the intake level and measure back from there to where you want the snout mount on the blower.i have my blower here so i can measure the blower for you.BDS had some measurements on there site of all size blowers.
Re: Roots blower physical size and placement [Re: blownzoom440] #847612
11/07/10 12:01 AM
11/07/10 12:01 AM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
On some roots blowers that I'm familiar with, they make many different snout lengths so you can tailor it to your setup by changing the shaft and the snout housing.
I know dyersblowers.com sells a roots intake for small block LA mopar, you'd have to redrill if you have magnum heads. Only problem is their SB mopar intakes costs an arm, leg, kidney and your left lung! $1300
Re: Roots blower physical size and placement [Re: DaytonaTurbo] #847613
11/07/10 06:30 PM
11/07/10 06:30 PM
Your not kidding on the price. They don't make one for a Magnum yet. I found one at INDY and it's $634. I can live with that.
Jack
Re: Roots blower physical size and placement [Re: CoyoteJack] #847614
11/07/10 06:38 PM
11/07/10 06:38 PM
ELYRIA,OH
ELYRIA,OH
Jack
the snout mount face is 5" from the #1 blower stud if that helps any now that you found an intake.
Re: Roots blower physical size and placement [Re: blownzoom440] #847615
11/08/10 09:51 AM
11/08/10 09:51 AM
Jack
I think what I will have to do is pick up the intake and a blower minus the snout if I see a smoking deal on one. Then get my measurements and order a snout and pulleys.
Maybe even buy a complete setup and then sell what I can't use to help pay for what I do need. This is if I see a great deal on a used one.
Jack
Re: Roots blower physical size and placement [Re: CoyoteJack] #847616
11/08/10 10:21 PM
11/08/10 10:21 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
I have been dealing with Good Vibrations out in California for my blower stuff. They are helpful, friendly, know their stuff, AND discount even BDS parts.
Master, again and still
Re: Roots blower physical size and placement [Re: DaveRS23] #847617
11/09/10 11:26 PM
11/09/10 11:26 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
I am waiting on the gasket & bearing kit to freshen up my blower
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: Roots blower physical size and placement [Re: CoyoteJack] #847618
12/02/10 09:03 PM
12/02/10 09:03 PM
SE PA
Five9Dak Offline
Five9Dak  Offline
SE PA
You can save 300 on that indy intake if you drill it for EFI yourself. It's a very nice piece, the runner entries are even bellmouthed a bit.
