Page 2 of 3 1 2 3
Re: 340 overheating problems [Re: ahy] #846625
11/05/10 07:57 PM
11/05/10 07:57 PM
Ohio
440727 Offline OP
440727  Offline OP
Ohio
The car has no shroud ....
Just bought a new MSD distributor so going start there with the adjustible weights and springs.
How hard is it to install an MSD system ? Have 6AL box and distributor.
Thanks !
Re: 340 overheating problems [Re: 440727] #846626
11/05/10 11:46 PM
11/05/10 11:46 PM
Under My Car
Mopar_Country Offline
Under My Car
Right there is where I'd start. The fan should be half in and half out of the back edge of the shroud. The shroud and fan combo is what keeps you cool at idle, at cruise there is enough air moving through the rad to run normal. As Chally 1 said advance your initial to get your idle down. You could be getting off the idle circuit and pulling some advance at that idle and that's what is making your timing jump around. As stated some movement is normal, mine bounces around about 2*.
How did you determine the clutch fan is working properly?
Re: 340 overheating problems [Re: 440727] #846627
11/05/10 11:46 PM
11/05/10 11:46 PM
Indiana
Y
YO7_A66 Offline
YO7_A66  Offline
Y
Indiana
Raise the initial timing to 18 degrees and add a shroud.
Re: 340 overheating problems [Re: Mopar_Country] #846628
11/06/10 12:18 AM
11/06/10 12:18 AM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Right there is where I'd start. The fan should be half in and half out of the back edge of the shroud. The shroud and fan combo is what keeps you cool at idle, at cruise there is enough air moving through the rad to run normal....
I think you can get a factory shroud from the dealer still for an E-body.
Re: 340 overheating problems [Re: autoxcuda] #846629
11/06/10 08:02 AM
11/06/10 08:02 AM
San Jose, California
DennisH Offline
Vacation
DennisH  Offline
Vacation
Got a B Body shroud from Megaparts. $95. Took about 10 days to get here though with standard shipping.
Re: 340 overheating problems [Re: autoxcuda] #846630
11/06/10 08:34 AM
11/06/10 08:34 AM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Definitly needs a shroud also.
Can't have too many shrouds. I bought a couple last time I was at the dealer about 5 years ago. Keeping one new one for a spare. They had plenty back then. Hope this helps your buddy.
Putting in a new dist isn't gonna help until you get the timing straightened out. Also you don't need a MSD, factorty ignition does just fine for me.
I drive my cars alot.
Re: 340 overheating problems [Re: Challenger 1] #846631
11/06/10 09:05 AM
11/06/10 09:05 AM
Cincinnati, Ohio
Cincinnati, Ohio
Bragging, ever drive your car this fast for this long in 95 degree heat at 6000+ feet alitude?
Like what was said above, factory cooling is best with the old original copper radators.IMO
This is as hot as it got and even cooled back down at idle as I let it sit for at least 5 mins idling back at the trailer siting in 95 degree heat with the AC running the whole time. Ulitimate test of the cooling and fuel delivery system this day. Car passed with stock cooling and fuel system including a factory vapor separator mounted at the fuel pump. It's a 10.5 to 1 340 with a 600 eddie carb.
It's idling in this picture after I ran it at those speeds, Bonneville salt flats where there is no speed limit!!
First my wife and I drove 14 miles straight down the long course at about 40 mph and turned around to came back at 40 and it was freaky. All we brought was her phone. I forgot the GPS or even water. We drove back toward the trailer following the fresh tire tracks, it was like being on the moon. I dropped her off I grabbed my GPS, camera, phone and some water went out there by myself and had at it. Next year I will have on lot's more safety equipment including a helment and racing shoes. Had my seat belt on. lol
Re: 340 overheating problems [Re: Challenger 1] #846632
11/06/10 09:15 AM
11/06/10 09:15 AM
DennisH Offline
Vacation
DennisH  Offline
Vacation
Cool pics. Agreed. Ma knew.
-Copper.
-Thermal fan.
-Green coolant.
It all worked and still works.
Wish I had bought some of those Mopar made in USA shrouds when available.
Re: 340 overheating problems [Re: Challenger 1] #846633
11/06/10 10:33 AM
11/06/10 10:33 AM
Indiana
Y
YO7_A66 Offline
YO7_A66  Offline
Y
Indiana
""including a helment and racing shoes.""
I like your high speed flip flops that you had on in the pictures.
Re: 340 overheating problems [Re: YO7_A66] #846634
11/06/10 10:57 AM
11/06/10 10:57 AM
Cincinnati, Ohio
Cincinnati, Ohio
Yea I know, it was pretty stupid. She in no way was gonna let do it while she was in the car and I kept saying I wasn't gonna do it. But when I got out there by myself it just kinda happened?
Re: 340 overheating problems [Re: Challenger 1] #846635
11/06/10 03:50 PM
11/06/10 03:50 PM
Ohio
440727 Offline OP
440727  Offline OP
Ohio
Ok guys...
He has an aftermarket Jegs aluminum radiator and Jegs only makes a flat shroud which requires some modification. So we'll address this by going to stock radiator or getting a shroud made up.
Accel does not sell a spring and weights set up for their distributors. Now I've already tried adjusting the total advance setting on this currect distributor. I pulled it apart and loosen both screws and moved the total advance plate 1/16 of an inch up. Put it all back together and the ran the car. Well I had an initial timing of 15* and total advance of 34*. Well the car could be idled down to 800rpms but the car was wanting to fall on its face on the road. So I put it back to original setting which is where we are now.
So my brother went out and bought the MSD set up because they have the springs and weights.
Now what's your opinion guys ?
Thanks !
Re: 340 overheating problems [Re: 440727] #846636
11/06/10 04:20 PM
11/06/10 04:20 PM
Cincinnati, Ohio
Cincinnati, Ohio
Thanks !
I think the MSD dist has a reputation for rusting really bad inside, keep a eye on it.
Like I said, it's lean, jet it up so it won't "fall on it's face"
Timing needs to be where we"re all telling you.
I'm not familer with a Accel dist, can't be much different than stock. You have to shorten the slots in the advance plate to limit advance.
Does that sound right to you? (me not knowing about accel dist)
Springs don't adjust advance in dist, don't worry about springs at this time. Worry about timing not springs. The length of the slots adjust the total timing.
Nothing wrong with a aluiminum radiator, it just needs a shroud to go with that clutch fan which is the hot setup. imo lol
Re: 340 overheating problems [Re: Challenger 1] #846637
11/06/10 06:35 PM
11/06/10 06:35 PM
Ohio
440727 Offline OP
440727  Offline OP
Ohio
Well the problem is as the Accel distributor sits now if I but it at 18* initial timing I'll be running like 50* total advance. So was I going in the right direction on adjusting the advance plate ? Just go more this time ?
The engine builder said don't go over 36* total timing on 93 octane or we'll tear stuff up.
Thanks guys !
Re: 340 overheating problems [Re: 440727] #846638
11/06/10 06:44 PM
11/06/10 06:44 PM
Cincinnati, Ohio
Cincinnati, Ohio
Thanks guys !
Yes your builder is right on. Inside the dist there are slots that need to be closed up/shortened so they only provide a additional 17 degrees of timing. 18 degrees at idle and +17 when you rev it up and that gives you 35 degrees of total timing, not counting vacum advance.
Hope this is starting to make sense.
Re: 340 overheating problems [Re: Challenger 1] #846639
11/06/10 06:56 PM
11/06/10 06:56 PM
is that 18 initial @800 rpm? then as said above shorten the slots to get 35 total. (possibly) need to richen the carb but I'd start on the airflow prob.
Re: 340 overheating problems [Re: RapidRobert] #846640
11/06/10 07:36 PM
11/06/10 07:36 PM
Cincinnati, Ohio
Cincinnati, Ohio
Yes
Re: 340 overheating problems [Re: Challenger 1] #846641
11/06/10 11:21 PM
11/06/10 11:21 PM
Yes
Alright, shorten it to 35 total & that'll get the timing out of the way. However do note (& post) what rpm it reaches 35 at & the springs might be off but if it is not pinging then no damage is being done there & it is close enough to ideal to not be retarded & having anything to do w the overheating. Continuing on...
Re: 340 overheating problems [Re: Challenger 1] #846642
11/07/10 01:44 AM
11/07/10 01:44 AM
Ohio
440727 Offline OP
440727  Offline OP
Ohio
Are you talking about the slots which the advance moves back and forth on ? These are two slots that are like 3/4 of an inch long paralle to each other held down by torx screws.
Thanks guys ?
Re: 340 overheating problems [Re: 440727] #846643
11/07/10 04:34 AM
11/07/10 04:34 AM
Havent been in a Mallory built unit but yes shorten the slots/limit the travel
Re: 340 overheating problems [Re: 440727] #846644
11/07/10 08:44 AM
11/07/10 08:44 AM
Cincinnati, Ohio
Cincinnati, Ohio
Thanks guys ?
Yes, that's it! You already have the good adjustable mallory designed dist. It's a nice peice! It's better than The MSD for sure in my mind.
You loosen both torx screws and close down those slots which limit over all timing.(there more like square windows on the adj units) Way better and easier to adjust than a stock dist. Can you post any pictures of it??
Page 2 of 3 1 2 3
