Blown alcohol guys #844260
11/02/10 11:24 AM
11/02/10 11:24 AM
Left Coast
BobR Offline OP
BobR  Offline OP
Left Coast
Is it possible to run a twin turbo'd solid BAE hemi using gasoline/innercooler? Or is methanol definitely needed to keep the heads cool?
Re: Blown alcohol guys [Re: BobR] #844261
11/02/10 01:44 PM
11/02/10 01:44 PM
Orange County, Ca.
B1CUDA Offline
B1CUDA  Offline
Orange County, Ca.
Bob, I suggest you call Darren at BAE, as he will know which way to guide you. Darren is incredibly familiar with the 10.5 type racing, as well as the Top Fuel stuff. I think if Darren and Jason put their heads together, it would be scary for the Outlaw class.
BAE - (909)923-1028
Re: Blown alcohol guys [Re: B1CUDA] #844262
11/02/10 01:53 PM
11/02/10 01:53 PM
Left Coast
BobR Offline OP
BobR  Offline OP
Left Coast
BAE - (909)923-1028
I know Doug has definitely talked to someone over there. I'm bringing them a check on Friday for the first order. I'm sure they'll get it straightened out but I was just curious if running gas was do-able with dry heads.
Re: Blown alcohol guys [Re: BobR] #844263
11/02/10 02:22 PM
11/02/10 02:22 PM
Hemiroid Offline
Hemiroid  Offline
BAE - (909)923-1028
When you said you were going BAE I thought you meant with a screw. Just kinda wondering why the turbos when the blower and BAE go together so well on meth? I guess it's probably less of a problem getting the turbos to leave and is what you guys are accustomed to.
Re: Blown alcohol guys [Re: Hemiroid] #844264
11/02/10 03:49 PM
11/02/10 03:49 PM
Left Coast
BobR Offline OP
BobR  Offline OP
Left Coast
BAE - (909)923-1028
We can't run a screw blower in Outlaw here on the west coast.
Re: Blown alcohol guys [Re: BobR] #844265
11/02/10 04:05 PM
11/02/10 04:05 PM
Orlando Florida
blown572dart Offline
Orlando Florida
Darn shame because they work well.
Re: Blown alcohol guys [Re: BobR] #844266
11/02/10 04:29 PM
11/02/10 04:29 PM
Hemiroid Offline
Hemiroid  Offline
BAE - (909)923-1028
Ahh, ok, makes sense. Well, I'm sure it will still haul a$$ as I've never seen a Hemi that didn't like manifold pressure. Whether it comes via the hair dryers or a screw won't matter too much, I'm sure it will still fly.
Good luck with it and please keep us posted on your progress.
