1991 Chrysler Imperial trans issues- any help? #843920
11/01/10 10:16 PM
11/01/10 10:16 PM
Anchorage Alaska
CruisingRam Offline OP
super gas
super gas
Anchorage Alaska
I have a 1991 Chrysler Imperial 3.3 V6
The transmission is acting exactly like the other '91 Imperial trans issues. I've replaced the Low speed sensor, The High Speed sensor and a throttle sensor. Thte car will shift from 1st to 2nd then gets stuck. It was shifting to third but wanted to slamm three times before resuming third. This seams electronic to me.... Any Ideas..
Thanks in advance.
Re: 1991 Chrysler Imperial trans issues- any help? [Re: CruisingRam] #843921
11/01/10 10:43 PM
11/01/10 10:43 PM
louisiana,usa
O
olemopar Offline
olemopar  Offline
O
louisiana,usa
You need to have it hooked up on a scanner and see what the codes are,if no codes you need someone with experence reading the data to figure out the problem,i worked at a dealership for 35 years, worked on a lot of these
Thad
Re: 1991 Chrysler Imperial trans issues- any help? [Re: olemopar] #843922
11/02/10 09:03 AM
11/02/10 09:03 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
I believe there was also an upgrade for the controller for them.I had one around here that I pulled from a friends car.Rocky
Chrysler Firepower
Re: 1991 Chrysler Imperial trans issues- any help? [Re: therocks] #843923
11/02/10 11:41 AM
11/02/10 11:41 AM
louisiana,usa
O
olemopar Offline
olemopar  Offline
O
louisiana,usa
Yes every time you serviced it you had to reflash the controller for the trans or replace to latest version
Thad
Re: 1991 Chrysler Imperial trans issues- any help? [Re: olemopar] #843924
11/02/10 01:36 PM
11/02/10 01:36 PM
Anchorage Alaska
super gas
super gas
Anchorage Alaska
Thad
Anyone know the service bulletin for this or anything? Hawaii can be kind of behind the times on this stuff at the dealer!
Re: 1991 Chrysler Imperial trans issues- any help? [Re: CruisingRam] #843925
11/02/10 03:02 PM
11/02/10 03:02 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
If it's like the other FWD transmissions you may want to check the connection on the transmission. My sister's minivan had issues and everybody wanted to rebuild it. I changed the plug for the wires and all the problems went away. In fact, there wasn't another problem with it until it got run over by an 18 wheeler.
- Stu Harmon
Re: 1991 Chrysler Imperial trans issues- any help? [Re: olemopar] #843926
11/08/10 12:00 AM
11/08/10 12:00 AM
Anchorage Alaska
super gas
super gas
Anchorage Alaska
Thad
I am going to reflash it here real soon, see what happens.
