727 weight? #843620
11/01/10 05:23 PM
11/01/10 05:23 PM
campbell river B.C
mopartoby Offline OP
campbell river B.C
Anyone have an idea what a bb 727 with an 8 inch converter weighs?
Re: 727 weight? [Re: mopartoby] #843621
11/01/10 05:32 PM
11/01/10 05:32 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
Well I can barely lift them without a converter so I'd say an 8 inch converter too much!!!
Re: 727 weight? [Re: Dodgem] #843622
11/01/10 05:34 PM
11/01/10 05:34 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
I think they are 150 to 160 without the converter so pushing 200 with one!
Re: 727 weight? [Re: Dodgem] #843623
11/01/10 05:36 PM
11/01/10 05:36 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
oh 68 to 72 kg and 91 kg with converter there abouts
in French!
Re: 727 weight? [Re: Dodgem] #843624
11/01/10 05:53 PM
11/01/10 05:53 PM
The Netherlands
I
Indy408 Offline
Indy408  Offline
I
The Netherlands
Last week i put one on the scale to compare it to a 4 speed 46re
A sb 727 fresh build no fluid weighs 128 without the converter.
4 speed 46re that i pulled from the truck, and drained the fluid.Weighs 213 with converter
Re: 727 weight? [Re: Indy408] #843625
11/01/10 06:20 PM
11/01/10 06:20 PM
organ
maximum entropy Offline
organ
when i was a kid they were maybe 50 pounds? now they're thousands of pounds- immovable.
Re: 727 weight? [Re: maximum entropy] #843626
11/01/10 06:25 PM
11/01/10 06:25 PM
Hemiroid Offline
Hemiroid  Offline
LOL!! I swear I was just thinking the same thing
Re: 727 weight? [Re: Hemiroid] #843627
11/01/10 06:32 PM
11/01/10 06:32 PM
campbell river B.C
campbell river B.C
thanks!!!! i just bought one from a friend of mine in california, i'm just figuring the shipping cost from there to b.c canada.
Re: 727 weight? [Re: maximum entropy] #843628
11/01/10 08:12 PM
11/01/10 08:12 PM
Maryland
Dads426 Offline
Dads426  Offline
Maryland
When I was young a LONG time ago I used to put a cast iron 3-speed or a 4 speed Muncie on my chest and bench press it into the bell housing. Now I can barely move them. That is why I have Kevin
2012 422 Allstars NSS Champion
2013 422 Allstars NSS Champion
2014 422 Allstars NSS Champion
Re: 727 weight? [Re: mopartoby] #843629
11/01/10 10:58 PM
11/01/10 10:58 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
With the vert about a 150# to 175# mike
Re: 727 weight? [Re: Indy408] #843630
11/01/10 11:00 PM
11/01/10 11:00 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
Dam I get weaker every year. I put a big heavy deep B&M aluminum pan on mine this year and it was just about the tipping point on my back and knees going out! LOL!!!
Re: 727 weight? [Re: maximum entropy] #843631
11/01/10 11:17 PM
11/01/10 11:17 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
When I was a kid I use to use either jacks or ropes around the torsion bars to get the tranny in.
At age 45+ its much easier/faster to just roll the 150# tranny on my stomach and manipulate it in with my knees/feet/arms etc. The rear crossmember helps. alot
Screw the jacks, that takes some prior manipulation too. By the time I get it manipulated onto the Jacks, I can have it installed allready. Screw that. mike
Re: 727 weight? [Re: Indy408] #843632
11/02/10 09:05 AM
11/02/10 09:05 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I would guess that stock conv would weigh about 55 lbs
on the 46re
Re: 727 weight? [Re: MR_P_BODY] #843633
11/02/10 04:25 PM
11/02/10 04:25 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
A 12" non-lockup converter weighs 35 lbs.
Re: 727 weight? [Re: Dads426] #843634
11/02/10 09:40 PM
11/02/10 09:40 PM
NC
440Jim Offline
440Jim  Offline
NC
I can relate to all that.
I used to bench press a Ford top loader 4-speed every weekend when I was 19. I had a close ratio trans and 4.11 gears (9" rear) for the weekend, and a wide ratio trans and 3.23 gears for during the week. Friday after work I washed the car, changed the rear pumpkin, and swapped the transmissions.
Then I bought a Chrysler and the first time I put that big 4-speed manual on my chest I almost cried for help.
Re: 727 weight? [Re: 440Jim] #843635
11/04/10 11:25 PM
11/04/10 11:25 PM
Mo.
racerx Offline
racerx  Offline
Mo.
Sorry not meaning to hijack.But sense we are speaking on weights,anyone no how much weight difference in a T-400/727?
Re: 727 weight? [Re: racerx] #843636
11/05/10 05:05 PM
11/05/10 05:05 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
The short tail TH400 without converter weighs 134 lbs.
Re: 727 weight? [Re: John_Kunkel] #843637
11/06/10 12:14 AM
11/06/10 12:14 AM
Mo.
racerx Offline
racerx  Offline
Mo.
Just weight'd a Big Blk. 727 136 without conv.
