Manual steering box opinions #840646
10/28/10 12:31 AM
10/28/10 12:31 AM
wisconsin
kmfdm Offline OP
kmfdm  Offline OP
wisconsin
I'm trying to get some opinions on what I should do with the manual steering box in my Dart. I have a lot of slop in the steering wheel, and I'm pretty sure the steering box is the culprit. Should I shell out the money to rebuild the one I have, or should I go with a new one? If I do go with a new one, which one should I get?
74 Dart Sport
Re: Manual steering box opinions [Re: kmfdm] #840647
10/28/10 01:05 AM
10/28/10 01:05 AM
AndyF Offline
AndyF  Offline
You might be able to just adjust out the slop, or at least most of it.
Re: Manual steering box opinions [Re: kmfdm] #840648
10/28/10 01:26 AM
10/28/10 01:26 AM
petaluma,ca. u.s.a.
west Offline
west  Offline
petaluma,ca. u.s.a.
if you are sure it is the box then play with it and see what happens. Only if it is trashed(which is rare) should you buy a new one.
Re: Manual steering box opinions [Re: kmfdm] #840649
10/28/10 01:31 AM
10/28/10 01:31 AM
So Cal
Sinitro Online content
Sinitro  Online Content
So Cal
I would suggest going with a new Flaming River box, 16 to 1, made out of steel and produced in South America (Argentina). Don't waste your time & $ having your old manual box rebuilt..
Just my $0.02...
Re: Manual steering box opinions [Re: kmfdm] #840650
10/28/10 10:04 AM
10/28/10 10:04 AM
Milwaukee
ToddP Offline
super street
ToddP  Offline
super street
Milwaukee
You could opt for the 20:1 Kit mopar performance sells. Should tighten everything up. If the sector shaft adjusting nut won't work well enough.
also check to see if the box you are using has bushings or needle bearings for the sector shaft.
I would get a different box if it has bushings, needle bearings are better.
