NEED HELP! 72 roadrunner 360 #838043
10/25/10 12:47 AM
10/25/10 12:47 AM
Detroit,Michigan USA!
E
erick72 Offline OP
erick72  Offline OP
E
Still months later trying everything,wiring rebuilt, Coil tested it works,New wires plug,Distributor, and still nothing! the only thing i haven't tried is turning the distibutor but i don't want to throw a rod if i turn it to much could this be the reason the 360 wont star? trying to get it goin before it too cold.
thanks guys!
also anyone near saint clair shores who would like to help?
Re: NEED HELP! 72 roadrunner 360 [Re: erick72] #838044
10/25/10 01:05 AM
10/25/10 01:05 AM
Chilliwack B.C. Canada
RUNCHARGER Offline
RUNCHARGER  Offline
Have you pulled a sparkplug, grounded it and see if you have spark jumping across the gap? If so then put your finger over #1 hole with no plug in it and bring it up to TDC on the damper while feeling compression push past your finger. Stop it at TDC and twist your distributor until it's at #1, check the rest of the wires for proper firing order, then button it together and start it up.
If you don't have spark jumping the gap on the grounded plug you have to do more work to see why you have no spark. Most likely a bad ballast resistor or ECU unless you still have points?
Sheldon
Re: NEED HELP! 72 roadrunner 360 [Re: RUNCHARGER] #838045
10/25/10 03:00 AM
10/25/10 03:00 AM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
The only thing I would do different, is when you line up your engine at TDC, back it off until the timing pointer is at about 10* BTDC, then line up your distributor with the #1 plug wire. Just giving it the extra 10* helps it start easier. Of course this is if you're getting spark.
Re: NEED HELP! 72 roadrunner 360 [Re: erick72] #838046
10/25/10 10:56 AM
10/25/10 10:56 AM
Columbus, GA
Michael Ecks Offline
Columbus, GA
What is the history of the car/motor? Was it running at some point before you made changes? Was the motor rebuilt.
If you have done all of the above and checked for fuel, spark, and made sure you don't have the distributor in 180 off. Then it is starting to sound to me like your timing chain jumped some teeth.
"The happiness of your life depends upon the quality of
your thoughts" ~ Roman Emperor Marcus Aurelius
Re: NEED HELP! 72 roadrunner 360 [Re: erick72] #838047
10/25/10 12:27 PM
10/25/10 12:27 PM
South Carolina
W
warpspeed Offline
warpspeed  Offline
W
South Carolina
Hey, I couldn't start my 318 85 earlier this year after pulling all of the pollution junk off of it. Believe it or not, I started turning the distributor CCW from where it should have been. It would sound like it wanted to start as I turned it another 10 to 15 degrees. As is stands now, the distributor is 90 degrees from where it should be. There is only one reason for that, the shaft from the oil pump is off. I haven't checked it, mainly because of the closeness of the distributor to the firewall. it wouldn't fit in the first place. But, after checking everything to make sure it was all working, turning the distributor out of its normal position didn't hurt it, and unbelievablely, it started and has been running for over six months now this way.
Re: NEED HELP! 72 roadrunner 360 [Re: Michael Ecks] #838048
10/25/10 01:53 PM
10/25/10 01:53 PM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
history of the motor is it was a running motor I pulled out of my 5th ave, was reringed/gasketed ~25k miles ago with new double roller timing chain, oil pump, oil pump drive, comp XE262 cam. pulled because I wanted to build something different with as much power but better fuel economy (since this is my DD)
IIRC the dizzy is the one I had in the car, too, but it was removed and put back in the motor by me, as I needed to get my other motor running while waiting for a replacment dizzy he was going to send me. the distributor has been modded (slots welded up) to give ~20* mechanical advance, coming in ~1200RPM and all in at ~2200 RPM. I ran it with ~18-20* initial and 36-38* total. I don't think I did, but it's possible I put the dizzy back in 180 degrees out.
engine was complete, minus carb/intake. not sure what he's using in that regards now.
first things: the basics:
fuel:
1) pull the fuel line off the carb, and have a friend crank the engine over. should have fuel pumping out of the line...if not, either a bad fuel pump, plugged fuel filter, clogged filter/sock in the sending unit or a bad/collapsed line.
2) with the fuel line on, does pumping the gas get a squirt from the accelerator pump circuit?
if fuel looks good, check your oil. if you've done a lot of cranking/pumping the gas and getting a lot of fuel in there, you might have gas in the oil, etc....
spark:
what others have said, check for spark by either pulling a plug out and grounding it to the engine (usually just touching the valve cover will work), or using another plug in one of the wires. no spark, there's a number of causes, bad ballast, bad ecu, another nobody mentioned is bad pickup in the distributor....the can go bad on occasion.
double check, make sure your wires are on the cyls correctly.
if you pull the dist. cap off and #1 plug off to set the cyl at TDC and point the distributor rotor towards the #1 cyl, make sure the #1 wire is over the distributor rotor. I know I had to rotate the wires over 1 terminal on the cap relative to what everyone calls the #1 terminal on the cap to get enough timing adjustment out of the distributor (vac. advance would hit the firewall otherwise).
if fuel looks good and spark looks good, next step I'd do is have a friend crank the motor while you look at the timing mark on the balancer with a timing gun hooked to #1. the motor, with that cam and low compression (stock rering) doesn't like to run or start very easily if the initial timing is somewhat retarded...the mark on the balancer when I put it together and checked it when I pulled the motor via the thumb over the #1 spark plug hole, was pretty accurate, within about 2 degrees. it was real hard to start until it got about 6-10 degrees initial advance.
if everything looks/checks out good, have one person cranking, have the distributor clamp slightly loose so it can be rotated, and one person watching the timing mark with a timing light, so the person watching the timing mark can tell the person turning the dizzy which way to go.
2017 Grand Cherokee Overland
Re: NEED HELP! 72 roadrunner 360 [Re: erick72] #838049
10/28/10 10:24 AM
10/28/10 10:24 AM
E
erick72 Offline OP
erick72  Offline OP
E
well ill try all these. maybe get the ecu tested. thanks guys. thi si sjust really frustrating!
Re: NEED HELP! 72 roadrunner 360 [Re: erick72] #838050
10/30/10 12:48 AM
10/30/10 12:48 AM
ST clair shores MI
moretoys Offline
moretoys  Offline
ST clair shores MI
do you have the oil changed and carb fixed?I bet the ballast is fried or the ecu is toast. I'm sure I have some spares to try.Does it crank over with the key like normal now??If you have everything ready to fire up.I might have an hour or so this weekend.Don't even try to start it with that oil in there.I have that spring if you still need it.Key on,Do you voltage at the positive side of coil?checking spark right at the coil? not the dist/coil wire,Could have bad wires.Check directly at coil tower.Also the neg side of coil should flash a ground signal if all is working right.If you have everyhting else ready to go,I want to fire it up,if I take the time to come by.
Re: NEED HELP! 72 roadrunner 360 [Re: moretoys] #838051
12/01/10 10:34 AM
12/01/10 10:34 AM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
any update?
