K Frame Clerance for Pan #837191
10/23/10 11:53 PM
10/23/10 11:53 PM
Illinois
gearhead01 Offline OP
Illinois
I once saw a sketch for the clearance notch in the K frame A Body)needed for a Milodon pan. I could not find it on their web site today. Does anyone have this sketch, ot pictures of their trimmed K frame?
Thannk you for your help.
John
1971 Satellite Sebring Plus - 14.46 @ 95.43
1977 Road Runner - N/B 11.02@ 119 Drag Radials
Re: K Frame Clerance for Pan [Re: gearhead01] #837192
10/24/10 01:37 AM
10/24/10 01:37 AM
Bama
Randy.. Offline
Randy..  Offline
Bama
little more [image]http://[/image] than a notch but you get the idea.
Re: K Frame Clerance for Pan [Re: Randy..] #837193
10/24/10 09:11 AM
10/24/10 09:11 AM
Canada
Kam*Kuda Offline
Kam*Kuda  Offline
Canada
mine
1970 Barracuda Convertible
1968 Satellite Street Strip car
1654.5 Mustang
1955 Land Rover
Re: K Frame Clerance for Pan [Re: Kam*Kuda] #837194
10/24/10 09:14 AM
10/24/10 09:14 AM
Canada
Kam*Kuda Offline
Kam*Kuda  Offline
Canada
the back
1654.5 Mustang
1955 Land Rover
Re: K Frame Clerance for Pan [Re: Kam*Kuda] #837195
10/24/10 09:16 AM
10/24/10 09:16 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
Those are nice but you don't need to take out that much for the milodon small block pan. Mine has maybe a 3x3 notch in it. If you set the motor down in the engine bay you will see where it needs to be cut. Its small enough its no big deal to do it quickly while your putting the motor in.
68 Barracuda Formula S 340
Re: K Frame Clerance for Pan [Re: Bad340fish] #837196
10/24/10 09:19 AM
10/24/10 09:19 AM
Canada
Kam*Kuda Offline
Kam*Kuda  Offline
Canada
Thats true. I only needed a small notch for my milidon pan in my e body. The heavily modified kframe is not really required in many cases
1654.5 Mustang
1955 Land Rover
Re: K Frame Clerance for Pan [Re: Kam*Kuda] #837197
10/24/10 09:50 PM
10/24/10 09:50 PM
Illinois
Illinois
Thanks for the pictures and descriptions. Milodon says only a 3/4" cut is required, and i saw an instruction sheet once a long time ago with the dimensions. I was looking for some one who might have that sketch.
Thanks again.
John
Re: K Frame Clerance for Pan [Re: gearhead01] #837198
10/25/10 12:45 AM
10/25/10 12:45 AM
New York
polyspheric Offline
polyspheric  Offline
New York
Milodon has let Buffy write the instructions.
The size of the hole depends in large part on how well tied down your engine is.
Worn stock motor mounts, or plates front and rear?
Torque strut?
Do what you like on the X-member, but if you don't have life insurance it shouldn't look like that.
Boffin Emeritus
Re: K Frame Clerance for Pan [Re: gearhead01] #837199
10/25/10 01:58 PM
10/25/10 01:58 PM
Indiana
W5Duster436 Offline
W5Duster436  Offline
Indiana
Thanks again.
John
Sure wish I would have known that as I put mine in with the lakewood BH and it took me forever to get in.. I wondered if that front lip needed to go but left it in. It appeared to me that just removing that front ledge would do the trick. Will definitely be doing it the next time the engine is out.
'70 Duster - SDSS 436 W5 4spd (Gone)
'71 Dodge D100
'70 Dodge W100
