Easiest way to remove hydraulic lifters?? #836001
10/22/10 01:48 AM
10/22/10 01:48 AM
Dexter, Michigan
copper67440 Offline OP
mopar addict
mopar addict
Dexter, Michigan
I beleive I've got a sticky lifter or 2. I haven't looked closer yet and will get a chance next week, hopefully. What is the best thing to use to remove them? I looked in the FSM and see they have a tool for it. What can I use? It's a 66 383.
Re: Easiest way to remove hydraulic lifters?? [Re: copper67440] #836002
10/22/10 01:56 AM
10/22/10 01:56 AM
Chicago Burbs
sthemi Offline
sthemi  Offline
Chicago Burbs
If you engine is reasonably clean, a magnet on an extension works well...
Stubborn ones may require some carb cleaner to get the varnish off.
Otherwise, pull the intake and rocker arms and grab em...Big blocks are nice with no water in the intake.. just a $25 gasket...
Just to add note that back in the day Solder Seal use to make a product called lifter quiet that did a great job of cleaning the lifters in a few hudred miles, eliminating the need to replace them.
Re: Easiest way to remove hydraulic lifters?? [Re: sthemi] #836003
10/22/10 02:09 AM
10/22/10 02:09 AM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
I just stick my finger under them and push up. They come out okay for me, I don't use a magnet. And no need for replacing a gasket either, just some fresh rtv under the front and rear pan rails and a blob at all for corners. I use some permatex copper gasket spray on the intake flanges on the valley pan for good measure.
Re: Easiest way to remove hydraulic lifters?? [Re: DaytonaTurbo] #836004
10/22/10 03:33 AM
10/22/10 03:33 AM
Puyallup, WA
StealthWedge67 Offline
Puyallup, WA
Pop the intake, remove rocker gear, and you can just push them out with your fingers.
Re: Easiest way to remove hydraulic lifters?? [Re: StealthWedge67] #836005
10/22/10 04:22 AM
10/22/10 04:22 AM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
Pull the valve covers and rocker assembly, remove the pushrods and pull the lifters out with a lifter extracting tool. No need to remove the intake.
Re: Easiest way to remove hydraulic lifters?? [Re: jbc426] #836006
10/22/10 05:48 AM
10/22/10 05:48 AM
Dexter, Michigan
mopar addict
mopar addict
Dexter, Michigan
It's the lifter extracting tool I don't have. looking to do it without removing the intake.
Re: Easiest way to remove hydraulic lifters?? [Re: copper67440] #836007
10/22/10 06:06 AM
10/22/10 06:06 AM
My Garage / Museum
idrivevintage Offline
Chrysler Plant
Chrysler Plant
My Garage / Museum
I've always had success with using a telescoping magnet and fish them out
Good luck with whatever you decide to do.
saw the video you posted of your car from the Coronet picture thread, sure sounds good! Looks good too!!
Re: Easiest way to remove hydraulic lifters?? [Re: copper67440] #836008
10/22/10 06:50 AM
10/22/10 06:50 AM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
Re: Easiest way to remove hydraulic lifters?? [Re: copper67440] #836009
10/22/10 07:36 AM
10/22/10 07:36 AM
Alexandria,La.
BigTerry Offline
BigTerry  Offline
Alexandria,La.
telescope pen magnet..1.99 at harbor freight I think it been awhile since I bought one..
Re: Easiest way to remove hydraulic lifters?? [Re: BigTerry] #836010
10/22/10 10:42 AM
10/22/10 10:42 AM
SW Fla.
CYACOP Offline
CYACOP  Offline
SW Fla.
You dont have to pull the intake. Just the rocker shafts.
Re: Easiest way to remove hydraulic lifters?? [Re: CYACOP] #836011
10/22/10 11:39 AM
10/22/10 11:39 AM
chicagoland,usa
buildanother Offline
chicagoland,usa
A nice 90 degree trans pick will hook them out of there also.
Re: Easiest way to remove hydraulic lifters?? [Re: buildanother] #836012
10/22/10 11:58 AM
10/22/10 11:58 AM
Puyallup, WA
Puyallup, WA
Guys, on a big block, pulling the intake is a 10 minute job. It then gives the benefit of actually seeing what you are working on. To me, its a no-brainer.
Re: Easiest way to remove hydraulic lifters?? [Re: jbc426] #836013
10/22/10 12:02 PM
10/22/10 12:02 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
I've done it with a coat hanger...now getting the new one in is a trick.
Coming soon!!!!
Re: Easiest way to remove hydraulic lifters?? [Re: Mr.Yuck] #836014
10/22/10 12:37 PM
10/22/10 12:37 PM
ILL
MLR426 Offline
MLR426  Offline
ILL
I've used a 18 inch 3/8 threaded carriage bolt and ground flats on both sides of the round head.
Then simply push down and turn it alittle to engage the head under the retaining clips of the lifter and lift out, the lifter can be reinstalled the same way.
logan426
Re: Easiest way to remove hydraulic lifters?? [Re: StealthWedge67] #836015
10/22/10 03:21 PM
10/22/10 03:21 PM
SW Fla.
CYACOP Offline
CYACOP  Offline
SW Fla.
It takes longer to pull AND reinstall the intake by the time you get done with the wiring, throttle linkage, gasket cleaning and pan cleaning. He just wants to swap out some lifters. What I didnt say last time was the fact that sometimes the lifter will not pass through directly above that lifter due to rough castings but I have always just passed it to the known wide enough passage and put them in the same way.
Its a "no-brainer".
Re: Easiest way to remove hydraulic lifters?? [Re: CYACOP] #836016
10/22/10 09:22 PM
10/22/10 09:22 PM
Warner Robins, Georgia
DusterMan Offline
super street
DusterMan  Offline
super street
I had a pair of mechanical fingers that I cut the end off
so when you extended them they would go under the snap ring
or catch real good in the lifter. Pull them right out and install.
Pete:
2003 Dodge Quad 2500 Hemi
69 RoadRunner 4 sp Alpine White
2019 Dodge Charger
Re: Easiest way to remove hydraulic lifters?? [Re: CYACOP] #836017
10/22/10 09:31 PM
10/22/10 09:31 PM
Kirkland, Washington
Pacnorthcuda Offline
Its a "no-brainer".
Through the valve cover is very sanitary. Why break an intake seal when you don't have to? Done is several times, very fast, very easy. And rare earth magnets ROCK!!!!
Re: Easiest way to remove hydraulic lifters?? [Re: Pacnorthcuda] #836018
10/23/10 12:09 AM
10/23/10 12:09 AM
Castlegar, BC, Canada
That AMC Guy Offline
If you have a stubborn lifter or 12, a lifter removal tool is always helpful. I don't know what you have in your area, but any well stocked parts supply house should have them in their specialty tool section. Relatively inexpensive as well. I think I paid $12-$18 for mine a few years ago.
It's a long tool with a spring loaded T handle on one end and retracting claws on the other. Basically, you hook the claws into the top of the lifter and pull up on the T handle. Upwards pressure on the T handle pushes the claws out further into the lifter to aid bite.
This tool is a necessity when working on ANY AMC. I'm up to 5 AMC's, and even the low-miler needs lifters. Its got two dead ones for sure!
Bloody Mary, Full of Vodka, Blessed art thou among cocktails....
Re: Easiest way to remove hydraulic lifters?? [Re: copper67440] #836019
10/23/10 01:32 AM
10/23/10 01:32 AM
missouri, USA
moparmojo Offline
moparmojo  Offline
missouri, USA
I have done it a couple times and thought it was fairly easy. Remove the valve covers and rocker assembly. I used a $7 Sears heavy duty telescoping magnetic pick up tool and basic mechanical fingers. Using the combination of the two worked good to pull the lifter out of the bore up and then slide it sideways until it would fit out one of the passages. In most cases I could just use the magnet to pull them up and out and other times I would have to try to get the fingers to grab at the retainer clip on the top of the lifter. Between the two of them it works pretty good. No need to take the intake off unless you really want to. Having the intake and valley pan would give you a good look at the cam shaft if needed. But if it is just a noisy lifter, just replace them all at the same time with the method above. Don't forget to soak them in oil/lube before install.
