Some dude was busting on all the patch work I did the other day and said it was worthless because I should have used full replacement panels.
Question, is it bad to use a lot of patch panels in place of using replacement steel? I am using the correct gage steal, butt welding it and really blending the panels in nicely. Additionally, I am preserving as much of the original good metal as possible..
For example, instead of replacing the entire quarter panel that only had rust on the bottom and the wheel well, I cut the quarter panel into pieces to only replace the bad spots. It's not a straight across weld, but it is still welded on cleanly and there is more original steel this way...
In the end, will this hurt, help or not make a difference to the value of the car?
