Re: Welding up advance slots in M.P dist...
[Re: 72demon416]
#833352
10/19/10 12:46 AM
10/19/10 12:46 AM
Posts: 5,620 long island NY
Ari440
long island NY
WELD THEM
take the distributer apart
two ligth spot welds , so you dont warp the plate
did this on my tach drive long time ago
1.39 9.85 - 137 mph
[Re: Ari440]
#833353
10/19/10 12:50 AM
10/19/10 12:50 AM
Posts: 3,698 NE Oklahoma
Von
NE Oklahoma
What happens if you warp the plate?
I welded mine back in the spring and the idle quality hasnt been right since. ![](/ubbthreads/images/graemlins/1343795-scratchchin.gif)
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72.
Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
[Re: six-barrel]
#833356
10/19/10 02:02 AM
10/19/10 02:02 AM
Posts: 1,496 Sask, Can.
72demon416
Sask, Can.
Well that certainly makes sense- thanks! Now.. Knowing that little tidbit I'm just a little more confused as to what is going on in my dizzy because I set my total to 32 @ 2600 and when I checked the initial it was @ 8 ![](/ubbthreads/images/graemlins/shock.gif) So... I figure I'll bump it to 18 initial but the total only went up to 38 ![](/ubbthreads/images/graemlins/confused.gif) I'm not sure whether there is a reason for that and I am uneducated in it's function or if there is a problem there? Either way, the slots are welded and it's going back together and we'll see how this works out.
[Re: ademon]
#833363
10/19/10 09:40 AM
10/19/10 09:40 AM
Von
NE Oklahoma
try JB weld
I did this to my dist and it lasted about 1k miles before it fell out.....
[Re: six-barrel]
#833365
10/19/10 12:26 PM
10/19/10 12:26 PM
Posts: 3,464 Dandridge TN
Dabee
Dandridge TN
Don at FBO sells a plate with 4 mech limit slots
Any one have contact info for Don @ FBO?
[Re: Dabee]
#833367
10/19/10 01:48 PM
10/19/10 01:48 PM
Von
NE Oklahoma
Good Luck...... ![](/ubbthreads/images/graemlins/eyes.gif)
