ET streets: 255/60/15 vs 275/60/15?
#832701
10/18/10 10:10 AM
10/18/10 10:10 AM
Posts: 2,309 Tomorrow.
Damned67
Tomorrow.
Hi All, Seems like I'm on a role for a wheel/tire thread on each forum! In a heavy car (67 Belvedere), how much traction will I be giving up with 255/60/15 vs 275/60/15? The Mickey Thompson site says that theres 0.5" difference in tread width (although measured on different size rims). 255s should fit without too much of an issue, whereas opinion is mixed on whether the 275s will fit without rolling the inner lip. cheers!
Re: ET streets: 255/60/15 vs 275/60/15?
[Re: Damned67]
#832704
10/18/10 09:12 PM
10/18/10 09:12 PM
Damned67
Tomorrow.
I'llhave to get out and try to measure up the wheel well. I do seem to recall that there was a lot of room behind the wheel where I could go for a deeper backspace. Anyone here run something similar on a 67 B-body? My issue is that I live in Oz, so with shipping costs/time etc, I can only afford to do this once, so I need to get it right the first time. Cheers!
[Re: Damned67]
#832705
10/19/10 06:14 PM
10/19/10 06:14 PM
Posts: 2,464 Sydney,Australia
tex013
Sydney,Australia
SR440 here in Sydney runs 275's on a 67 coronet.darned tight,i'll see if i can measure it later today
Tex
New best ET 10.259@129.65 . New best MPH 130.32 Finally fitted a solid cam, stepped it up a bit more 3690lbs through the mufflers New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm Power by Tex's Automotive
[Re: 572B1]
#832707
10/19/10 10:16 PM
10/19/10 10:16 PM
Posts: 4,319 Puyallup, WA
StealthWedge67
Puyallup, WA
Post more about your combination, and how fast you plan on going. B-Body's stick pretty good.
[Re: StealthWedge67]
#832708
10/20/10 12:47 AM
10/20/10 12:47 AM
Damned67
Tomorrow.
Good point. Here's the combo (cut and paste from an old thread): "A .030 over 440 block with Indy aluminium main caps and a Callies 4.25" crank, Oliver billet rods and Diamond pistons, giving a compression ratio of 10.4:1. On top is a pair of E'brock heads with some minor work, Indy rockers, and a 0.587/0.593 287/294 cam, under an M1 intake and 1050 Dominator. Downstream is a Mopar 175K converter and a 3.55 rear end, and 'huge' 205/70/14 tires."
That combo (including those tires!) has taken me 12.54 @ 114. Low to mid-11s would be nice. I know it needs a whole lot more than just tires, but the tires are a starting point.
Cheers!
[Re: Damned67]
#832709
10/20/10 02:24 AM
10/20/10 02:24 AM
StealthWedge67
Puyallup, WA
Sounds like a strong combo, somewhat suprised you're only seeing 114mph. But, 114 still shows enough horsepower to get pretty deep into the 11's. You don't mention anything about the rear suspension, but even with just good stock springs, an effective set of traction bars, and a set of ET streets, A footbraked B-Body should stick at that power level. Ultimately, It's your call. I sorta think that either tire will make that combo go. I too have a 67 Satellite, that runs about what you are now, and have the same dilemma (why I've been following your thread). I'm going with 255's, because my car is pretty nice street car and I don't want to deal with rubbing issues. If it was a strip only car, I'd be more willing to squeeze the 275's in, but thats me. Please keep us posted on what you find, either way.
