Head dowel pin #832267
10/17/10 08:34 PM
10/17/10 08:34 PM
Canada
69 GTX Offline OP
69 GTX  Offline OP
Canada
Well while replacing my head dowel pins on my 440 I must have had a brain malfunction because I put the first one in the hole at the front of the engine just below the place it should go, it slipped in and now I can not grap it with anything. Is this hole a oil supply for the rockers ,anyone ever had this problem before?
Re: Head dowel pin [Re: 69 GTX] #832268
10/17/10 08:45 PM
10/17/10 08:45 PM
Under My Car
Mopar_Country Offline
Under My Car
Can you see it? Is it still parallel with the hole? What have you tried?
Re: Head dowel pin [Re: Mopar_Country] #832269
10/17/10 08:53 PM
10/17/10 08:53 PM
Canada
69 GTX Offline OP
69 GTX  Offline OP
Canada
Its just level with the block, I tryed to pull it with a set of side cutters but could not get them to grip
Re: Head dowel pin [Re: 69 GTX] #832270
10/17/10 08:56 PM
10/17/10 08:56 PM
SW Fla.
CYACOP Offline
CYACOP  Offline
SW Fla.
Clean the oil of it with some MEK or carb cleaner then JB Weld a handle on it and pull it back out. That is if a good magnet won't wiggle it back out.
Re: Head dowel pin [Re: CYACOP] #832271
10/17/10 08:58 PM
10/17/10 08:58 PM
superglue
Re: Head dowel pin [Re: 69 GTX] #832272
10/17/10 08:58 PM
10/17/10 08:58 PM
Canada
69 GTX Offline OP
69 GTX  Offline OP
Canada
Can anyone tell me if this is a oil supply gallery for the rockers
Re: Head dowel pin [Re: 69 GTX] #832273
10/17/10 09:02 PM
10/17/10 09:02 PM
Under My Car
Under My Car
If it's somewhat loose try a shop vac and see if you can suck it out.
Re: Head dowel pin [Re: 69 GTX] #832274
10/17/10 09:07 PM
10/17/10 09:07 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Oil supply to the rockers is the raised area in the valley @ the #4 cam bearing.. I believe you have plugged a coolant passage..
Re: Head dowel pin [Re: 1_WILD_RT] #832275
10/17/10 11:49 PM
10/17/10 11:49 PM
Canada
69 GTX Offline OP
69 GTX  Offline OP
Canada
Well nothing else is working so I think I will try to weld a small stud to it and then pull it out
Re: Head dowel pin [Re: 69 GTX] #832276
10/17/10 11:52 PM
10/17/10 11:52 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Do you have access to a stud gun used in bodywork? ideal tool for the job...
Re: Head dowel pin [Re: 1_WILD_RT] #832277
10/18/10 01:46 AM
10/18/10 01:46 AM
Canada
69 GTX Offline OP
69 GTX  Offline OP
Canada
Thanks, will give it a try if I can find one
Re: Head dowel pin [Re: 69 GTX] #832278
10/18/10 01:58 AM
10/18/10 01:58 AM
Central Coast, Calif.
Snoopy Offline
Snoopy  Offline
An arc welder will also work. Turn off welder and touch the welding rod to the end of the dowel pin. With the rod still in contact with the pin, have someone turn the welder on and off. The rod should stick to the pin. Pull the rod and pin out of the hole.
You may have to increase the current, but not the duration to make this work.
Re: Head dowel pin [Re: Snoopy] #832279
10/18/10 03:17 PM
10/18/10 03:17 PM
Canada
69 GTX Offline OP
69 GTX  Offline OP
Canada
Thanks to everyone for all the ideas to remove this dowel pin, what finaly worked was Snoopys idea with the arc welder, took six trys but it came out. What a relief to get it out, Thanks again, Rodger
