Re: B body torque boxes
[Re: rtpete]
#831302
10/16/10 08:13 PM
10/16/10 08:13 PM
Posts: 18,157 Mass
DAYCLONA
Mass
Go right to the source AMD, they have a vast array of floor gussets/brackets, frame members, brackets, torque brackets, etc, inside, outside and under the car,...also some members here are dist. for the AMD line,...I'm sure they'll chime in
[Re: badblack68]
#831304
10/16/10 09:16 PM
10/16/10 09:16 PM
Posts: 2,592 None
71rm23
None
Speaking of torque boxes. Are they welded to the front, just inside of the frame rails? Or at all four corners, inside the frame rails? Also, I looked at AMD site and didnt see them. Its for a 71 Roadrunner.
[Re: 71rm23]
#831306
10/17/10 04:10 AM
10/17/10 04:10 AM
Posts: 1,168 Vancouver, WA
MoparMarq
Vancouver, WA
No, outside frame rails, but inside rocker panel seams. This pic is of the left rear torque box on my '72 RR. It is looking rearward on the driver's side of the car along the seam of the rocker panel and floor panel. The holes at the top are to make it easier to get to the top two nuts on the leaf spring hanger.
[Re: MoparMarq]
#831307
10/17/10 10:17 AM
10/17/10 10:17 AM
Posts: 2,592 None
71rm23
None
Thanks Moparmarq!
