Re: How many hours does this take...
[Re: cudastruction]
#829722
10/15/10 09:05 AM
10/15/10 09:05 AM
Posts: 3,060 Western New York
sixpackbee
Western New York
There have been cars that took me 15 minutes to hang one door and an hour for the other side. I would say anywhere between 4 and 8 hours for me. I do work alone and am a perfectionist so the hours are more than some.
1959 Bugeye Sprite 1967 Charger Black L code 1967 Coronet R/T Convert Green 440 auto bought from original owner 1968 Charger R/T Bronze 440 4 spd console AM/FM 1969 Super Bee WM21H B5 A40 D21 N96 1969 Barracuda Formula S 340 Convert pilot car 1969 Hemi Road Runner RM23J D32 Omaha orange 4.10 Dana N96 N85 1970 Super Bee WM23N FE5 V1X 3.91 axle package, N96 1970 Road Runner RM21N B3 V1X D13 1971 MG Midget 1971 Road Runner RM23H GW3, A57 1972 Road Runner RM23P FY1, D21
[Re: sixpackbee]
#829723
10/15/10 09:34 AM
10/15/10 09:34 AM
Posts: 2,304 WI
RestoRick
WI
[Re: anlauto]
#829725
10/15/10 09:48 AM
10/15/10 09:48 AM
Challenger 1
Cincinnati, Ohio
I guess I don't get it. How variable can the amount of hours be to hang doors, a hood, fenders and a valence. I understand getting all the gaps "perfect" is subjective but how variable can those hours possibly be?
Lets assume this...the rust damage has been cut out and repaired correctly and all body measurements are within 1/4" of factory specs. Does that reduce the "variables" and make this question a little more reasonable?
I would guess you've never done this before?
I've spent half a day aligning the hood only to find out the front end was out of square....
I would say 8 hours if everything goes easy and the hydraulic power pulley stays in the cabinet..
4 hours is on the low side, if 2 guys do it then 4 hours is 8 hours...
[Re: cudastruction]
#829727
10/15/10 01:21 PM
10/15/10 01:21 PM
Posts: 3,287 West Coast, USA
jbc426
West Coast, USA
They also have to know to start i.e. aligning the rear of the doors to the front of the quarters and work forward. Mine were original pieces and it still took about 12 hours to align the doors and front-end. It came out much better than the factory alignment though....
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
[Re: jbc426]
#829728
10/15/10 01:46 PM
10/15/10 01:46 PM
Posts: 15,995 RI Deep in the rust belt
chargervert
It sounds like you have a shop that is doing things the right way. Unless they charge you some crazy amount of money. Tell the shop that you want to be notified if they think the job will take more than 4-6 hours. If they are having issues aligning the panels,you want to be informed. I will tell you that 70 - 74 Cuda's are more differcult to align the nose on than a Challenger is,due to the headder panel. The fenders and headder panel all have to fit as a unit,and the hood has to jive with all three peices. The Challenger gives you more play to move the fenders and hood around.
70 Charger R/T SE 472 Hemi
70 Charger R/T convertible
70 Charger R/T V Code Sixpack
69 Charger R/T SE Sunroofcar
68 Charger 383
68 Charger 318
71 Charger R/T
70 Challenger convertible
71 Challenger convertible
71 Cuda 340
09 Challenger R/T Classic
[Re: domingo]
#829732
10/17/10 04:18 PM
10/17/10 04:18 PM
Posts: 417 Caledon, Ontario
smac77
Caledon, Ontario
This is an easy one to answer.... it'll take anywhere between one hour with two guys if everything lines up bang on first shot with zero adjustments...(not very likely) to one hundred hours (or more)if the guys welded the car together improperly without fitting all the stuff first, and it all needs to be redone.... don't laugh, I'm fixing someone else's night-mare right now in my shop. The previous "shop" did the back end of the car so poorly, they cut a 2" inch section out of the valance to try and get it to fit between the new 1'4's they put on crooked... needless to say, all of the work this shop did is now sitting out back in my scrap metal pile... My point is... it just takes the time it takes to do it right... and no offence to anyone who's tried to throw in their on this but,none of us knows how much rust repair work has been done, or the skill of the guys who did it. The correct answer can only come from the guys working on it...
Restoration, Sales and Canadian Distributor For: AMD Sheetmetal Wizzard Direct Fit, Bolt In Aluminum Radiators Legendary Interiors SSBC & Wilwood Brakes Control Freak Suspensions Fine lines Tubing and many more... www.macleanclassics.com
[Re: elitecustombody]
#829735
10/18/10 01:57 PM
10/18/10 01:57 PM
Posts: 18,582 Rust Belt, SW PA
Silver70
Rust Belt, SW PA
Why didn't they fit all the panels before epoxy?
Not sure why your asking, but the reason I would epoxy the parts first is so there wouldn't get rusty from handling them or sitting. When I striped a panel, blast and strip, either/both its epoxied right away. I do my body work over it also.
68 Road Runner, 69 Belvedere, 71 Challenger Vert 340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z 66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
