Who's running SB turbo setups #827585
10/11/10 09:34 PM
10/11/10 09:34 PM
kentucky
roadrunner7020 Offline OP
kentucky
I recently purchased a 72 challenger I am going to run a small block 360 and potentially a single turbo setup and a low numerical gear like 323s. My first question is about what block to use I have the option to buy both an LA 360 and a 5.9 magnum 360 out of a ram to start with. I know the magnum motors are roller cam blocks but if I'm looking to build around a 550 horsepower boosted small block what would be my best choose the LA or the magnum? I know boosted motors like different grind cams so the roller setup may hurt me there.. Is the magnum bottom end any better then the LA? If it becomes in the budget it will most likely get aftermarket aluminum heads as well. Also what's better to run custom headers or a good set of logs modified? Also what size turbo? This may just be a pipe dream but I'm truly interested in building this setup to cruise not all out race if meeping power steering and or air that would be amazing but i doubt it ebodies and room dont exactly go together thanks for your help in advance Moparts members
Re: Who's running SB turbo setups [Re: roadrunner7020] #827586
10/15/10 01:43 PM
10/15/10 01:43 PM
Oakland, MI
dizuster Offline
dizuster  Offline
Oakland, MI
I'm in the middle of a 360 build right now. '91 block (basically magnum). Hydraulic roller cam (you can get a regrind from bullet for $125, and it's allredy on a wide lobe sep because of the factory EFI, so it works great on a turbo).
I have stock crank, stock rods with good bolts, decent forged pistons (probe's), good rings, good head gaskets, iron '308 heads (slightly ported), old torquer 340 intake, with a home modified E85 blow through carb.
I have a S400 75mm turbo (CHEAP, like $600 brand new). I'm using magnum manifolds, with my own hot side piping.
If this thing doesn't make 550hp, I must have forgotten to put 4 of the pistons in it...
550hp is CAKE...
Re: Who's running SB turbo setups [Re: dizuster] #827587
10/18/10 11:18 AM
10/18/10 11:18 AM
Ontario, Canada
rtspeeddemon Offline
Ontario, Canada
I run a turbo set-up on my 360 ,magnum block stroked to a 408.
Re: Who's running SB turbo setups [Re: rtspeeddemon] #827588
10/18/10 03:51 PM
10/18/10 03:51 PM
Houston, Texas
TheOtherDodge Offline
Houston, Texas
Almost complete with my project. 5.2L Magnum stroked with home ported Eddy Heads. Im running a Hughes hydraulic roller, and like mentioned above, it has a 114 LSA because of the PCM so it will be fine for blown app.
The project will be super streetable but still put down 600 rwhp on pump gas.
Re: Who's running SB turbo setups [Re: TheOtherDodge] #827589
10/19/10 01:26 AM
10/19/10 01:26 AM
kentucky
kentucky
Thanks guys I have a factory la 318 motor on hand. How do you like the 392 setup? How would a forged 392 setup on around a 75-80mm turbo and blowthrough carb setup run on a 3400 lb challenger? Would I be better finding a 360? What kind of compression would be best on around 91-93 octane? How are you all routing these single turbo setups? Lastely who sells a good forged bottom end for sb mopars? Sorry for so many questions I just want to know anything I can before I start into this all
Re: Who's running SB turbo setups [Re: roadrunner7020] #827590
10/20/10 09:31 AM
10/20/10 09:31 AM
Houston, Texas
Houston, Texas
At 3400 lbs, you are about the same weight as me. For pump gas, you need to stay around 9:1 with a stroker so it won't be too lazy off boost. If you haven't done anything yet, I would start off with a 360 block simply for the xtra cubes over a 318 block. My truck came with the 392.
Routing the turbo in an Ebody engine bay is easy...no issues with that. You have plenty of room for ac, radiator and intercooler.
For headers, I found me a used set of stainless shorties and flipped them side to side. Works great! No need for custom ones at our hp levels.
I would snag a 360 magnum motor from a junkyard, since they come with factory rollers. There are tons of them. You can use the AC from them along with the condensor, etc. Then stroke it!
Here are my goals, as an example: 100000% streetable, retain AC, PS, PB, super quiet like your grandma's Caddilac, pump gas, be able to drive it 200 miles on a trip, 600 rwhp (about 700 at the crank, limited to the factory block).
Here are a few specs on the build:
Engine
Block #: 53006-1, tall fill, plataeu finish on hone with torque plate (525, 623, 818 stones), 3.094 bore, .05 deck height
Edlebrock (61769) Performer RPM heads, 2.02 Stainelss/1.60 Inconel, intake port opened, exh port opened, head bolt bulge thinned, 3 angle valve job
Crower (87055D-1) retainers
Manley (11599-8) Enconel 1.60 exhaust valves
Crower (68340) 1.520 springs
Comp Cams (611-16) 11/32 keepers
ARP Head studs
ARP Main studs
Program (M340-C4A) Billet 4 bolt main caps (only 2 used)
JE (294482) forged pistons w/.927 pin
Scat (6620021) 4340 forged, 2.100 x 6.200 H-beam rods
Harland Sharpe (5/16 studs) 1.6 Rockers
Mopar Lifters
Comp Cams (7050-16) chromemoly pushrods
M-1 4 bbl Intake (P4532587), intake port opened, plenum roof raised
Cometic (C5554-040) MLS .040 head gaskets
Clevite (CB-663 HN) High Performance Rod bearings
Clevite (MS540H) Main bearings
Comp Cams (2103) Timing set
Summit (SUM-C4277) SFI Balancer
Hughes (HER 2836 ALN-14) hydraulic roller cam, .544/.555, 228/236, 114 LSA
Total Seal (09023940) 1/16, 1/16, 3/16 moly top ring, iron second ring, std tension oil ring
Turbo:
76 mm, .86 A/R
2.5" hot/cold side
3" downpipe
24x8x2.5 intercooler
Tial 44 mm wastegate
BBK 75 mm throttle body
Tial 50 mm bypass valve
custom 90 mm air hat
Electronics:
MSD 6AL
MSD 2 step rev limiter
MSD (8534) Billet Distributer (Ford cap, 8421 rotor)
Classic FAST Engine Management System
Fuel System
Aeromotive (11101) A1000 Fuel pump
Aeromotive (15404) Regulator
Custom fuel rails (Stubbs Racing)
83 lb injectors
Exhaust System
Magnaflow (12289) muffler
3" piping with tail pipe
Specs
Head torque: 125 w/gear oil
Mains torque: 125 w/gear oil
Rods torque: 75 w/gear oil
Rod Side Clearance: .018, .023, .013, .020
Piston to head: .043
Intake Valve: .225
Exhaust Valve: .250
Top Ring gap: .025
Second Ring gap: .029
Total Bob weight: 1808
springs: 1.890 installed height, 155 lbs seat, 405 lbs @ .580 lift
Transmission
727 Torqueflite w/ red alto racing clutches
ATI 4500 Converter
Mopar ProTime Transbrake
Chassis:
Moser Dana 60 w/ Motive 3.54 gears
Moser Spool
Moser Axles
Moser Rear end cover
QA1 Ladder Bars w/coil overs
QA1 rear shocks
5 lug disc conversion in front
Wilwood rear disc brakes
1350 U joints with Precision 330-10 U bolt straps
Misc
NGK R5671A-10 (5820) plugs at .025 gap
Fram PH16 filter
Quaker State 10W30 conventional oil
Re: Who's running SB turbo setups [Re: TheOtherDodge] #827591
10/21/10 10:38 AM
10/21/10 10:38 AM
kentucky
kentucky
Couple questions :
Super quiet wig 3 inch exhaust how is that going to work?
4500 stall and 354 gears how's that going to act on the highway my 3500 had slippage in my roadrunner.
Where did you get a good piston to run 9:1 I'll prolly build a 9:1 408 drive it a little while I piece the turbo system together I'm finding alot of 9.4:1 pistons with running eddy heads on the stroked kits I'm seeing.
Re: Who's running SB turbo setups [Re: roadrunner7020] #827592
10/21/10 12:21 PM
10/21/10 12:21 PM
Houston, Texas
Houston, Texas
"Super quiet wig 3 inch exhaust how is that going to work?" First, a turbo will muffle quiet a bit to begin with. But to make it extremely quiet I ran 3" to a big 3" Magnaflow and 3" tail pipe all the way out the back of the truck. The tail pipe all the way out from under the vehicle is the key!
"4500 stall and 354 gears how's that going to act on the highway my 3500 had slippage in my roadrunner" Not sure how this is going to work yet because I don't have much seat time in it yet. I am going to try it, since I had it already and may have to change it later. A 3000 may be more appropriate. Just have to wait and see.
"Where did you get a good piston to run 9:1" My compression is closer to 9.3:1. It is a custom JE piston for a turbo application with the ring pack lower on the piston.
Re: Who's running SB turbo setups [Re: TheOtherDodge] #827593
10/25/10 10:40 AM
10/25/10 10:40 AM
kentucky
kentucky
Thanks for the responses where did you get the flange for the turbo? Also where did you get those valve covers they look great!!
Re: Who's running SB turbo setups [Re: roadrunner7020] #827594
10/25/10 05:55 PM
10/25/10 05:55 PM
Houston, Texas
Houston, Texas
I can ask the turbo builder where he got them...
Im not sure about the valve covers because they came with the truck when I bought it.
Re: Who's running SB turbo setups [Re: TheOtherDodge] #827595
10/30/10 09:00 AM
10/30/10 09:00 AM
Victoria, Australia
Ian Offline
Ian  Offline
Victoria, Australia
in the buld of a 408 twin turbo and this ones a mates tuff 408 we made an honest 1200+ with a , std block , edelbrock heads just gasket matched , 8.2:1 comp on meth with a single y2k 88mm.
did 5 seasons without pulling the sump & when we did everything was perfect , showed 8% leakdown cold on the worst cyl .
we ran a copper gasket with "o" rings in the heads & reciever grooves in the block
1.37 60 ft [email]6.0@113[/email] [email]9.57@141[/email] 408 glide 3550lbs
new video http://www.youtube.com/watch?feature=player_embedded&v=Xvq3ZObywQE
Re: Who's running SB turbo setups [Re: Ian] #827596
11/02/10 05:38 AM
11/02/10 05:38 AM
Australia
gg408 Offline
gg408  Offline
Australia
Here's mine
Std LA 360 block, 410ci, W2 heads, ARP studded and short filled, BWS480 turbo, C&S 800 blowthrough carb and Air/Water IC
Hoping to make around the 850fwhp mark, anything over that will be a bonus.
Should be up and running in the new year I hope.
Cheers
gg408
Re: Who's running SB turbo setups [Re: gg408] #827597
11/02/10 09:52 AM
11/02/10 09:52 AM
Houston, Texas
Houston, Texas
"make around the 850fwhp"
You really think your block will hold up to that power? What else have you done to the block? The turbo will certainly make the power...
Re: Who's running SB turbo setups [Re: TheOtherDodge] #827598
11/02/10 08:15 PM
11/02/10 08:15 PM
Oakland, MI
dizuster Offline
dizuster  Offline
Oakland, MI
I was thinking the same thing. What are you trying to see if you can make 850fwhp with that combo on 5psi?
That thing BETTER make 850hp...if not you must have forgotten 3 of the pistons when you built it...
Re: Who's running SB turbo setups [Re: dizuster] #827599
11/03/10 07:00 AM
11/03/10 07:00 AM
Australia
gg408 Offline
gg408  Offline
Australia
I read a certain post on unlawfull section were Ryan built a W9 headed 48deg R3 engine with way more exotic internals and cam than what i have and it made just over 1070fwhp so I think with what I have I'm being realistic when I say 850hp.
My engine is only a std 360 block with short fill hard block,Arp main studs, Eagle 4" steel crank, Eagle H-beam rods, Arias forged pistons,
FT Solid cam 235@.050" 114 lobe sep and .525" lift, home ported W2s Indy intake C&S 800 carby Arp head studs Cometics and HS rollers.
If I make 850 with this eng which i should I'll be happy.
Later I will build the right eng for the bigger HP.
Will the block handle the pwr only time will tell.
I belive it will as turbo eng from what I belive are not as hard on the bottem ends and Nitrous engines. Having said that I have seen some nasty breakages as well with turbos.
As for leaving some pistons out I might have to as it has been a long time since I have driven a fast car.
Any input on the build would be great as I am open to suggestion and help.
Cheers
gg408
Re: Who's running SB turbo setups [Re: gg408] #827600
11/03/10 09:24 AM
11/03/10 09:24 AM
Houston, Texas
Houston, Texas
Making 850hp is not a problem. I don't think your block will last long though. That is why I am limiting mine to 700-720.
Re: Who's running SB turbo setups [Re: gg408] #827601
11/03/10 09:55 AM
11/03/10 09:55 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
FT Solid cam [Email]235@.050"[/Email] 114 lobe sep and .525" lift, home ported W2s Indy intake C&S 800 carby Arp head studs Cometics and HS rollers.
Cheers
gg408
I don't see you making 800hp with that engine. Not enough cam, or head. My buddy has a 392ci 360 w/ worked W5 heads a much larger 720 roller cam and he's pushing 12lbs of boost (single 100mm turbo) and he's around 850. He runs in the mid-8's chasis Plymouth TC3. The car has run as fast as 174 in the 1/4 and has more in it.
Re: Who's running SB turbo setups [Re: gg408] #827602
11/03/10 11:02 PM
11/03/10 11:02 PM
State College, PA
RyanJ Offline
moparts member
RyanJ  Offline
moparts member
State College, PA
Cheers
gg408
My turbo (S480, W/ non race cover) was way outside it's efficiency range on motor that made 680HP/590TQ N/A
I'm ordering a new Garrett GT91 Thumper with 1.0 AR tomorrow from Forced Inductions & am planning on re-dynoing it in 2 weeks assuming I can get my hands on 10 gallons of C16 in time. May also try a 1.32 AR on it as well... Will have EGT sensors in the turbo headers this time to monitor EGT's under boost & added a crank trigger for more precise timing changes. Also adding a dual methanol injection system, injecting into the hat & the turbo to help with inlet temps. I think we'll see 1200 without too much difficulty... I may push it into the 1300 range if I'm feeling confident after hitting 1200. We'll see, I don't need to/want to go crazy with it, just want to get some nice baseline wastegate/psi-power settings for when it goes in the car, but those kind of power #'s get addicting when it is on dyno & it is so easy to make simple changes & watch #'s skyrocket.
Re: Who's running SB turbo setups [Re: Mr.Yuck] #827603
11/04/10 07:57 AM
11/04/10 07:57 AM
Australia
gg408 Offline
gg408  Offline
Australia
Cheers
gg408
I would have to say that your buddy is making a lot more than that unless his car is 2000lbs, but I could be wrong.
Well I can give you an example were I have a mate making 840fwhp with 355ci Aussie Holden engine and a s400 with the same cam specs and blow through at 17lbs of boost.
Car comes in at 3300 lbs with driver and has run best 144mph in the 1/4.
In the car it did only showed 720 before it melted a piston.
There are more examples that I have seen and based my build on that are around the same specs.
I don't think it will be easy but I do belive it can be done.
As for the block I would rather trash an LA block than a R3, the LA blocks are much cheaper.
Cheers
gg408
Re: Who's running SB turbo setups [Re: gg408] #827604
11/04/10 08:21 AM
11/04/10 08:21 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
Not sure what it weighs...maybe 2600-2800? It's tube chassis car but it's all steel except the hood. Good luck w/ the build. What ever the numbers, it will be fast.
