Adjusters Cracking as I set the Lash.....Nice Quality
#825252
10/08/10 09:08 PM
10/08/10 09:08 PM
Posts: 12,394 Taxes & Virus's R-US, NY
Dragula
So I get my new push rods and my nice hold down kit to use with the CRANE gold rockers I have had sitting on my shelf for some time, and as I start setting the lash on my 360 hydraulic cammed motor, I hear a crack. Back the rocker stud all the way out, and the jam nut is locked on the adjuster big time.
I get it loose, and all the threads peel off like nothing. No spares, but I tried to set the rest, and two more cracked before I even finished....Just lovely. I guess the green truck is done for the season, tomorrow was TNT....What junk!
Re: Adjusters Cracking as I set the Lash.....Nice Quality
[Re: Dragula]
#825253
10/08/10 09:43 PM
10/08/10 09:43 PM
Posts: 16,487 On the run…
BloFish
On the run…
How long have they been sitting?
It really doesn't matter whether you win or lose… as long as you look good doing it!
‘65 A100 ‘69 ‘Cuda ‘73 Vega GT ‘06 Mega Cab ‘14 Mercedes SLK
[Re: Dragula]
#825255
10/08/10 10:22 PM
10/08/10 10:22 PM
Posts: 1,093 Long Beach, CA
Mike Swann
Long Beach, CA
Is it the rocker body or the nut that is cracking?
Which threads? the adjuster or the rocker body?
8.30's @3400 lbs
[Re: Dragula]
#825257
10/08/10 10:40 PM
10/08/10 10:40 PM
Posts: 3,544 Syracuse,NY
CompWedgeEngines
Syracuse,NY
Consider yourself fortunate..most of those bad Crane screws broke AFTER the engine ran...and boogered up many a engine.
RIP Monte Smith
[Re: Eric]
#825262
10/08/10 11:24 PM
10/08/10 11:24 PM
Posts: 3,354 ohio
HEMIDARTS
ohio
Smith Bros....
My gold cranes were junk!!!! I ordered up a set from smith bros. They are very nice!!! and cost $75.00 Infact they were the cheapest thing on the motor, but smith bros makes a very nice piece!!
[Re: mistress]
#825264
10/08/10 11:39 PM
10/08/10 11:39 PM
Posts: 587 San Clemente, ca
enelson
mopar addict
mopar addict
San Clemente, ca
I run hughes rockers in my BB. Over .700 lift and over .550 spring rate. never had any problems ever. I run the valves every week and they don't need it. (never any loose)they are a little more than the gold but you get what you pay for. just my 2 cents worth.
I may pick up some of those for the shafts + improved oiling over the cranes...
mine are ok but there was a few runs of those bad adjusters which caused lots of issues...
[Re: Mike Swann]
#825267
10/09/10 09:55 AM
10/09/10 09:55 AM
Dragula
The adjusters. The threads just crack right off...Heck, I didn't even have them tight yet, just snug.
[Re: Dragula]
#825269
10/09/10 11:45 AM
10/09/10 11:45 AM
Posts: 6,847 Missouri
StrokerPost
Missouri
I know there were alot of guys complaining about them a few years back. I, like others here, took the Crane adjusters and pitched them when they were still new in favor of the Smith Bros type. I have NEVER liked those narrow Crane nuts, mostly cuz there so easy to slip off of with your wrench.
[Re: StrokerPost]
#825270
10/09/10 02:17 PM
10/09/10 02:17 PM
Dragula
Yeah, I am missing some skin off my knuckles too. I put the stock ones back on and put it in the trailor for the winter. We will see what I get done on it this year.
