Heater core 1970 b body interchange? #824393
10/07/10 04:10 PM
10/07/10 04:10 PM
kentucky
roadrunner7020 Offline OP
kentucky
Sorry If this comes up as a delist tried to post from my phone earlier. I have a 1970 b body air car however the air parts in the engine bay are gone and my heater core is bad. Can I install a standard non ac core in my heater box and use just the heat I will later install a classic auto air system maybe next season but I want heat for fall and the correct ac heater core is nearly 300 vs 58 or so for heat only. Will they interchange without modifications? Thanks in advance
Re: Heater core 1970 b body interchange? [Re: roadrunner7020] #824394
10/07/10 04:15 PM
10/07/10 04:15 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
No , the cores are completely different .
Re: Heater core 1970 b body interchange? [Re: JohnRR] #824395
10/08/10 10:37 AM
10/08/10 10:37 AM
kentucky
kentucky
Thanks in that case is it cheaper to redo mine or can that be done? I'd really like heat in the next few weeks but if not I guess a jacket will work !
Re: Heater core 1970 b body interchange? [Re: roadrunner7020] #824396
10/08/10 11:01 AM
10/08/10 11:01 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
You'll have to remove it to see why it's leaking , there are two cores connected by hoses and such plus a valve , almost anything in there could be leaking .
Re: Heater core 1970 b body interchange? [Re: roadrunner7020] #824397
10/08/10 11:11 AM
10/08/10 11:11 AM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Nothing interchanges between A/C and non A/C heater boxes without major firewall changes.
A competent radiator shop can probably repair most anything wrong with the core
Re: Heater core 1970 b body interchange? [Re: roadrunner7020] #824398
10/09/10 06:36 PM
10/09/10 06:36 PM
Colo Springs, Co
dragaddict Offline
super street
dragaddict  Offline
super street
Colo Springs, Co
If you are trying to retain a stock look it is tough. I have a 69 Coronet non R/T or numbers car that I can cut up to my hearts delight so I pulled all the factory air and heater junk out and shaved a couple hundred pounds off the car. Vintage Air has a street rod universal heater that plugs into heater hose like stock that is small enough under the dash to also mount the MSD box under there. Plenty of heat for the wife with my window low enough to listen to the pipes. Whole deal was less than $200.00 at local street rod shop.
