Re: Numbers behind rear seat
[Re: 493RT]
#822835
10/05/10 11:06 PM
10/05/10 11:06 PM
Posts: 21,526 N.E. OHIO, USA
A12
N.E. OHIO, USA
Do anyone of you guys know what the numbers behind the rear seat are relating to ?. Car is a 68 Coronet.
"G" St Louis plant by chance...?
[Re: A12]
#822836
10/05/10 11:13 PM
10/05/10 11:13 PM
A12
N.E. OHIO, USA
My '68 rr, it's a "G" St Louis built car......now let's all think; are there any options that may use any of those numbers as codes or are they an inspector's code?
[Re: Firepowerflyer]
#822839
10/06/10 12:13 AM
10/06/10 12:13 AM
Posts: 417 Caledon, Ontario
smac77
Caledon, Ontario
this one was over in the spring green post...
Restoration, Sales and Canadian Distributor For: AMD Sheetmetal Wizzard Direct Fit, Bolt In Aluminum Radiators Legendary Interiors SSBC & Wilwood Brakes Control Freak Suspensions Fine lines Tubing and many more... www.macleanclassics.com
[Re: 6bblgt]
#822844
10/06/10 05:59 PM
10/06/10 05:59 PM
A12
N.E. OHIO, USA
I wonder if it is:
Roof Paint * Body Paint * Upper Door Frame Paint
Does anyone have fender tag info for the above pictured cars?
My '68 rr (photo with 12 12 20) is FF1 mist green metallic with no vinyl roof (FF1 roof) and upper door paint is medium/dark green metallic. The dash is Catawba green a dark (flat/egg shell green) but not that close to the upper door green. The upper door green is close to '69 F8 green IMO. Here's my '68 rr with the 12 12 20. The SPD just FYI is April 2, 1968. I have the original fender tag BTW.
MikeR
[Re: A12]
#822847
10/06/10 11:09 PM
10/06/10 11:09 PM
Posts: 18,632 jersey shore
flypaper
I hate Texas
I hate Texas
jersey shore
my guess they would be a vendor id and maybe a date code of sorts i'm sure all the body panels were not stamped at the same place and came from differant sources..
[Re: A12]
#822848
10/07/10 08:24 PM
10/07/10 08:24 PM
Posts: 9,065 Milwaukee, WI
In_The_Pink
Milwaukee, WI
Wonder why the frist two numbers repeat?
8 8
12 12
14 14
Upper/lower body color/upper door panel color
Found this in a B5 blue '76 Aspen SE with a blue interior:
[Re: In_The_Pink]
#822849
10/07/10 08:35 PM
10/07/10 08:35 PM
A12
N.E. OHIO, USA
8 8
12 12
14 14
is that, is that B5 B5 ?? Why, why, the the double double ??
