Duster Driveshaft Length../6 to 318, 7 1/4 to 8 1/4 #820838
10/03/10 03:00 PM
10/03/10 03:00 PM
Leucadia, Ca.
V
vdriver Offline OP
vdriver  Offline OP
V
Leucadia, Ca.
Swapped out the original 7 1/4 for an 8 1/4 in our '70 Duster. Put the /6 - 904 combo back in for now; gonna upgrade to 318 - 904 in the near future.
Haven't shortened the driveshaft yet and only wanna have to do it once.
So, should the 'shaft length for the /6 - 904 - 8 1/4 be the same as 318 - 904 - 8 1/4?
Re: Duster Driveshaft Length../6 to 318, 7 1/4 to 8 1/4 [Re: vdriver] #820839
10/03/10 03:10 PM
10/03/10 03:10 PM
Lake Orion, MI
goldduster318 Offline
Lake Orion, MI
Yes, the 904's are the same length and sit in the same spot so the driveshaft is the same. Once you shorten it for the 8.25 you'll be set.
'70 Duster 470hp 340/T56 Magnum/8 3/4 3.23 Sure-Grip
Re: Duster Driveshaft Length../6 to 318, 7 1/4 to 8 1/4 [Re: goldduster318] #820840
10/03/10 03:49 PM
10/03/10 03:49 PM
Leucadia, Ca.
V
vdriver Offline OP
vdriver  Offline OP
V
Leucadia, Ca.
Cool!
Re: Duster Driveshaft Length../6 to 318, 7 1/4 to 8 1/4 [Re: vdriver] #820841
10/03/10 04:38 PM
10/03/10 04:38 PM
Oakdale CT
gdonovan Offline
gdonovan  Offline
Oakdale CT
Mine was 49.5 inches (904 with 8.25) u-joint center to center.
