Painting pinch weld #819936
10/02/10 01:01 PM
10/02/10 01:01 PM
Crook County, ILL
Mastershake340 Offline OP
Crook County, ILL
Looking for advice on painting the blackout on the pinchwelds of my '71 Challenger. Not masked off right? If I don't mask, I am concerned with overspray. Flat black or semi-gloss?
Re: Painting pinch weld [Re: Mastershake340] #819937
10/02/10 01:15 PM
10/02/10 01:15 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Here's the E bodie factory print.....FG/BJ or 70-1 Cuda/Challenger, take note to G series (1971) body colors for omission of PW blackout
Mike
Re: Painting pinch weld [Re: DAYCLONA] #819938
10/02/10 01:30 PM
10/02/10 01:30 PM
Crook County, ILL
Crook County, ILL
Thanks!
I don't see GK6 on the list so I need the blackout.
I suppose putting some tape loosely on the horizontal body panel surface above the pinch weld before spraying would do the trick, allow a little bit of overspray to get on that surface, but not too much.
Re: Painting pinch weld [Re: Mastershake340] #819939
10/02/10 03:29 PM
10/02/10 03:29 PM
Houston Texas
PAINT IT BLACK Offline
Got a CHIP on my shoulder
Houston Texas
Thought it was supposed to be brushed on with a 2" brush?
Re: Painting pinch weld [Re: PAINT IT BLACK] #819940
10/02/10 03:32 PM
10/02/10 03:32 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Both methods were used.
This one looks like a 4" brush was used, but I do not recall seeing anything that specifed what size to use anywhere.
Re: Painting pinch weld [Re: Alaskan_TA] #819941
10/02/10 03:45 PM
10/02/10 03:45 PM
Houston Texas
Houston Texas
I remember seeing some bulletin posted on Moparts a while back specifying a brush.... BUT it might have been in reference to red paint on rear drums...
Re: Painting pinch weld [Re: PAINT IT BLACK] #819942
10/02/10 04:48 PM
10/02/10 04:48 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
I used SEM Trim Black for the rad and pinch weld blackout. It seems like a good quality paint that should last.
Re: Painting pinch weld [Re: Mastershake340] #819943
10/02/10 08:40 PM
10/02/10 08:40 PM
USA
E
ECS Offline
David Walden
ECS  Offline
David Walden
E
USA
Hi Brad,
If you look at the drawing provided by Mike you will notice the small exploded diagram that references the "over-spray" and what is "permissible". It would be impossible to get an "over-spray" pattern if a brush were being used. Also notice just to the right of that section, the only mention of applying paint with a "brush" is for the 27 model or Convertible body style. I have documented vehicles (other than Convertibles) that used the "brush on paint" application and have even seen BOTH methods used (contrasting sides) for the same vehicle! Sometimes the employees doing the paint jobs chose convenience over the intended engineering specifications. If you do not have your original to use for a format and are attempting to be factory correct, defaulting to the Chrysler engineering specifications should leave you technically accurate. Good Luck!!
