Dana or 8 3/4.. I know.. I know, but just asking..
#818871
10/01/10 10:54 AM
10/01/10 10:54 AM
Posts: 4,283 Danville, NH
Mopar_Mike
Danville, NH
I am thinking of building a 650 hp hemi for my 67 Coronet drag car. Thinking of around a 4K stall and foot brake launches. I have a 742 case 8 3/4 with MW spool 3.91 gears and 35 spline axles and 1350 joint in the car now with cal-tracs. Do you think this rear could handle the hemi? I know put a dana in and forget-about it, but since my 8 3/4 is already in there thought I ask for opinions.
Thanks.
RS23L7 4-Speed
Re: Dana or 8 3/4.. I know.. I know, but just asking..
[Re: Mopar_Mike]
#818872
10/01/10 12:11 PM
10/01/10 12:11 PM
Posts: 10,542 BROOK PARK, OH
WILD BILL
BROOK PARK, OH
Unless your car is super light go with the dana
[Re: dragram440]
#818874
10/01/10 12:52 PM
10/01/10 12:52 PM
Posts: 989 WI, USA
67dodge67
mopar addict
mopar addict
WI, USA
Last time I was at the track with my 67 Coronet (470, 727, 3.91 w/ spool, drag radials, no spray), all steel/interior, after I got home I pulled the 742 8 3/4 apart to check and make sure all was good. Let's just say things happen in 3's. I will say this tho, I was happy that it lasted as long as it did. But, called Dr. Diff to set me up... now there's a Dana... and the rest is history.
[Re: Mopar_Mike]
#818875
10/01/10 01:17 PM
10/01/10 01:17 PM
Posts: 40 Washington
SuperStock68Dart
Washington
Spend the money once and be done with it, go with the Dana. The 8 3/4 will eventually break and will take the trans with, at least it did in my car. Dana has been in the car for 3 seasons have not touched it. 1.3 60's @ 3500#
[Re: SuperStock68Dart]
#818876
10/01/10 01:36 PM
10/01/10 01:36 PM
Posts: 1,058 bigfork mn
dragram440
bigfork mn
It is hard to spend the money once when the bolth of us already have 8 3/4's done. So its twice for us either way!!
67' charger 499 RB
10.57 at 127
[Re: dragram440]
#818877
10/01/10 01:38 PM
10/01/10 01:38 PM
dragram440
bigfork mn
where does a guy buy a dana? Any Idea on what they are going for?
67' charger 499 RB
10.57 at 127
[Re: dragram440]
#818878
10/01/10 02:21 PM
10/01/10 02:21 PM
Posts: 74,979 U.S.S.A.
JohnRR
U.S.S.A.
dr. diff can set you up , about 2k
[Re: JohnRR]
#818879
10/01/10 02:41 PM
10/01/10 02:41 PM
Posts: 989 WI, USA
67dodge67
mopar addict
mopar addict
WI, USA
Contact Dr. Diff... he's da man!
[Re: 67dodge67]
#818880
10/01/10 02:47 PM
10/01/10 02:47 PM
dragram440
bigfork mn
He set me up with all my 8 3/4 stuff.
67' charger 499 RB
10.57 at 127
[Re: Mopar_Mike]
#818882
10/01/10 02:55 PM
10/01/10 02:55 PM
Posts: 12,385 Taxes & Virus's R-US, NY
Dragula
Thanks.
We blew up 3 of them last year with our mild hemi....Oh, and one drive shaft!
Hemi's eat 8-3/4 rears....The fourth one is still alive under the car so far this year, but its not stock anymore, and two weeks ago, I bent all 10 of the 3" long wheel studs on it. Now it needs the 5/8" studs...
And this is a pump gas street car with a very mild hemi that I got to run 11.1 in. We put milder gears in it last week and went from 4.30's to 3.91's and it didn't even slow it up 2-tenths. The car weighs 4010lbs with driver. Its running low 11.30's on street tires, mufflers at that weight....
[Re: dragram440]
#818883
10/01/10 04:56 PM
10/01/10 04:56 PM
Posts: 3,414 Toronto
mshred
Toronto
Sell the 8-3/4 while its still in one peice and then the cost of the dana wont be so bad
[Re: mshred]
#818884
10/01/10 05:24 PM
10/01/10 05:24 PM
dragram440
bigfork mn
I would love to sell it but who would want one set up like this. If your going this route you might as well go with a 60. I was thinking of putting a 9" in it but to buy a good third member they arent cheap either. Maybe the 8 3/4 is broke now and thats what killed my trans.
67' charger 499 RB
10.57 at 127
[Re: dragram440]
#818885
10/01/10 05:33 PM
10/01/10 05:33 PM
mshred
Toronto
never know until you try
[Re: mshred]
#818886
10/01/10 07:00 PM
10/01/10 07:00 PM
Posts: 11,710 Portage,michigan
B3422W5
Portage,michigan
I upped the power on my old 3350 pound 70 Duster a few years back to where when i brought it out that year, it ran 10.30's off the foot. It last 4 passes and grenaded, took the tranny out as well. Went Dana, upped the power even more, started using a brake, and never a peep again.
Anybody with 650 horsepower in a B body that makes way more torque than a smallblock should not even think twice about getting that 8.75 out of there, selling it, and buying a Dana for it.
This situation is definately( and i dont mean this in a bad way) an out and out no brainer
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam Best so far, 10.40 @127 1/4 1.41 best 60 foot 6.60 at 103.90 1/8
[Re: Dragula]
#818887
10/01/10 09:46 PM
10/01/10 09:46 PM
Posts: 2,825 Sk. Canada
RemCharger
Sk. Canada
Thanks.
Bent all ten studs??? Maybe a torque wrench would help.
[Re: dragram440]
#818890
10/01/10 10:35 PM
10/01/10 10:35 PM
Posts: 43,129 Bend,OR USA
Cab_Burge
It depends of course just like many race parts, if you want all new with brakes the the price is more than if you buy a junkyard core and have it built it up I bought a junkyard core, Ford 3/4 ton pick up for $75.00, I bought new Moser axle ends for $125.00 with shipping, paid a local welder that had the narrowing jigs $125.00 to cut it down and weld the new ends and the old ladder bar brackets on it I bought a new Strange Engr.35 spline spool for it, right at $200.00 to the door. I reused the Strange Engr. 35 spline axles out of the 8 3/4 I had been running along with the complete rear brakes and I had to buy a pinion yoke, $130.00 w/ shipping. I have all the tools to set the pinion depth, backlash, press and remove the bearings and so on. I used a set of used 4:10 Dana gears out of another pick up rear end that I had sold to someone years ago that didn't want those gears and I did the labor on setting it up myself. Add the cost of the new bearings, seal and lube and it is still cheaper than a complete new one, the choice is yours. BTW, there is always someone who will buy your 8 3/4 parts, including the housing, if there not broken My car twisted the 8 3/4 housing up bad enough to rip the ladder bar bracket loose on the passneger side That happened on the starting line luckily, instead of when shifting into to 2nd or 3rd gear. The car did a immediate right turn into the other lane, and again luckily, I was a little bit late on the light and the other car was not there when my car went across into his lane I have seen cars totaled whern a part breaks during a run, don't take a chance on any parts if in doubt change it out
[Re: dragram440]
#818892
01/28/11 01:35 AM
01/28/11 01:35 AM
SuperStock68Dart
Washington
Let me know how much it cost's you to fix the 8 3/4 AND transmission when it breaks! I've been there done that and it's not cheap. When I decided enough is enough I got a Dana from a pickup, knocked out the tubes installed chrome moly tubes, Mark Williams 40 spline gun drilled axles, MW aluminum spool, MW housing ends and Richmond pro gears for 2400.00 3yrs ago. Of course you need to find a narrowing jig to use and do the work yourself! When I was done the Dana was only 3 pounds more than the 8 3/4 it replaced! You can still sell the 8 3/4 at this point.
[Re: dragram440]
#818894
01/28/11 07:11 PM
01/28/11 07:11 PM
Posts: 3,245 Between a rock & a hard place
cudadoug
Get a Dana from a pick up at Pick-n-Pull and have it narrowed, new ends, etc. You can reuse your axles if the same length my shorten them a tad...
[Re: dragram440]
#818895
01/28/11 07:15 PM
01/28/11 07:15 PM
cudadoug
Gosh I really hate to and sure don't want to beat a dead horse, but...9" phords break in heavy cars, too. Three words: Dana, Dana, Dana.
[Re: mshred]
#818897
01/29/11 03:00 AM
01/29/11 03:00 AM
Posts: 8,165 Left Coast
BobR
Left Coast
They sell and they're fine for street cars.
[Re: BobR]
#818899
01/29/11 04:51 AM
01/29/11 04:51 AM
Posts: 2,103 East Coast, NJ
fig426
East Coast, NJ
I have SB 416 4 speed T/A. Slow compared to what these guys are talking and I broke TWO 8.75's so far. The money I have dumped in the 8.75's would have almost bought me a Dana. Now I don't race that car anymore and am finishing a mild 528 hemi car that I put a Dana in. I learned.
Chris from New Jersey
[Re: Mopar_Mike]
#818901
01/29/11 09:49 AM
01/29/11 09:49 AM
Posts: 52,972 Romeo MI
MR_P_BODY
You never said the weight BUT I run a 8 3/4 and have for years... but my car is light... I currently run the alum center and a back brace.... I have no plans on putting a Dana in
[Re: mshred]
#818903
01/29/11 11:25 AM
01/29/11 11:25 AM
Posts: 16,923 NC
440Jim
NC
That is the right way to think about it. You might only get half what it cost to build that 8-3/4, but it will be a parts rear end (even harder to sell parts) when you break the gears, bend the housing, damage the trans sprag, etc.
[Re: Quicktree]
#818905
01/29/11 12:05 PM
01/29/11 12:05 PM
Posts: 2,172 Ohio
theclutcher
Ohio
Please, someone post the beaten horse. Hey modds, why dont we just sticky a post like this so if anyone has a question like it they can refer to the sticky. To the OP. If you have to ask, you need one.
[Re: Challenger 1]
#818906
01/29/11 12:16 PM
01/29/11 12:16 PM
Posts: 11,684 W. Kentucky
justinp61
W. Kentucky
Don't be a dumb, buy a 9".
I guess I'm one of the many dummies here. Oh well we all can't be geniuses . It amazes how much people blow about 9" rears. If they are so strong why didn't Ford put them in their 3/4 ton trucks? A good 9" third member will cost as much or almost as much as a complete Dana.
Sell your 8 3/4" and buy a new Dana, I got alomst half of my Dana cost out of the 8 3/4. I broke one 8 3/4, had to tear the 727 down to check it out, that was enough for me.
[Re: justinp61]
#818907
01/29/11 12:22 PM
01/29/11 12:22 PM
Quicktree
because a truck is a truck and they already had a truck rear, guess what it was? and when people suggest a 9" they are not talking a passenger type stock rear. it's an aftermarket race piece. like it or not the 9" race rear is the racers choice on 90% of the cars you see at the track.
[Re: Quicktree]
#818908
01/29/11 12:31 PM
01/29/11 12:31 PM
justinp61
W. Kentucky
because a truck is a truck and they already had a truck rear, guess what it was? and when people suggest a 9" they are not talking a passenger type stock rear. it's an aftermarket race piece . like it or not the 9" race rear is the racers choice on 90% of the cars you see at the track.
I'll say 60%, there a lot of Danas where I race. For the costs I'll stay with my dana.
[Re: DoctorDiff]
#818910
01/29/11 02:10 PM
01/29/11 02:10 PM
Quicktree
9" rearends are the small block Chevy of the rearend world. That doesn't make them the best choice for all applications, however.
1. A comparable drag style 9" is more expensive to build than a 35 spline Dana 60
2. A comparable drag style 9" weighs virtually the same as a Dana 60
3. A 9" runs hotter and robs more HP than a Dana 60
4. A 9(+)" style rearend built STRONGER than a Dana 60 costs MUCH MORE and the parts availability is MUCH LESS.
maybe so, but the dana is HP limited. the 9-9.5 and larger are not. for the average bracket racer there is nothing wrong with a dana. if they had a drop out center section it would be even better but that would make it a 9" based rear
[Re: DoctorDiff]
#818912
01/29/11 02:47 PM
01/29/11 02:47 PM
BobR
Left Coast
All rearends are "HP limited". Pro Stock doesn't run Dana 60s and Top Fuel doesn't run 9.5" rearends.
Application is everything.
Application is everything. I have a Strange Dana in my 416 Challenger T/A. I have a Dewco 9.5 in my race car. For the kind of racing most every weekend racers do the 9.5 is the best choice IMO. My brother has a fairly stout 8 3/4 in his BB Dart. He doesn't race it and therefore doesn't get much traction and it's fine for that.
[Re: theclutcher]
#818913
01/29/11 07:41 PM
01/29/11 07:41 PM
Posts: 1,627 anywhere@ anytime
actionange
anywhere@ anytime
[Re: Thumperdart]
#818915
01/30/11 12:46 AM
01/30/11 12:46 AM
Posts: 1,717 Rancho Cucamonga, Calif.
PUNK
We are switching over to a Dana because they just look BAD A$$!!!!!! Really though, the cost is a huge variable. We were going to do the 9" because we are not biased at all. But for our application the Dana fit the budget the best and we know we cant hurt it. Oh yeah....It looks BAD A$$ to!!!!
10.53 @ 125mph. 1.37 60 foot. Caltracs and Monoleafs, AFCO shocks.
Heads by INDIO MOTOR MACHINE; IMM. CP Pistons, PC Carbs.
[Re: justinp61]
#818916
02/03/11 10:51 AM
02/03/11 10:51 AM
Challenger 1
Cincinnati, Ohio
Maybe I shouldn't have used the word "dumb"
Just because your stuck in the 80s don't mean that everyone else has to be, a 9" is a much better choice for a race rearend, bar none!
[Re: actionange]
#818917
02/03/11 12:45 PM
02/03/11 12:45 PM
Posts: 9,986 Frostbitefalls MN (Rocky&Bullw...
gregsdart
I think you are forgetting that people come and go from this site all the time. New racers eager to learn come on here, read a quote like that and don't want to look dumb and then don't ask many questions. I don't mind responding every day to a different person the same info. To him it may very well be his first post, and probably is. without the tolerance of many good people on this board, as well as else where, I would probably still be fighting my way out the the elevens instead of running in the eights.
[Re: gregsdart]
#818918
02/03/11 01:14 PM
02/03/11 01:14 PM
Quicktree
and very well said, and nothing wrong with a little humor along the way. we deal with these posts on a monthly basis if not sooner.
[Re: Dean_Kuzluzski]
#818921
02/03/11 02:11 PM
02/03/11 02:11 PM
dragram440
bigfork mn
I think it would be hard to put a horsepower,weight limit on the 8 3/4. If so what can mine handle? 3740 lbs, 8" 5000 converter,foot brake, 35 sline m/w axles, spool, motive 3.91 gears, back brace and m/w caps and studs. I would asume that it would just be a guess?
67' charger 499 RB
10.57 at 127
[Re: Challenger 1]
#818922
02/03/11 10:36 PM
02/03/11 10:36 PM
justinp61
W. Kentucky
For my car the Dana is the best choice, obviously not the best for all applications, but I never said that it was. If the 9" was the end all of rear ends they would be in everything with wheels. I'm going to go to the shop now and listen to some hair bands and polish the cover on my Dana.
