Page 2 of 3 1 2 3
Re: Dana or 8 3/4.. I know.. I know, but just asking.. [Re: Mopar_Mike] #818891
10/02/10 12:49 AM
10/02/10 12:49 AM
State of retirement
52savoy Offline
52savoy  Offline
State of retirement
If it was my car, I would put a few runs on it and see how it reacts(unless you can find a cheap junkyard Dana). It might hold up with that ratio(contact pattern) and small tires..
I ran a 8 3/4" in my Hemi roadrunner for 5 years and the only thing I broke was the suregrip(year 2). Then a spool went in it.
The specs on my car at that time..
3500lbs, 14X32 slicks, 5.33 and 5.50 pro gears,Strange axles and spool.... 10.60at 128+mph. I put a Dana in it because I found one with 35 spline axles for $100.
for what it's worth..Jimmy Addison used an 8 3/4" in the Silver Bullet.
Re: Dana or 8 3/4.. I know.. I know, but just asking.. [Re: dragram440] #818892
01/28/11 01:35 AM
01/28/11 01:35 AM
Washington
SuperStock68Dart Offline
Washington
It is hard to spend the money once when the bolth of us already have 8 3/4's done. So its twice for us either way!!
Let me know how much it cost's you to fix the 8 3/4 AND transmission when it breaks! I've been there done that and it's not cheap. When I decided enough is enough I got a Dana from a pickup, knocked out the tubes installed chrome moly tubes, Mark Williams 40 spline gun drilled axles, MW aluminum spool, MW housing ends and Richmond pro gears for 2400.00 3yrs ago. Of course you need to find a narrowing jig to use and do the work yourself! When I was done the Dana was only 3 pounds more than the 8 3/4 it replaced! You can still sell the 8 3/4 at this point.
Re: Dana or 8 3/4.. I know.. I know, but just asking.. [Re: SuperStock68Dart] #818893
01/28/11 04:57 PM
01/28/11 04:57 PM
Nevada
theman440 Offline
theman440  Offline
Nevada
Take your rear wheels and drums/rotors off. Measure from axle flange to axle flange. Call Moser and order one without spring perches installed. Swap brakes, install, set pinion angle and weld up perches. I was quoted 1800.00 plus freight, comes with spool, 35 spline axles, green bearings and choice of ratio. Don't forget to shorten driveshaft.
Re: Dana or 8 3/4.. I know.. I know, but just asking.. [Re: dragram440] #818894
01/28/11 07:11 PM
01/28/11 07:11 PM
Between a rock & a hard place
cudadoug Offline
cudadoug  Offline
where does a guy buy a dana? Any Idea on what they are going for?
Get a Dana from a pick up at Pick-n-Pull and have it narrowed, new ends, etc. You can reuse your axles if the same length my shorten them a tad...
Re: Dana or 8 3/4.. I know.. I know, but just asking.. [Re: dragram440] #818895
01/28/11 07:15 PM
01/28/11 07:15 PM
cudadoug Offline
cudadoug  Offline
I would love to sell it but who would want one set up like this. If your going this route you might as well go with a 60. I was thinking of putting a 9" in it but to buy a good third member they arent cheap either. Maybe the 8 3/4 is broke now and thats what killed my trans.
Gosh I really hate to and sure don't want to beat a dead horse, but...9" phords break in heavy cars, too. Three words: Dana, Dana, Dana.
Re: Dana or 8 3/4.. I know.. I know, but just asking.. [Re: cudadoug] #818896
01/28/11 07:52 PM
01/28/11 07:52 PM
organ
maximum entropy Offline
organ
i'd like to add one more word- dana.
Re: Dana or 8 3/4.. I know.. I know, but just asking.. [Re: mshred] #818897
01/29/11 03:00 AM
01/29/11 03:00 AM
Left Coast
BobR Offline
BobR  Offline
Left Coast
never know until you try
They sell and they're fine for street cars.
Re: Dana or 8 3/4.. I know.. I know, but just asking.. [Re: BobR] #818898
01/29/11 04:46 AM
01/29/11 04:46 AM
communist bloc of new jersey
jamesc Offline
jamesc  Offline
Sell the 8-3/4 while its still in one peice and then the cost of the dana wont be so bad
yea what he said
Re: Dana or 8 3/4.. I know.. I know, but just asking.. [Re: BobR] #818899
01/29/11 04:51 AM
01/29/11 04:51 AM
East Coast, NJ
fig426 Offline
fig426  Offline
East Coast, NJ
I have SB 416 4 speed T/A. Slow compared to what these guys are talking and I broke TWO 8.75's so far. The money I have dumped in the 8.75's would have almost bought me a Dana. Now I don't race that car anymore and am finishing a mild 528 hemi car that I put a Dana in. I learned.
Chris from New Jersey
Re: Dana or 8 3/4.. I know.. I know, but just asking.. [Re: Mopar_Mike] #818900
01/29/11 08:57 AM
01/29/11 08:57 AM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
If I was gonna spend $$ for a race rear end it would be for a 9" because they have way more parts available for them and are alot easier to change ratios.
Don't be a dumb, buy a 9".
Re: Dana or 8 3/4.. I know.. I know, but just asking.. [Re: Mopar_Mike] #818901
01/29/11 09:49 AM
01/29/11 09:49 AM
MR_P_BODY Offline
MR_P_BODY  Offline
You never said the weight BUT I run a 8 3/4 and have
for years... but my car is light... I currently run
the alum center and a back brace.... I have no plans
on putting a Dana in
Re: Dana or 8 3/4.. I know.. I know, but just asking.. [Re: SuperStock68Dart] #818902
01/29/11 11:13 AM
01/29/11 11:13 AM
gregsdart Offline
gregsdart  Offline
Spend the money once and be done with it, go with the Dana. The 8 3/4 will eventually break and will take the trans with, at least it did in my car. Dana has been in the car for 3 seasons have not touched it. 1.3 60's @ 3500#
Tally the cost of the broken 8 3/4 plus the trans plus at least one lost race days worth of expenses then add what you could get for it now and it will show you just how close you are to getting the Dana cheaply!
Re: Dana or 8 3/4.. I know.. I know, but just asking.. [Re: mshred] #818903
01/29/11 11:25 AM
01/29/11 11:25 AM
NC
440Jim Offline
440Jim  Offline
NC
That is the right way to think about it. You might only get half what it cost to build that 8-3/4, but it will be a parts rear end (even harder to sell parts) when you break the gears, bend the housing, damage the trans sprag, etc.
Re: Dana or 8 3/4.. I know.. I know, but just asking.. [Re: gregsdart] #818904
01/29/11 11:32 AM
01/29/11 11:32 AM
Q
Quicktree Offline
Quicktree  Offline
Q
come on guys, everybody knows the 8 3/4 is bullet proof. thumperdart has been running one forever.
Re: Dana or 8 3/4.. I know.. I know, but just asking.. [Re: Quicktree] #818905
01/29/11 12:05 PM
01/29/11 12:05 PM
Ohio
theclutcher Offline
theclutcher  Offline
Ohio
Please, someone post the beaten horse.
Hey modds, why dont we just sticky a post like this so if anyone has a question like it they can refer to the sticky.
To the OP.
If you have to ask, you need one.
Re: Dana or 8 3/4.. I know.. I know, but just asking.. [Re: Challenger 1] #818906
01/29/11 12:16 PM
01/29/11 12:16 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
I guess I'm one of the many dummies here. Oh well we all can't be geniuses . It amazes how much people blow about 9" rears. If they are so strong why didn't Ford put them in their 3/4 ton trucks? A good 9" third member will cost as much or almost as much as a complete Dana.
Sell your 8 3/4" and buy a new Dana, I got alomst half of my Dana cost out of the 8 3/4. I broke one 8 3/4, had to tear the 727 down to check it out, that was enough for me.
Re: Dana or 8 3/4.. I know.. I know, but just asking.. [Re: justinp61] #818907
01/29/11 12:22 PM
01/29/11 12:22 PM
Q
Quicktree Offline
Quicktree  Offline
Q
because a truck is a truck and they already had a truck rear, guess what it was? and when people suggest a 9" they are not talking a passenger type stock rear. it's an aftermarket race piece. like it or not the 9" race rear is the racers choice on 90% of the cars you see at the track.
Re: Dana or 8 3/4.. I know.. I know, but just asking.. [Re: Quicktree] #818908
01/29/11 12:31 PM
01/29/11 12:31 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
because a truck is a truck and they already had a truck rear, guess what it was? and when people suggest a 9" they are not talking a passenger type stock rear. it's an aftermarket race piece . like it or not the 9" race rear is the racers choice on 90% of the cars you see at the track.
I'll say 60%, there a lot of Danas where I race. For the costs I'll stay with my dana.
Re: Dana or 8 3/4.. I know.. I know, but just asking.. [Re: Quicktree] #818909
01/29/11 01:51 PM
01/29/11 01:51 PM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
9" rearends are the small block Chevy of the rearend world. That doesn't make them the best choice for all applications, however.
1. A comparable drag style 9" is more expensive to build than a 35 spline Dana 60
2. A comparable drag style 9" weighs virtually the same as a Dana 60
3. A 9" runs hotter and robs more HP than a Dana 60
4. A 9(+)" style rearend built STRONGER than a Dana 60 costs MUCH MORE and the parts availability is MUCH LESS.
Re: Dana or 8 3/4.. I know.. I know, but just asking.. [Re: DoctorDiff] #818910
01/29/11 02:10 PM
01/29/11 02:10 PM
Q
Quicktree Offline
Quicktree  Offline
Q
maybe so, but the dana is HP limited. the 9-9.5 and larger are not. for the average bracket racer there is nothing wrong with a dana. if they had a drop out center section it would be even better but that would make it a 9" based rear
Page 2 of 3 1 2 3
